Question about HP Pavilion a6000n (882780985018) PC Desktop
Add Memory I want to add 1 GB of memory to my hp a6000n computer. Is there a special order to install the new memory
    Problem Solver:
  • 16 Answers
It depends, you will want to check the type of memory first, and make sure you are purchasing the correct type. Also, if you have memory slots that are different colors, you will want to put the memory in two similar colors. also, i would advise buying a set of 2 1gb sticks of ram that are dual-channel capable, and removing the old memory. Otherwise the old stick of memory will significantly slow down the speed the new stick can run at. Memory is extremely cheap at, you can get 2gb ddr2 ram for under $30.
Posted on Jan 20, 2009
Increase virtual memory
no proberly not,you should never do so.
i understand you wan't to add moore memory (RAM)
windows 32x can only handle max 4 64x 8-12 GB.
invest in some new memory (RAM) that's best.
Apr 24, 2013 | HP Presario Computers & Internet
HP Pavilion a6000n PC. M2N68-LA (NARRA GL8E) motherboard. This motherboard can hold 4GB of memory. I bought 4GB of PC2-400. Problem 1: When I install any of the sticks of memory the BIOS shows them as...
if you are using a 32 bit operating system it will not recognize all of the memory in some instances or the mobo is not designed for more than 2 gb maximum check the mainboard (motherboard) website for specs on your model. sometimes you have to use 64 bit operating system to be able to get the full use of memory over 2 GB
Jul 23, 2010 | HP Pavilion a6000n (882780985018) PC...
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
I want to increase th DDR in my emachines T2682. how much can i increase it and do i have to make any changes.?
Go to this trusted site I use all the time. Click "Scan My System" accept the download of the scanner. When it finishes it will tell you what you have and what you can add, with the cost of all options. They have good prices and are very safe & reliable. From your model # unless changes have been made you have 256MB of Ram which is far to little for XP to run like it should. This is the bare minimum for XP. Buy and install at least 1 GB of RAM. It is a simple process and you will have to make no changes to the system. Once you install the new RAM and turn the computer back on it will recognize the new memory. Follow the directions for installing the Ram and make sure to wear a ground strap or ground yourself to the exterior of the case before touching anything inside. Crucial has a section on installing RAM which you should look at if you have never done it before. Your XP will fly with 1 GB of ram and this is the best money you can spend to make it faster. I checked their site using the model # your listed and you are in luck. You can purchase 1 GB of RAM, which they have on sale, for $38.99. You have 2 slots in your computer and you will be able to leave the 256 MB intact and add the 1 GB giving you 5 times the Ram you now have. You can see the results here.
Feb 12, 2010 | E-Machines T2682 (000002965) PC Desktop
I need to add space to my compaq presario desk top. i don't know how to on this computer. the model# SR5034X
If you want to increase cpu speed so you need to increase RAM memory.
You can fix it on motherbord of desktop cpu.
But if you have low space on disk storage partition so you can add space to desktop with 2 method.
(1) you can add harddisk to desktop cpu with sata or IDE .SATA harddisk is best if your motherbord support SATA.
You can add harddisk as you like for example 80 GB or 160 Gb.
(2) If you want to add RAM memory for speed reson you can purchase new RAm and fix it in memory module slot on motherbord.
There is 2 type on
RAM in currently.
DDR1 and DDR2
you can add RAM memory like 512 MB or 1GB or more.
Aug 07, 2009 | Compaq Presario 5000 PC Desktop
Want to add memory to Gateway 700x
Max memory is 2GB, i.e. 1GB per slot(DIMM), so you will need 2 X (SimpleTech 1 GB PC3200 400MHz DDR RAM). {Always use matched pairs only}
Visit this link :
Mar 31, 2009 | Gateway 700 X PC Desktop
Upgrade problems
Your system comes stock with one stick of DDR2 (512 MB), which means that it is _ not_ dual channel DDR2 memory as dual channel DDR2 must be installed in matched pairs. Try to exchange the new memory for 2G of some single channel DDR2.
Jan 28, 2009 | eMachines W3507 PC Desktop
Added 1 gb memory ddr400 to motherboard, no added memory
Yes, lots have changed. You changed the memory.
Step one. Goto Start, control panel, system. See how much memory is displayed. If its the same, then you have to update your "BIOS". goto the manufacturers website and click on support by your model # to do this.
If it shows the new memory, then your fine.
Let me know if this fixes it!
Dec 29, 2008 | MSI 865PE Neo3-FS Motherboard
Wanting to upgrade the memory on a hp pavillion a6220a
Standard Memory:
256 MB or 512 MB or 1 GB (Removable)
Maximum Memory: 2 GB Memory Expansion: 2 Sockets
256MB Memory (PC2-5300) 396519-001, PX974AA, PX974AT KHEW974
512MB Module (PC2-5300) 396520-001, EK477-69001, PX975AA, PX975AT KHEW975
1GB Module (PC2-5300) 398038-001, PX976AA, PX976AT KHEW976
You can upgrade your system to 2GB MAX
Your memory type is PC2-5300
Please be sure to get the right memory (above listed)
Have a great day
Pablo :-)
Let me know if you have some questions about this issue...
Oct 22, 2008 | HP Computers & Internet
Install 2 RAM modules of 1 GB
The other memory may be soldered in. Check your manual and see if it has any information on additional memory. If you only have on expansion slot you may have to buy larger memory chips. like instead of 2 chips 1 gig each you may have to purchase a 2 gig chip. Computer companies usually make the chip installation easy to get to on lap tops.
Jan 14, 2008 | HP Compaq nx6310 Notebook
HP Pavilion a6000n (882780985018) PC Desktop Logo
995 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
