Question about Pioneer GM-D510M Car Audio Amplifier
Amp trouble my amp wont turn on i looked at the wires and the fuses they are all fine. everything is connected it just shut off 2 days ago and wont turn on. what could be the problem.
  • 105 Answers
Check the remote turn on line from your deck & make sure there is 12 volts on it when everything is on. Check the ground, too.
Posted on Jul 15, 2007
SOURCE:
I cant get it to turn on the red light blinks but thats it
check the ground. it is most likely disconnecting also check the fuse between your battery and the amp and the actual amp fuse.
Jun 03, 2010 | Kenwood DNX7100 Car Video Player
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
Just stopped working
please check if the supply is still present in your amp using a multimeter. if you dont have a multimeter, check the fuse that supply the amp. a broken fuse will not turn the amp. let us know.
Apr 15, 2009 | Kenwood Car Audio & Video
1991 GMC sonoma ignition turns on but wont crank
check your battery first,  Then measure voltage to the starter solenoid.  No voltage at solenoid the problem is at the key switch.
Mar 08, 2009 | 1991 GMC Sonoma
1994 jeep cherokee rear dome light problem
Check to see if you have inadvertantly hit the push switch on the rear dome lite. Click it once and try
your lites again..I had this happen on my 93 jeep and that was the problem.
Dec 29, 2008 | 1996 Jeep Grand Cherokee
Kenwood 9102d wont power on
YOu might have burned out the inner fuse. Better yet the source connect...
Nov 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Car amplifier wont turn on
Your best bet is to call Alpine directly at: 1-800-832-4101
Jul 15, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
My amp wont turn on
The reason it used to cut-off at 60% volume as you said before,
Is probably due to the "protection circuit mode" being tripped.
You can try resetting it by turning off your CD player ,removing the Batt( + ) and Gnd ( - ) terminals from the amp for a short period. Reconnect them Allow the amp to receive power but not switch on (keep cd player/remote power source off)
If you dont know how to wire the CD player to control the amps power status , the easiest way is to connect the 'power antenna' or similar low voltage throughput wire from the head-unit to the amp's Remote terminal.
My old amp did the same thing ,and would need to be powered off/on before resuming sound output, sometimes I had lots of trouble with the protect mode staying on , even with little or no sound output from headunit.
Jul 14, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Amp wont turn on
It's possible the ground is not a good connection. Sometimes it may look good but dirt or corrosion builds up resistance creating a voltage drop where the wire is grounded to the frame.
Jan 26, 2008 | Jl Audio E1200 Car Audio Amplifier
Pioneer GM-D510M Car Audio Amplifier Logo
122 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
