Question about Kenmore 22422 Top Load Washer
Machine will not advance to next function in cycle on its own.
My machine will not advance to the next step ina cycle unless I do it manually...how do I cahnge a TImer maybe????
    Novelist:
  • 101 Answers
A timer is easy to replace. Depending on your machine though if the timer is expensive just get a new machine or see if you can get a refurbished timer for less. If you remove the back panel which involves removing about 8 screws you will see the timer. Unplug the machine and just remove the wires connecting to it. Remove the few screws that hold the timer in and remove the timer then replace with the new one. Sometimes it takes a little love to get the thing out and make sure you remove the knob first from the front of the panel so it comes out. Let me know if you have any other questions.
Posted on Jan 21, 2009
What could be wrong with our washer So our washer filled up with water and then will not go into the next cycle even if we try to manually do it Do you know what could be wrong
  • Does Your machine have a little switch button activated by the top door? (You can hear it click as you open and close the door.). If that switch is not working, the control click can not let the machine advance to the next step in the cycle.
  • Let US know what you find. M B
Jul 08, 2014 | Kenmore 24032\24036 Top Load Washer
My Kenmore washer will not move into the next cycle unless I manually turn it to the next cycle. This just began today. What is wrong with it?
It's either the timer is faulty or the lid switch is broken. If it fills and agitates but dos not spin and drain it's the lid switch. If it spins and drains when manually advanced to that setting your timer is bad.
May 18, 2011 | Kenmore Washing Machines
My washer runs non stop on the wash cycle...it washes the clothes but doesn't past the wash cycle...doesn't drain, rinse or spins. What can I do?
Can you manually rotate the timer control to the next steps?
Will it proceed thru the cycles when you rotate the timer manually?
If so, then you can complete the cycle manually for the time being...
If so-- then the clock motor that drives the timer.control is not advancing it.
If yours is a newer machine with all digital controls, then I suspect something wrong in that controller, too-- But I do not have any idea of how to 'advance it manually!
(The blessings of modern controllers!-- Give me the old clock motor driven drum controllers! :-) )
Mack B
Dec 28, 2010 | Washing Machines
My kenmore washing machine dosnt cycle from one function to the next can anyone help
With the limited information, my initial leaning is toward the timer being bad, not advancing through the cycles. The timer is where practically every function is controlled on a washer. I can't think of any other item that would give the same symptom
Oct 29, 2009 | Kenmore Washing Machines
My Kenmore Washer 110.92281100 won't stop
I purchased a new timer, installed and solved the issue.
May 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 22422 Top Load Washer Logo
53 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
