Question about Star Manufacturing International Star TSP100 Printer
Star tsp 100 printer will not print with coffee shop manager
2 Suggested Answers
SOURCE: Star TSP 100 do not print in access 2003, access
Miguel963,
I hope you have solved your problem in the mean time (9 months ago!).
I just bought the same printer and ran into the same problem. After looking on the internet for a solution and finding none I read the software manual a couple of times again and came up with this solution.
Access is right when it claims that the report's length is over the 22.75'' limit. The paper size of the 72 mm x Receipt is 72 mm wide and 3,000 mm tall; 22.75 being 577.85 mm. This means that the selected paper size is more than 5 times too tall.
The simplest solution is to choose the 72 mm x 200 mm paper size.
Next you need to go to the properties of your printer (Start > Settings > Printers and Faxes > Star TSP100 Cutter (TSP143)). Select Printer > Properties. In the Properties dialog select the Device Settings tab. Under Installable Options, set the Paper Type to Receipt. Setting the paper type to Receipt will cause the pages to have a variable length.
While you're there you might set the Page Cut Type to No Cut and set the Document Cut Type to Partial Cut.
Works like a charm for me.
If you really want you can even add Access's favorite paper length to the list of paper sizes. To do that you need to go to My Computer > Control Panel > Printers and Faxes. The best way to go there is to use the Windows Explorer or something similar. Under the File menu in Windows Explorer you'll find an option Server Properties. The Print Server Properties Dialog Box is shown. On the Forms tab you'll see a Forms on: <ComputerName> list. Locate the Star paper size of e.g. 72 mm x 200 mm and select it in the list. Once you check the Create a new form check box you can give it a new name. I called mine 72 mm x Access and modified the paper height to the 22.75'' or 577.8 mm.
However, I ran some tests and it doesn't seem like this last step is really necessary. Even with the 72 mm x 200 mm paper size selected for my Access report I printed tickets that were 5,000 mm tall without any problem.
Hth,
Posted on Oct 31, 2010
Star tps 100 not producing reciept intermittantly
Is this the networked Star TSP or the USB version? If it's networked you may want to make sure that you're still connected to the network by printing out a test receipt (power the printer off, hold the feed button down while it's off and continue holding the feed button after turning the printer back on until it prints a test receipt - the second receipt will give IP configuration information).
If you're not receiving a valid IP address you may be having network issues - you might consider assigning the printer (you might need to power cycle your router and printer to get initially connected again in order to do this).
You can also try resetting the printer to its default configuration - you can find instructions here:
Star TSP100Lan Network Troubleshooting Unable to Detect the Printer within...
Oct 25, 2014 | Star Micronics TSP100 Thermal Printer
Why is my star tsp-800 thermal printer offline?
Hi Valued Star User
Please try restarting the computer, this will reset the printer spooler, clear any existing print document and should mean the printer comes back online.
I hope this helps.
For further help please contact us at: support@star-emea.com
Best regards
Star Technical Support
Jan 31, 2012 | Star TSP-800 Thermal Receipt Printers
How do I get my TSp 650 to open the cash drawer. It prints XP printer test page fine.
Hi
Go into the "Device Properties" page of the driver and select "Open Cash Drawer".
Please contact support@star-emea.com for more information.
Star Technical Support.
Aug 15, 2011 | Office Equipment & Supplies
My printer only prints to copies, want one Star TSP 100 future print, how do I change setting
It could be a setting in the driver or in your point of sale software. If you want to check the driver, right click on the TSP100 in Printers and Faxes and click on properties, then printing preferences and advanced. In advanced, make sure the copy count is set to 1.
If you need help assistance with Star Micronics printers, you can contact their technical support at (800) 782-7636 or http://www.starmicronics.com/Supports/TechnicalSupport.aspx .
Feb 17, 2011 | Star Micronics TSP100 Thermal Printer
How to change the printing darkness star tsp 700
To change the darkness settings, use the
printing darkness settings command 'd' n. Refer to the separate
programmer's manual for details.
http://www.star-m.jp/eng/service/usermanual/linemode_cm_en.pdf
Oct 28, 2010 | Office Equipment & Supplies
STAR TSP 100 FUTURE PRNT
check the roll of paper in the receipt printer. If it is feeding wrong, it will not print. Turn it around. Kathy
Jul 09, 2008 | Star Micronics TSP100 Thermal Printer
Star Manufacturing International Star TSP100  Printer Logo
21 people viewed this question
Top Star Manufacturing International Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Star Manufacturing International Office Equipment and Supply Expert? Answer questions, earn points and help others
