Question about HP LaserJet 2840 Printer
Hp color laserjet 2840 error code 54.2 fix it
I just installed new cartridge and then 54.2 error is showing it also says Turn off then on and I've tried that several time and the error is stillthere
  • 3 Answers
SOURCE: Re-installing yellow cartridge in HP 2840
There is a gray button right of the LCD display that has a black arrow circling clockwise and four color dots (magenta/black/cyan/yellow). Push it until you see the "Rotating to Yellow" in the LCD display, then open up the top of the printer by pushing the big gray latch next to the picture card reader at the right front of the printer. You now have access to the cartridge. pull it out and examine it. If it is a new cartridge, check to see if you pulled the plastic dam strip out (which keeps the toner in place in shipment etc).
Posted on Sep 17, 2008
  • 3 Answers
SOURCE: HP Printer Color LaserJet 2840
I Have A HP Laserjet 2820 on power up went through to scanner bulb warming up then made a clicking noise comming from scanner unit it was trying to escape the case. if this is the same as yours the problem is that the scanner unit can't find the home position strip mounted betweent the gray case wide piece right hand side as you look down on scanner unit with lid up & the top of the scanner glass inside the scanner unit to get to it you must remove top section of the scanner unit & cleean underside of scanner glass please E-mail me if you want full instruction.
Posted on Jan 01, 2009
  • 14 Answers
SOURCE: Replaced HP LaserJet 2840 catridges and now [?][?][?][?] ! error
The OEM cartridges have a chip on them. If the aftermarket supplies do not have the right chip, missing a chip, etc., the machine will not recognize. Placing the old cartridge back in without any toner can give off the same message.
Try rebooting the printer without a cartridge in. Then install the cartridge, either one, and see if that helps. If not, wait for the OEM to arrive.
Posted on Jan 28, 2009
sys_admin
  • 829 Answers
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Posted on Mar 22, 2009
SOURCE: Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
Posted on May 14, 2009
I installed an original Q3971A toner into the HP 2840 laser printer, However there is still a notice to install cyan catridge. Can you help please
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
Dec 18, 2015 | HP LaserJet 2840 All-In-One Printer
Hp color laserjet 1025 cartridge memory error on imaging drum
If the ground spring located on the left inside wall of the printer is ok, and you have tried cleaning all the ground contacts on the cartridge, then it may just be a bad toner cartridge. Especially if it's a third party cartridge and/or especially if this problem happened right after or shortly after installing a new cartridge.
Jan 19, 2015 | HP RB3-1025 Hewlett-Packard Color Laserjet...
How to reset supplies on HP 2840 laserjet?
"Would like report of supplies from 2840 laserjet. How to get it to show report"
Select 'Menu" button, then select "Reports", then select "Supplies Report".
This will print the status of the four toner cartridges and the drum.
It doesn't make sense to reset toner cartridges UNLESS you refill them
first. On the HP 2840 each cartridge/drum contains a chip that measures
the life of the unit.
You can purchase toner/chip combinations online cheaper than new
cartridges. I also purchase drum chips to extend the use of my drum
until print quality actually starts to deteriorate.
I use both of these methods to save money on supplies - buy toner and
toner chips, buy drum chip to get full use of drum unit.
Hope this helps.
Mar 19, 2012 | HP LaserJet 2840 Printer
My HP color Laserjet 2840 will not print in color
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
  • Turn on the lid of the printer and then remove the cartridge from the printer head.
  • Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
  • Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
http://www.fixya.com/support/t6065807-hp_2840_doesnt_print_in_color_prints_in
Oct 02, 2010 | HP LaserJet 2840 Printer
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
Jan 12, 2010 | HP LaserJet 2840 All-In-One Printer
For my hp color laserjet 2840
You have a bad scanner assembly. Very expensive to get fixed
Mar 02, 2009 | Office Equipment & Supplies
HP Color Laserjet 2840 refill problem
It may be that the cartridges are the problem? Usual fix is to go back to before the problem and start again. If you don't have old good cartridges, you may have to get new cartridges.
Feb 15, 2009 | HP Color LaserJet 2550n printer + HP Color...
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
HP color jet 2840 cartridge not recognize
Turn the printer off and turn it back on again and see if happens now.
Jul 12, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 2840 Printer Logo
804 people viewed this question
Seeker5211
Seeker5211
