Question about Maytag 3.2 Cu. Ft. 6-Cycle Super Capacity Washer - White-on-White
WASHING MACHINE FILLS SLOW - Maytag 3.2 Cu. Ft. 6-Cycle Super Capacity Washer - White-on-White
    Sergeant:
  • 291 Answers
The water supply hoses at the back of the machine connect to a vatervalve. The watervalve has screens that can become clogged with lyme and other debris after a time. Usually cleaning the screens will solve a slow water fill issue. If no improvement replace the watervalve. Go to www.searspartsdirect.com type your model # into the long search bar. To the right is a short search bar, choose model# in the drop down. Click "search." find the exploded view with watervalve (usually in the "cabinet" view, i think) match the number of part with list at right of page.
Hope this helps.
Posted on Jan 07, 2013
Washing machine fills slow
If faucet is full opne, probebly are clogged filters Remove inle tubes and in the connection of tubes with machine youll find those filers. Remove them carfiully, wash them, reinsert and screw the tubes back.
How To Clean Your Washing Machine Filter
Oct 07, 2015 | Whirlpool Washing Machines
Washer fills extremely slow. Hoses are fine water
Hi, check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Jun 19, 2011 | Maytag PAV2300 Top Load Washer
My Kenmore HD plus 80 series fills up tub slowly, starts cycle before its full.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 13, 2011 | Dryers
Washinging machine tub fills with water after finishing a load
Your problem is kinda the opposite of these tips...
your fill valve has dirt in it and is leaking by...
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
heatman101
Sep 18, 2010 | Whirlpool Washing Machines
Water fills tub when off
You have kinds the opposite problem as these tips...there is dirt in your fill valve...
heatman101
Sep 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The drum fills with water when not in use.
You have kind of the opposite problem of these tips... the soleniod valve has dirt under it and will not shut off tight...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 07, 2010 | Whirlpool GHW9400 Front Load Washer
Light turns on but no water fills up.
heatman101
Aug 31, 2010 | Maytag Washing Machines
Washer fills slow on cold
I should be so lucky!
Mine takes a nap on hot filling.
Has the hose got a kink in it?
Cut off the water supply and remove the hoses.
Clean the intake filters of yor washing machine connectors.
LOL
May 01, 2009 | Washing Machines
Amana washer has no hot water - cold works fine
There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
Dec 04, 2007 | Amana ALW880WH Top Load Washer
Maytag 3.2 Cu. Ft. 6-Cycle Super Capacity Washer - White-on-White Logo
56 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
