Question about Fujitsu LifeBook S2020 Notebook
Power button only turns laptop on when I disconnect battery, powe
I can only power on this fujitsu S2020 laptop, after disconnecting the battery and the power cord, and re connecting then turning the s2020 on
There's 4 buttons to the left of the power on button, 1,2,3,4 and enter, what are they for? a security code? on my S2020
I can only see a very very light image on my LCD when I turn on the S2020, I have this S2020 connected to a external crt monitor, and I works fine I'm sending this from the S2020
I have tried all 3 settings that I know, CRT, LCD, or View both screens at the same time.
I ordered a inverter and I'm waiting for it to arrive in the mail'
I can't get the wireless card, Video, and Modem drivers, there's a yellow question mark by all 3 in device manager.
Can anyone help
joestpaul09@gmail.com
    Problem Solver:
  • 5 Answers
The four buttons are for changing between your first four windows. Your screen dims to save power.
Your drivers sound like they are messing up your boot-up.
Use safe mode or your trick and use your fujitsu update my drivers program or use a program like Driver Detective.
I hope this fixed your problem.
Posted on Feb 03, 2009
Laptop will not fire up
disconnect the adapter+ battery , HOLD the power button by 30 seconds. the idea to release all the ESD accumulated, and connect the adapter+battery again and try it.
If doesnot resolve restart the computer HOLD the CRTL +F12 keys and use the software for recover to factory adjust.
If this does not resolve the problem test the power adapter output, the output battery, use the software utilitary coming with the computer for test the battery.
God bless you
May 23, 2013 | Fujitsu Siemens Computers & Internet
I'm using fujitsu lifebook s2020 and i have a problem with the wifi..my wifi is kind of disappeared or lost..how can i get it back? thank you
Good Day
The first thing you should check is that you WiFi is on. What I mean with that is that laptops usually have a button to switch on or off WiFi to generally save battery life. If you are sure that WiFi is on (usually the WiFi button's light is on) than check if ou can see a netwok adapter.
If you dont see it, there can be two reasons. 1. Another program which got installed on the laptop has controll over the WiFi and the WiFi will not be controlled my your Operating system. 2. Check the properties of your network place. It might contain the WiFi adapter disabled. Ceck under the properties and ut the tick poxes on "Show if adapter is connected" and "Show if there is a problem".
Last resort is to check under you Device manager (Right click My computer, Manage, Device Manager) and make sure the WiFi adapter's drivers are proberly installed.
Hope this helps
Jul 23, 2011 | Fujitsu LifeBook S2020 Notebook
My Fujitsu A6020 notebook laptop has a black screen after booting up. I entered the Bios Menu where it asked for a password to be entered, so I established a password. Then when I rebooted it asked for...
Remove the cmos battery for a few minutes and move the cmos jumper (If one) & Disconnect the power supply. While in that state press and hold the power button to discharge all power from unit. Then reinsert the battery and your cmos should be returned to default settings.
Jul 12, 2017 | Fujitsu LifeBook A6020 PC Notebook
I need a info on opening case of Fujitsu E8010 notebook to fix power supply connector.
Hi snaq,
I found this detailed blog on how to dismantle a Fujitsu Laptop. First, make sure that your warranty is already expire. :)
Please refer to this blog http://jackrepair.blogspot.com/2006/06/repairing-fujitsu-s2020-ac-jack.html
Mar 15, 2011 | Fujitsu LifeBook E8010 Notebook
We have a floor inverter, the timer display and power button keep flashing on the internal unit. Even after we have turned all the power off to it, no luck, Any ideas
Try to disconnect the battery for abot 15 seconds.
Check the battery voltage before and after disconnecting.
If no success after connecting back of a well charged battery, try to find the problem again with this information layed on.
Jul 16, 2010 | Fujitsu Electronics - Others
My Dell D610 doesn't turn on with the battery, connected to the adapter, neither just with the Battery; Battery is good. Just turn on without the battery...
1. do one thing
disconnect the power cord disconnect the battery\ disconnect any else connected the laptop. now hold down the power button for 1 minute. Now connect the battery and check Also recharge the battery.
If it still does not work, battery has gone bad.
Dec 08, 2009 | Dell Latitude D610 Notebook
Password forget to turn on fujitsu s2020
please remove and replace the cmos battery after 1minutes.
Sep 24, 2009 | Fujitsu LifeBook S2020 Notebook
Lifebook s2020 wont boot
try to replaced memory card or clean it first the pin of the memory card by using dry clothes
Aug 17, 2009 | Fujitsu LifeBook S2020 Notebook
Compaq nx9010 powers down to stanby.
select control panel off computer menu then select performance and maintence icon then select power options then you will see power options properties options tabs.. set properties to suit your needs
this should solve your problem
Jan 12, 2008 | HP Compaq Business Notebook NX9010
Fujitsu LifeBook S2020 Notebook Logo
106 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
