Question about Sony (1QTY) Beige 3.5" Internal Floppy Drive 1.44mb (CFDDSWHT) Floppy Drive
Floppy disc not working
Yesterday I used my floppy disc and an hour latter when I went to use it again it would not work. It came up that the disc was not formatted, but it was and if I formate it I will loose everthing I have on it.
Can you give me any help on how i can open it.
Thanks
Stuart
  • hendo1946 Jan 20, 2009
    Thanks for trying but joy with your suggestions.
    Thanks for trying but NO joy with your suggestions
  • 15,935 Answers
Sometimes u can go to a different computer and get the disk to work. Most of the time u can't though. I suggest you try a few different computers (new and old computers) and if you get one to read it get your info off and save it to another floppy or a flash drive or something. I have also tried the format option and it will always say that the disk can't be formatted. I usually toss them in the trash after that.
You may also try running a standard windows scandisk on the disk. A lot of people feel more secure saving their stuff to a floppy, mostly because it's something physical they can hang onto and carry around. But the truth is that they are far too unreliable to use given the wide range of other options available today (e-mail, ftp, jump drives, hard drives, cd-roms, etc.)
Posted on Jan 20, 2009
  • 1 more comment
  • blueextc3221
    blueextc3221 Jan 20, 2009
    I've found that disks with that error message can be saved - sometimes.
    It basically means that the disk has errors on it. If you do a Scandisk on that floppy, checking the "thorough" option, it will fix bad sectors if they are repairable. Sometimes the bad sectors are where your important data is stored, and you may lose some. But many times I've been able to recover most if not all the data.
    Open up my computer and right click on the floppy, go to properties, then tools. Click on Check Now in the error checking section.
    An interesting note though - using Scandisk on a Win98 machine works, while using the error check on a Win2000 machine usually doesn't.
    I work at a school, and a lot of students bring these disks to me. Always save your work on a hard drive somewhere, then back up to floppy. Good luck!
  • blueextc3221
    Because this isnt what you wanted to hear does not make it worthy of a "thanks for trying" rating.
  • blueextc3221
    blueextc3221 Jan 21, 2009
    I would appreciate you returning HERE to modify your rating from "thans for trying" to a higher rating. The eperts here at Fixya are assigned a percentage in direct correlation to the ratings given. A "thanks for trying" rating greatly skews the average in a negative way. Your question was answered with the appropriate response - even if it is not what you wanted to hear.
    Your cooperation is appreciated.
Floppy boot disk
Try setting the boot order in the BIOS to floppy drive first. If that does not work, try writing the floppy again, preferably to a different, new floppy disc in case that one is failing.
Oct 21, 2013 | Foxconn Computers & Internet
Floppy disc does not work on pc
Floppy discs go bad all the time. Test with another floppy.
Dec 09, 2012 | Computers & Internet
KURZWEIL K2000 Synthesizer/Keyboard My floppy drive gives the message "Problem Mounting Disk" when I try to read a floppy. The floppy is the Kurzweil K2000 Factory Programs and Demos, so it...
Hi
Remove the battery, and clean the compartment of any old corrosion on the contacts. Leave the batteries out for a few hours. Allow all static electricity to drain. While it's off and UNPLUGGED work the power switch a few times to bet all the charge in the capacitors of the power supply. Press some buttons.... let it rest a few hours. Next return the batteries and start the machine. Your problem appears to be corrupted boot up of the Operating and Setup chips after a partial discharge and rapid reboot.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 14, 2011 | Computers & Internet
How do I transfer music data off my korg Triton keyboard's floppy
Either the floppy format of the Triton is not PC compatible or maybe you don't have a floppy drive on your computer? If the latter, buy a USB floppy drive... about $20
Sep 16, 2009 | Music
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
I wanted to copy some files from a floppy disc to my external hard disc formated for Mac but there seems to be mechanical problems and it says it is unreadable and wants me to reformat it. I bought a new...
Copying files from Floppy Drive to External HDD.
01. Ensure that both Floppy drive and External HDD are configured properly in the machine.
02. Sometimes if virus affected the files of floppy drive, will not copy the full files.
03. Close the small led in the floppy top right side and check once again.
04. In start program, type coimmand and the dos prompt with Drive will appear.
05. keyin Dir A: and see it reads all files.
06. There also it gives error, you cannot copy these files to External HDD.
07. Try to use some other floppier which is already formatted.
08. Ohrr solution is just copy all these files from the floppy drive on to C: and copy the same files after creating a folder in C Drive.
09. Check the Interlink cable is also working fine.
10. If the problem not solved, please call authorized system service engineer to sort out the issue..
Mar 05, 2009 | Imation (01946) External Floppy Drive
Icon not appearing on drives list
Did you use the Safely Remove Hardware icon to disconnect your floppy drive? Did you subsequently connect the drive to a different USB port? If both answers are YES, then simply reconnect the drive to the same port and it should work.
If that fails, reboot your machine and try again. USB ports are finicky if you don't follow proper protocol.
Jan 26, 2009 | Mad Dog Multimedia Dominator (MDED1F)...
F1 floopy diskette faliure seek faliure
Make sure it is not disabled in the boot order, there is also an option for the drive itself (Diskette Drive) that must be disabled
Jan 05, 2009 | Dell Dimension E310 PC Desktop
Floppy disc
Take the floppy disk with the writing on the top side and insert it into your floppy drive (typically it will be your A: / drive).....This will work if it’s a USB or an internal floppy drive.....I hope this helps
cbinny1
Sep 29, 2008 | Panasonic 1.2MB 5.25 Intrl Floppy Drive...
TEAC floppy drive won't work with Vista Home Premium
Have you tried WWW.Driverguide.com - Generally I have found all the drivers I need there. Else try the manufacturer's web site at www.teac.com
Aug 15, 2007 | Teac Floppy Drive 235HF Internal Floppy...
Computers & Internet Logo
224 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
