Question about Crosley CW6000 Front Load Washer
Kenmore 80 series
Water fills and drains, but doesn't agitate, rinse or spin - sounds like it is working, but it is not.
  • 61 Answers
Ok sound lie a broke drive coupling lean the machine back look under the front you will see the motor in the center with a pump mounted on the front behind the motor is the gear case between the motor and gearcase is the drive coupling. To replace it disconect the power, remove the two clamps holding the pump on,remove the pump disconect the wiring harness to the motor now on the front of the motor there are two screws one on top and one one the bottom one the front of the motor with a 1/4 scocket romove the two screws. with a flat head screwdriver release the top clamp on the motor now the motor should tilt down and you can lift it off the coupling is on the short shaft of the motor and on the shaft of the gear case remove both may need to use a flathead screwdriver to get the one off the gearcase replace using a 1/2 deep well scocket and short extention and hammer tap them both on lightly but be sure the go all the way on put the rubber part of the coupling on the gearcase side and turn one of the fingers to 12:00 position turn one on the motor to 6:00 put motor back on the gear case bracket and put the top clamp on frist put the bottom clap back on insert screws put pump back on put pump clamps back on note you will have to turn the ootor to line the shaft up to go into the pump reconect the motor wiring harness plug machine in and test
Posted on Jan 20, 2009
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore 80 series Model # 110.23832100\r\nthe washer fills up agitates, when finished washing it stops pauses a while then starts to spin, you can hear the water going out put it is like it can't pick up...
Hi
If the washer is not draining then it is due to a clogged drain pump, drain filter or a kinked drain hose. Clean the drain hose, inspect if the drain hose is plugged. Also check the connection to the drain pump and make sure wiring is fine. Check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Apr 07, 2011 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Trouble shooting kenmore washing machine 80 series.
washer will fill with water that's it, will not operate on any cycle
Jun 22, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Crosley CW6000 Front Load Washer Logo
242 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jdthefixer
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
