Acer aspire 4738 cannot open flashing power light whene pressing on button
SOURCE: ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
Posted on Feb 24, 2009
benwabnick
  • 2404 Answers
SOURCE: i have an acer aspire 3680 2682 that wont boot.
Try also taking out the hard drive and the dvd drive to make sure that they aren't shorting out the motherboard.
Also try another stick of memory besides the one that came with your laptop to be sure the memory isn't bad.
If after you do these steps you still can't get video then your motherboard is bad.
Posted on Jul 31, 2009
SOURCE: i cannot turn on my acer aspire 5520. when i press
Hi there! this is a possible power supply problem or the power button from the laptop is faulty.. But first I suggest that you use a different working power adapter that is same power supply for your laptop and try to remove the battery and try to clean the contact point of your batter, to further isolate the problem, if you did this troubleshooting and still doing the same thing I suggest that you bring ur laptop to acer for check up and repair of the power supply system of the laptop, if your laptop still under warranty, bring it to the service center right away.. if not then u can try doing the troubleshooting..
Posted on Aug 12, 2009
SOURCE: acer aspire 5315 doesnt boot blank screen
When you power up the laptop press F1 or F2 or "del" key to enter in bios setup.
Then check your harddisk is detect or not?
Then also make sure SATA option is disabled in bios.
Then go to boot option and set first boot device as your harddrive.Then save settings and exit.
But if you even not able to enter in bios then you have reset bios settings and Refix RAM memory .
For that open back cover fo laptop and find cmos cell on motherbord pull it for 10 minutes so all settings of bios goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 25, 2009
  • 846 Answers
SOURCE: acer aspire 5580 , power button is broken, how to start
i would assume somebody has to open the Laptop and replace the powerbutton. If you want to pay to have somebody do it for you there is a third party Acer Repair Service. However, if you want to do it yourself, the part is available on ebay. Here's an Acer Repair guide. Maybe a tech savy friend can do it for you.
Posted on Jan 20, 2011
Why does my acer aspire e1 571- 6482 not start or charge anymore? only the on led and batt led flash.
pressing power on button should be for 30 to 40 sec but the flashing lights means there is a hardware problem can find flashing light codes on the net you could try removing ram 1 by 1 c if that works hope this helps if not will keep an eye on this
Jul 29, 2014 | Acer Aspire E1-571-6650 Laptop
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
I cannot start up my acer aspire 584g32bn
Safe Mode and System Restore can fix startup issues in an Acer Aspire One, but if the computer won't even load the boot screen, the problem could be related to the basic input/output system (BIOS).
The Acer Aspire One 110 and 150 are two models that can have BIOS-related problems that prevent the computer from booting.
You can upgrade the BIOS through a USB flash drive to repair this issue.
If you are able boot past the startup screen, but can't sign in to Windows, you can use Windows Advanced Boot Options to bypass startup problems.
Go to the Acer website (see Below).
http://us.acer.com/ac/en/US/content/drivers
Click "Support," then select "Download" from the menu on the left.
Select "Netbook" as the product family.
Click "Aspire One" as the product line. Select "AOA110" or "AOA150" as the product model.
Click the "BIOS" tab.
Click the download button and save the file to the desktop.
Go to the desktop when the download completes.
Double-click the file to open it.
Drag-and-drop the folder to the desktop.
Double-click the folder to open its contents in Windows Explorer.
Double-click the "BIOS_Acer_3310_A_AOA110 & AOA150" folder.
Double-click the "Dos_Flash" folder.
Insert a blank USB flash drive into a USB slot.
Drag-and-drop the "3310.fd" and "Flashit.exe" files to the flash drive.
Right-click the "3310.fd" file. Click "Rename."
Change the file name to "zg5ia32.fd" and press "Enter."
Connect the AC adapter to the power jack.
Hold down "Fn" and "Esc" with one hand, then press the power button with the other.
Release the "Fn" and "Esc" keys when the power indicator light comes on.
Wait at least seven minutes for the system to fix the BIOS and repair the Acer Aspire One startup issues.
The computer will restart automatically when the process is complete.
Other Models
Turn on the computer.
Press "F8" before the Windows logo appears to access the Windows Advanced Boot Options menu.
Scroll to Last-Known Good Configuration.
Press "Enter" to load Windows.
If the OS fails to start up, hold down the power button for 10 seconds to turn off the computer.
Press the power button to turn the Acer Aspire One back on. Press "F8," then select "Safe Mode" from the options.
Log in to Safe Mode. Click "Start," "All Programs," "System Tools" and then "System Restore." Click "Next."
Select the last working restore point from the options. Click "Next."
Click "Finish" to run System Restore and recover the Acer Aspire One to a previous state.
Apr 21, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 1640 wont start up. when power button is pressed all lights flash but nothing happens
It sounds like you may have a faulty power switch/button and are in need of replacing it.
Mar 25, 2011 | Acer Aspire 1640Z Notebook
Is bluetooth available in acer aspire 4738?
hold fn then press f3 then drag the off button to on
Hope It Helps!!!
Nov 11, 2010 | Acer Computers & Internet
Why dont open web camara windos xp acer 4740
download acer's webcam driver from the following link, and choose your acer's laptop brand.
http://support.acer-euro.com/drivers/downloads_gd.html
Aug 11, 2010 | Acer Aspire 4720 Notebook
Black screen acer aspire 4315, changed screen & inverter but still no joy any help please.
If the screen is black and the power light & fan still work....try this:
ASPIRE ONE BIOS FLASH RECOVERY
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
http://support.acer.com/drivers_download.aspx
Jan 19, 2010 | Acer Aspire 4315 Notebook
My acer aspire one netbook was black screen but the power was lighted, i hear the fun was spinning and the hdd was spinning, please help me, when i powered on it lights up but no display at all a blac
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
May 04, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
