Question about InFocus ScreenPlay 4805 Multimedia Projector
InFocus x16 wont turn on, both lamp and temp turn red, but the projector wont work
  • 26 Answers
SOURCE: INFOCUS Lamp replacement
If the counter had expired, the projector would not even attempt a power up. You have other issues. How many blinks on the light?
Posted on Feb 28, 2008
  • 26 Answers
SOURCE: Infocus x1a projector shuts down after 30 seconds - dust problem ??
Most likely, if it is a thermal problem, your main cooling fan has quit or is stopping after a short period. The problem is, I've seen several of these do this, and in every case, it is not the fan that has failed, but the Controller Board. And that is a very expensive part.
Posted on Mar 12, 2008
Mark_Webber
  • 472 Answers
SOURCE: Infocus LP820 - Turns on for 30sec then shuts down
This could be one of two problems I have seen with another model Infocus projector (they are very good projectors though)
The first is the video input. Make sure it is attached correctly at both ends of the cable.
The second, remove the dust covers and blow them out. The problem can arrise if the temperature sensor detects the air inside the unit is getting too hot. If you can see the sensor when the dust covers are off (it will look like a little lump of goo on the end of a wire) then just give it a wipe as well. If dust settles on those it can cause incorrect temps to be reported.
Hope that solves your poblem =)
Posted on Apr 11, 2008
projdoc
  • 2237 Answers
SOURCE: InFocus LP120 Projector shuts off automatically
overheating or power supply problem.
Posted on Sep 03, 2009
projdoc
  • 2237 Answers
SOURCE: Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Posted on Mar 09, 2010
Testimonial: "Of all the comments on lamps failing to power up, only this answer fits my circumstances. I eliminated other "solutions" posted on FixYa. Thanks!"
Infocus in104 projetor problem: power off, temp red, lamp green
Most probably failure of the thermistor or thermal fuse that detects the temperature of the lamp housing - so the projector thinks it's hot even when it's cold. Unfortunately it will need a trip to an authorised service centre for repairs
Apr 04, 2014 | InFocus IN104 Projector
I have infocus t160 projector, it shuts off after 1 or 2 min and led of temp flashing red & lamp flashing green.
seems that the mother board is broken.
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 23, 2014 | InFocus X16 DLP Projector
Infocus in15 temp and lamp indicator flashing
In attempts to get your IN15 projector working, please try the steps below.
Disconnect AC power from the projector and wait for 10 seconds for supply to properly discharge.
While holding down the Menu, Select and Input buttons simultaneously, plug in the main AC power until
the LEDS stop flashing (approximately 7 seconds)
Jul 15, 2012 | InFocus IN15 DLP Projector
Why does Infocus IN102 projector auto shutdown after a few minutes and indicator light blinks red.
Is it possible to repair the controller board some how? Replacement is not an option because I have approx 100 projectors of this model and X16 lying with me, requiring immediate repairs...
Jan 07, 2012 | InFocus IN102 DLP Projector
Projector was turned off wrong and now wont turn back on.
if the led flashes once in 2-second intervals and you don't hear a high-pitched whir, the colorwheel needs replacing. if you do, the ballast is bad. if it flashes 2 times, the lamp is past 3000 hours. 4 times, fan error. 5 times, temp too high and it needs to cool.
Nov 07, 2009 | InFocus ScreenPlay 4805 Multimedia...
Projector shuts off within 30 seconds of power on
is the led lit on the top of the projector? what colors?
green is ok.
red flashing in sequence:
2 times- lamp hours exceed 200 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fans not working. remove obstruction or replace fan.
5 times- temp too high. clean thoroughly.
solid red- undiagnosed error by projector. possible power supply or ballast.
also make sure the lamp door switch is working.
Aug 07, 2009 | InFocus LP 820 Multimedia Projector
My Infocus DLP 4805 can't turn on
very possible the lamp is bad. Many projectors will not even power on once the lamp burns out. As for the strange noise, there may be something more serious wrong with it.
Jun 22, 2009 | InFocus ScreenPlay 4805 Multimedia...
No Image
You may be hearing the color wheel turning. Make sure the lamp is installed correctly and lamp access door/plate is properly closed.
Jun 24, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Infocus LP120 Retrying-Power Light Turns Red...
Usually when the lamp is good and you get this message, the ballast is bad. That is the part thatdrives the lamp. Check with Infocus for a repalacement balast.
Dan
Apr 09, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
InFocus ScreenPlay 4805 Multimedia Projector Logo
26 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
