Question about Honeywell Fan Timer Board St9120c 2010
How to switch a st9120c to a st9120b circuit board
2 Suggested Answers
  • 20 Answers
SOURCE: I am being told that I need to replace my furnace
is it working properly if so then the ancer is no if yes remove it and take it to local apliance store and have them test it thay may have a used one cheep !!!!
Posted on Feb 11, 2010
HOW TO REMOVE CIRCUIT BOARD FROM SHURE PGX2/SM58
First, unscrew the cartridge from the top. The round circuit board on top of the transmitter has a cutout on the switch side. Slide a screwdriver through that cutout and pop out the bezel the surrounds the switch. Remove the spring clip that is around the round circuit board and slide out the circuit board.
Apr 26, 2014 | Shure PGX-2 Wireless Handheld Microphone...
I need a wiring diagram to help install a Honeywell st9120c-4057 control board
SHOULD BE A WIRING DIAGRAM WITH THE NEW CONTROL THAT HAS CONVERSION CHART TELLING YOU EXACTLY HOW TO CONVERT OLD CONTROL TO NEW ONE . MUST BE LISTED ON PAPER EXACT CONTROL NUMBER IF IT DONT LIST IT YOU HAVE WRONG REPLACEMENT CONTROL BOARD.
Jan 11, 2014 | Honeywell Heating & Cooling
On my z71 1996 model rear bake lights don't work but the third light works, could it be the brake switch ?
No, it is not the brake lamp switch. If the brake lamp switch was not working, the high mount (3rd) brake lamp would also not function.
Chevrolet trucks are notorious for bad tail lamp circuit boards.
Disconnect the electrical connector from the circuit boards. Check for power at the circuit board connector (with the brake pedal depressed) on each side. The brake/turn lamp circuit for the left side is the YELLOW wire. The brake/turn lamp circuit for the right side is the GREEN wire. If there is power at the connector, check the GROUND (BLACK wires) to make sure they are getting a good ground. If the power and ground circuits are OK at the connector, replace the circuit boards.
NOTE: DORMAN makes a kit that includes circuit boards for both sides it is DORMAN Part Number 70001
If there is no power on the YELLOW and GREEN wires at the circuit board connectors, the most likely cause would be a defective turn signal switch.
Apr 28, 2012 | 1996 Chevrolet K1500
I have a Ryobi RG6900 Generator,how do i connect it from the generator to the distribution board.
I use a COBRA. It is a lead with a plug at either end. Plug one end into the generator (output) and the other into any household plug outlet. (Set to the ON position)
Before doing so ensure that no outside power can enter through your DB board (switch the Mains Switch to the "off" position) Also switch off (at the DB board) any circuits that may cause a demand of more than 21 Amps (Stove, Geyser, Swimming Pool Pump etc)
Start the 6900 and wha-la you have power to all circuits not switched off at the DB Board.
I typically leave the light circuits, one of the plug circuits (to run the TV, Decoder etc) Security Circuit,and Garage Door opener switched on.
When mains power returns First stop & disconnect the 6900, remove the COBRA and then switch on the Mains and other circuits.
Dec 29, 2011 | Motorcycles
Some of these compatible boards have a fuse, which look identical, and some don't have the fuse. Why? Is that an issue?
Circuit board assemblies are revised all of the time. The fuse may have been added to solve a problem that was cropping up - which would mean the ones with the fuse are a later revision. Or the fuse may have been removed and replaced with a jumper as a cost saving step when it became apparent that the fuse never blew anyway - which would mean the ones without the fuse are a later version. But it doesn't matter. Either board will work.
Dec 02, 2010 | Honeywell Fan Timer Board St9120c 2010
Gas valve opens and burner lights but the furnace blower does not start the blower will run in the on position. controlboard is a honeywell st9120c
Here is the specs for your board
http://customer.honeywell.com/techlit/pdf/PackedLit/69-0781.pdf
Check the wiring to be sure you're getting all the inputs and proper timer settings.
It could be bad. (sometimes the fan relay goes bad)
Oct 28, 2010 | Honeywell Fan Timer Board St9120c 2010
I am being told that I need to replace my furnace circuit board (Honeywell ST9120C 4016). I just replaced it 2 yrs. ago. Any ideas? If it needs to be replaced, where can I purchase it?
Feb 10, 2010 | Honeywell Fan Timer Board St9120c 2010
I have a honeywell st9120c 5013 heating unit that i want my new digital thermostat to allow the fan only to come on (no heat just fan) can it be done?
yes,that model should have a slide button for fan on/auto.that is assuming your furnace is a fairly modern unit.
Aug 18, 2009 | Heating & Cooling
Open Questions:
See all Honeywell Fan Timer Board St9120c 2010 Questions
Honeywell Fan Timer Board St9120c 2010 Logo
51 people viewed this question
Top Honeywell Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Honeywell Hardware and Accessory Expert? Answer questions, earn points and help others
