Question about Frigidaire ATF6000ES Front Load Washer
How remove top from frigidaire washer model gltf1670as0
5 Suggested Answers
  • 883 Answers
SOURCE: Frigidaire gltf1670as0 Front Loading Washer
door lock position switch may not have been properly tightened at factory. first position then tighten the switch
Posted on May 23, 2007
onthejob5130
  • 640 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0
back bearings defective,,,should sound like train coming down on track..
Posted on Dec 29, 2008
  • 220 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0 Makes very loud
If you want to take the time, I just replaced my drum bearings and seal for $62.00. No really any special tools needed. My model showed the bearings were not sold seperately and you had to buy the complete tub half, but when you take it apart, you can knock out the bearings and buy them online or at a bearing house. I have a seal part number also.
If I remember right the bearing part numbers are 6306-2RS and 6307-2RS (1 each) and the seal is a 40mmX80mmX10mm thick. Make sure you get the -2RS bearings because they are sealed. The ones that came out of mine are shielded bearings ( -Z ) and they will not resist moisture if the seal shaft seal fails.
Most AutoZones have seal and bearing drivers you can "borrow". They really help during installation so you don't deform the seal or damage the new bearings.
Any good bearing house should be able to macth on up or if you post back I can give you the exact number. I think most brands of front washer use the same bearings, but you may want to take yours apart before you buy.
Worst case the junk yard doesn't care if it comes in pieces or as one piece. Give it a try.
Not sure you will want to get this involved, but its not really too bad of a job.
Posted on Dec 31, 2008
Jahn27
  • 1554 Answers
SOURCE: I received a Frigifaire Gallery
Unplug both appliances then insert a flat-blade screw drive into the slot between the front panel and the base of the dryer and pry the hole plugs out.
Remove the screws from the holes where the hole plugs were removed from.
Using two or more people, lift the dryer front then move it to the front to release it from the rear brackets and off the washer top.
Remove the rear brackets (one on each side) then install both into the slot on the washer's top panel.
Install the washer's top panel as shown then pull rearward on it to align the brackets and secure it with the screws previously removed.
Carefully lay the dryer on its back then install the four leveling legs.
Insert the hole plugs back into the dryer and you now have an unstacked washer and dryer.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 16, 2011
Why does my front loading washer leave brown stains on some loads?
Hello friend, I appreciate your post!
I see you're getting brown stains on some of your loads of laundry within your Frigidaire washer. I have completed some research in regards to brown stains and that could be iron or manganese in the water supply, water pipes, or water heater. In order to restore discolored loads try a rust remover safe for fabric. Do not use chlorine bleach to remove these stains as it may intensify discoloration. I hope this is helpful. -Matt
Aug 18, 2014 | Frigidaire Washing Machines
Frigidaire gltf1670as0 front load washer not agitating or spinning. fills drains and progresses through the cycle otherwise fine.
Hello paigeterrajr - Well, if there isn't any motor movement, it could be the door switch, the motor, or the main control board. Since the shock absorber could possibly be broken as well, it is possible that the unit thinks that it is not balance properly which will prevent it from going into a high speed spin/agitate. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 21, 2013 | Frigidaire GLTF1670A Front Load Washer
GLTF1670AS0 front load washer
What is your concern or questions with this particular washer?
Dec 27, 2012 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire gltf1670as0 uses to much water. Washing machine pulls water in and then pushes it right back out. All cycles are working but our water bill doubles each month we use it.
I would double check the drain hose, it sounds as if you are siphoning as it fills. The drain hose must be higher then the washer itself to prevent this from happening. If this does not solve this issue, get back to me and we can would on another possible solution.
Thanks, Gere
Oct 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Code ddo
Hi
This error code appears in the frigidaire washer which means--
ddo error--- Dispenser Drawer Open
Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
GLTF1670AS0
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Washing Machines
Dec 29, 2008 | Frigidaire ATF6000ES Front Load Washer
May 11, 2007 | Frigidaire GLWS1233A Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
