Red Power Light flashes 3 times
Bought the TV 3 years ago, and it worked great. Just this evening I heared some relays click at the back of the TV, and the screen went dark. The Power Light blinks 3 times, and taking the TV off power several times did not make a difference.
  • Jacek Janiszewski Jan 07, 2013
    This a problem with Panasonic Viera TCP54G10 Plasma TV
    Top Expert:
  • Televison & ... Master
  • 74,468 Answers
3 blinks 3.3v SOS D Board. This is the fault. That's SOS board has the fault. Check this to know more details.
Posted on Jan 07, 2013
  • 308 Answers
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
Posted on Jan 18, 2007
SOURCE: power light blinks red, TV doesn't turn on
if you are not technical i sugest you have this checked out by a professional most probably a fuse has gone from iside or your driver board has gone down. The blinking should be normal after you have turneds it off because some capacitors will be discharging.
Posted on Aug 24, 2007
  • 61 Answers
SOURCE: Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Posted on Nov 19, 2008
ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 94 Answers
SOURCE: wont power on
caps on main board may be defective. power supply may be defective if the caps on the MB arent bubbled
Posted on May 28, 2010
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Mitsubishi model# wd-62327
you have identified the problem good,
but you could specify the problem a bit accurately
:the possibilities of your problem might be because of.
1.fault in the circuit
or
2.problem in the display of your tv.
Dec 07, 2007 | Mitsubishi WD62327 TV
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
Just replaced the lamp, worked for about 3-4 days, tv won't turn on, green light flash about 3-4 times then a red light flashes, waited about two days, tv came on and worked for about 1 month now the same...
I have the same TV and had same problem . Try taking the bulb and assembly out and reinstall , there are some sensors on the assemblies that might not be getting good contact . It fixed mine .
Jan 20, 2011 | Sony KDF-50E2000 50" HDTV
Horizontal lines on screen after STR6301 replcement
hi just by using a 3-2 prong converter which is found at a hardware store can take away ur problem. It takes the plug into the wall from a 3 prong plug to a 2 prong plug and is supposed to work. try it and let me know if it works....
May 24, 2009 | Sony Televison & Video
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
TP55Hwon't turn on, after unplugging, click and red light flashes
I HAVE THE SAME PROBLEM ,I FOUND OUT AFTER OBSERVING FOR QUITE SOMETIME THAT THE CLICKING NOISE I HERE AFTER PLUGGING IT TO THE OUTLET CAME FROM A RELAY SWITCH LOCATED ON THE POWER BOARD AFTER TAPPING ON IT THE SET WOULD POWER AND THE BLINKING RED LIGHT GOES TO NORMAL..I BELIEVE THIS RELAY IS CAUSING THIS PROBLEM FOR ALL THE FELLOWS OUT THERE WITH THIS TV SET AND THE BLINKING RED LIGHT..IN MY CASE THE RELAY WENT SO BAD NOW THAT THE COIL THAT MAGNETIZES TO CLOSE THE CIRCUIT GAVE UP ,SO I PULLED THE COVER OF THE RELAY TO UNVEIL THE TWO METAL STRPS THAT COME IN CONTACT AND HAVE BENT ONE SLITELY TO REMANE CLOSE THIS POWERS THE TV UP NORMAL BUT IN ORDER TO SHUT IT DOWN I HAVE TO PULL THE OUTLET. THIS IS TEMPORARY UNTIL I CAN FIND WHERE TO GET RELAY SWITCH. PLEASE DONT TAKE MY RESEARCH AS A SOLUTION BUT FOR WHAT EVER ITS WORTH. I WILL GET THIS UP AND RUNNING AGAIN ITS ALL WORTH EVERY DOLLAR TO FIX.
Nov 18, 2008 | Toshiba TP55H60 55" Rear Projection...
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Aug 10, 2007 | LG RU-52SZ51D 52" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
