Acer aspire 4738 won't power on - Computers & Internet
  • 2567 Answers
SOURCE: my acer aspire 4738 when
If you connect the external monitor & nothing is displayed on it, then this means that both the backlight lamp & the inverter board are fine. The main indicators in these cases are the sound, and the hard drive LED on the laptop case. If the laptop sounds just like it always does for a minute or two after being turned on, it means it's going ahead and booting the operating system, but the video processor or part of the motherboard circuit for video output has failed. If the laptop just sits there and beeps when you turn it on, or if you hear the fan but not the hard drive chuckling with its active LED flashing away, it means the laptop isn't getting as far as trying to boot the operating system. While this could be due to any number of hardware problems, the most common and easiest to
troubleshoot or repair is RAM failure. If your laptop has two RAM modules installed, try booting with just one and then the other in the primary slot. If your laptop only has one RAM module, you might consider buying one online from a site with a good memory selector, like Crucial.com.
Posted on Oct 23, 2010
  • 31 Answers
SOURCE: Acer Aspire 5538 Won't power
It sounds like your computer's charging port is disconnected from the motherboard. The charging port cable probably has to be re-soldered to the motherboard to be fixed. If you are not skilled in computer hardware repair-ale I would suggest going to a computer technician.
Posted on May 13, 2011
djromann
  • 158 Answers
SOURCE: Acer Aspire One won't turn
You probably get damaged the charging connector, or it is simple dissoldered from the mainboard, thats a very common problem. Check first if it turns on with another fully charged battery. If yes, you should resold the charging connector.
Posted on May 14, 2011
  • 11800 Answers
SOURCE: My Acer Aspire One Netbook
Massive hardware failure on the motherboard - the netbook will have to be opened and its components tested by a repair shop. Take it to one.
Posted on Jun 05, 2011
SOURCE: is bluetooth available in acer aspire 4738?
hold fn then press f3 then drag the off button to on
Hope It Helps!!!
Posted on Aug 26, 2011
Does acer aspire 4738z have wi-fi inbuilt ?
yes its certified WiFi, check in system hardware manager to see if the WiFi is installed correctly, if so see the manufacturers manual available online.
Jan 28, 2014 | LotFancy Lotcy Black keyboard for Acer...
Acer aspire 4738z
Boot with a Win 7 installation disc then choose repair.
Oct 30, 2012 | Acer Genuine Adapter Charger Aspire...
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
Laptop Model ACER ASPIRE 4738 Change operating system Linux To Windows Xp How Can i Do it
YOU NEED TO FORMAT YOUR HDD TO FAT OR NTFS FILE SYSTEM ON THE PARTITION YOU WANT TO INSTALL THE OS. USE ONE OF THE MANY DISK UTILITY SOFTWARE TO DO IT.
REGARDS.
PLZ. DON'T FORGET TO RATE THIS COMMENT
Jul 07, 2011 | Computers & Internet
Driver for Acer 4738 series for XP
Acer stop supporting the Aspire 4738 Series for Windows XP. They currently only support and host the drivers for Windows 7.
However, I was able to find a copy of the older Windows XP drivers for your laptop, which are located here: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 23, 2011 | Computers & Internet
My younger brother (12 yrs old) accidentally removed the driver for the wifi of my acer aspire 4738. Then I tried to reinstall the driver with the cd that came with the laptop. Nothing happened. It...
Reinstall all drivers and applications using Acer eRecovery by following these steps:>
  1. Click Start, and then All Programs
  2. Click Acer, and then Acer eRecovery Management
  3. You may be prompted to enter or create a password. This password will be required to use eRecovery in the future.
  4. In the next window on the left toolbar, select Restore.
  5. Choose Reinstall Drivers or Applications
  6. Choose Contents
  7. Choose the driver or application you wish to install
  8. On the right, click the Install link and follow the prompts.
  9. The computer may restart when installation is complete. If it does not restart, manually shutdown and restart the computer.
Or you can restore your pc to an earlier point of time ..->windows.microsoft.com/en-US/windows7/products/features/system-restore
May 12, 2011 | Computers & Internet
Is bluetooth available in acer aspire 4738?
Hope It Helps!!!
Nov 11, 2010 | Acer Computers & Internet
Why dont open web camara windos xp acer 4740
download acer's webcam driver from the following link, and choose your acer's laptop brand.
http://support.acer-euro.com/drivers/downloads_gd.html
Aug 11, 2010 | Acer Aspire 4720 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
