Question about Miele Touchtronic W1213 Front Load Washer
Where can i purchase bearings for a miele w1213 washer
Trying to replace the bearings in my miele w1213 but don't know the part number or where to buy the bearings.
SOURCE: How to fix a Miele
check drain pump is not blocked if so clean out
Posted on Mar 15, 2008
marked
  • 6487 Answers
Below is how error codes are deciphered by the cycle lights and water level light. This should help diagnose the failure. I recommend to have service technician diagnose and repair your washer.
LONG DRAIN error code will cause the NORMAL, PERM PRESS, and HANDWASH cycle led lights to come on and the WATER LEVEL light to blink.
If the drain time exceeds 6 minutes, the wash cycle will stop. Push the START/OFF button to reset the mode, a drain task is executed and the previously selected cycle resumes.
POTENTIAL CAUSES:
  • Drain pump failure.
  • Drain hose: check for proper connection, kinks or clogs.
  • Pressure switch contact failure.
INCORRECT FILL WATER LEVEL error code will cause the HEAVY DUTY, PERM PRESS, and HANDWASH cycle led lights to come on and the WATER LEVEL light to blink.
Wash cycle stops. Press START/OFF button to enter Standby mode. Execute a Diagnostic Test to drain the water.
POTENTIAL CAUSES:
  • Incorrect electrical connection to pressure switch.
  • Pressure switch is defective.
  • Pressure switch hose is damaged or loose.
  • Air dome is clogged.
  • Drain hose: check for proper height, kinks or clogs.
UNEXPECTED FILL DURING AGITATION OR SOAK error code will cause the HEAVY DUTY, NORMAL, and the HANDWASH cycle lights to to come on and the WATER LEVEL light to blink.
The pressure switch contact selected has opened during agitation task. The wash cycle stops and a Drain task is executed. Once the Drain is complete, the cycle stops.
Push the START/OFF button to reset the operation mode, a Fill task is executed and the previously selected cycle resumes.
POTENTIAL CAUSES:
  • Water or clothes were removed from basket after Fill task was complete.
  • Drain hose is improperly connected.
  • Water leaking from washer tub.
SLOW FILL error code will cause the HEAVY DUTY,NORMAL, and PERM PRESS cycle lights to come on and the WATER LEVEL light to blink.
If the Fill task exceeds 20 minutes, the wash cycle stops. Push the START/OFF button to reset the operation mode, a Fill task is executed according to previous Wash Temp selection and the previously selected cycle resumes.
POTENTIAL CAUSES:
  • Water inlet valve is clogged or damaged.
  • Water pressure is too low.
  • Water hose is closed/clogged.
  • Water supply faucet(s) turned off.
Hope that helps..........
Posted on Jul 12, 2008
  • 122 Answers
Unfortunately you need a Service Rep out there to check the electronics - how old is the machine? - Warranty? the drain pump should be 220 or 120 depending on the model.
Posted on Nov 30, 2008
  • 177 Answers
SOURCE: No Power lights, anything, on a Miele W1213
make sure the door is closed properly and push it hard as this completes the light circuit on the display and then allows the unit to work.
Posted on Aug 18, 2010
  • 251 Answers
SOURCE: Miele Touchtronic W1213 Front Load
hi - If I remember correctly this particular series had a time related sequence built into the programme, whats happening is the timer has picked up the false readings when the pressure activates the switch.
Suggestions to look into - leave power off & turn water back on - does water run into the machine (faulty valve); turn power on initiate a cycle water runs, then turn power off - is water still running? (faulty valve)
From experiences on the field, theres a slim chance that the pressure tube has a hole in it from the vibrations over time. This effect will not create enough pressure in the tube to activate the pressure switch, the only other problem would be the pressure switch itself.
Posted on Jun 18, 2011
Miele washer leaking from soap tray (on rinse cycle). Can't figure out what's the problem. Please help.
Remove and clean fully soap tray. if persists could be machine leveling or water pressure too high going in so fast to tray that its unable to cope, in which case try reducing the water pressure. good luck
Feb 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Miele frong load washer water will not drain, what do I do
Check the hose going to and from your pump which is located on the bottom of your machine. You prob ably have a underwire preventing ytour pump from spinning.
Jan 14, 2010 | Miele Touchtronic W1213 Front Load Washer
Rinse light flashing on miele novomatic washing machine
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30. The shop time should not exceed one hour. Miele charges about $50 for brushes if you can not find a local supplier. The W1930 motor that I rebuilt used a 6202Z and a 6201Z bearing set.
Sep 02, 2008 | Miele Touchtronic W1213 Front Load Washer
Miele 2104 Washing Machine
If your model is displaying the same symptoms as the W1930 that I repaired, then the cure is to replace or check the brushes on the main drive motor ($17) and check or replace the bearings ($12). This is much easier on the pocket book. I was able to confirm the presence of drive voltage (25VDC) to the motor terminals prior to the removal.
May 25, 2008 | Miele Touchtronic W1213 Front Load Washer
Miele Touchtronic W1213 Front Load Washer Logo
43 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
