How can we adjust the Element TV ELEFW327 screen image size?
The screen cuts off the sides of the image so text along the edges can't be seen. Both sides of the screen are cut off even in wide mode.
  • 116 Answers
SOURCE: Picture cut off Screen on Tube TV
Is the extra width problem something new or has the condition always been there? If it is something new, probably the power supply regulator has failed causing overvoltage to the tv.
Posted on Mar 01, 2008
SOURCE: Zoomed screen on my TV
with remote control use Zoom boton, or enter to menu and seek for this option.
Posted on Oct 23, 2008
SOURCE: Picture on Telefunken 72 cm TV expands beyond screen size
Your screen somehow got switched to theatre/cinema mode. There is a setting on the remote that attributes to aspect ratio. Sometimes it is called "ASPECT". Look for it, and press it until your original screen aspect shows.
Posted on Dec 16, 2008
  • 12 Answers
SOURCE: need help adjusting the screen size on a Sony Trinitron KV-32FS13
try to adjust the yolk away from the picture tube
Posted on Jan 13, 2009
t5mustang
  • 3 Answers
SOURCE: RCA HD27F754T picture color and screen size.
check your hook ups, sounds like you have a component hook up conected to a composite jack.
Posted on Mar 09, 2009
Tip
Replacing CR1620 lithium battery for Ultramax OB24
For consumers with the Brita Ultramax (OB24), the one with a digital memo. Here's how you can modify the battery housing for replacement.
Important: It is best to take pictures along the way so you know where the parts go during re-assembly.
I attached photos along on bottom of page for easy viewing.
1.) Remove the battery housing unit from the cover. It is easier if you unclip the small cover off from the larger (main) cover to do this. Carefully pry along the edges with a butter knife until the housing is raised up enough for you to pull if off with your fingers.
2.) Turn the housing upside-down (LCD reader faced down). Now carefully cut/slicing along the topside outer edges of the battery unit with a razor blade. Make sure it is cut evenly so that it can be reused as a 'cover'.
3.) After it is cut and exposed, tap the internals out of the clear plastic housing so you can get access to the battery. Stick something thin (such as the newly cut plastic cover) through the battery lever and push the CR1620 battery out. Replace battery, put everything back into its plastic housing.
4. After everything is reassembled with its new battery, put the (cut) plastic cover piece back, hold gently and wrap some clear packing tape such as 3M. You'll have to measure the tapes and cut them to fit. Secure the top portions with tape, then wrap along the sides to secure the rests.
on Oct 28, 2014 | Brita 35530 UltraMax Digital Water...
I'm needing to make a series of kerf cuts on a 12' wide plywood piece in order to bend it in a 15" arc. My problem is the kerf cut is deeper in the back of the board than the front.
It is important for even cuts that the board is fixtured properly. I would secure the plywood to a second board that is flat stiff and strong. A table top that is not warped may work OK. This will prevent the plywood from bending from the weight of the saw.
Use a scrap piece of material at the exact thickness of the plywood to allow the saw to cut through the width of the plywood .
You need to cut past the back edge to ensure the kerf depth is consistent.
If you cannot hold the saw flat and steady you may also need a lead in piece so the saw is flat and square before beginning the cut into the 12 inch wide plywood.
I would use a fence along the side of the saw as a guide relocating after each cut.
Dec 23, 2015 | Saws
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
The picture is outside the edges of the TV
It's probably an issue of the "Aspect" or the "Screen Mode" you're in. I'm no TV repair expert, but if you look in your Main Menu for "Screen Mode" or even your remote might have a button labeled "Asp" or "Aspect" or "Mode"....or even "Wide" (which when pressed repeatedly will cycle through the most common 4 screen modes = Wide, Screen Fit, Zoom, 4:3.) The last one refers to the ratio aspect, but depending on your TV, they could be named differently.
Given your description, it seems you're in "Zoom" mode, since it's cutting off the edges of the picture. Put it on a station like CNN, which has a streaming ticker at the bottom and cycle through the options you have until you find the one you prefer. (Note: you should also be able to set this in your Main Menu somewhere as your preferred view, but some shows and movies might come through as full screen or 'Letterbox' regardless of your preference.
One final observation I've found on several units is that the remote button that's in the bottom right-hand corner (which may not be labeled as such) is the default location for your aspect selections. Push it and see what happens.
Jul 22, 2012 | Philips 47PFL7403D 47 in. LCD TV
How i adjust horizontal size and vertical size
To answer your concern, all you have to do is to change the setting of your aspect ratio on your TV.
Here is my suggested way to procede:
1. Apply 1080i signal, which should produce an oversized HD image on ColorStream1or 2.
2. Select an HD channel that is broadcasting standard 4:3 image, not wide screen.
3. Switch to the Service Mode ( Please refer to the above links). In the Service mode, press channel up/down to find the Adjustment parameters needed for the following steps.
4. Adjust HIT with volume up/down control for the image height to 22.5 inches.
6. Adjust WID for image width of 30 inches, (22.5*4/3)
7. Adjust HPOS to center the image.
8. Adjust PARA and TRAP to minimize geometric distortion.
9. Switch into Convergence mode and Adjust VLIN to get equally spaced horizontal grid lines.
10. Measure the length of the central grid lines and note the number of horizontal and vertical grid lines. This information is used to create an overlay grid.
11. Create the overlay grid on 40x25 x0.003 inch clear Acetate sheet, which you can get at the Art Supply store for under $2. Draw the grid with a fine line erasable pen. Draw vertical and horizontal lines through the center of the sheet so that the lengths are the same as the central grid lines. Now draw the grid so that it has the same number of lines as the convergence grid but are equally spaced, with the outer ones at the ends of the central lines.
12. Cut off about 1/4 inch from the right side of the sheet so that the sheet can lay flat against the screen, which is slightly less than 40 inches.
13. Put a reference mark on the TV frame 2.5 inches down from the upper left side of the screen.
14. Place the overlay on the screen so that the upper edge lines up with the reference mark. The overlay sticks by electrostatic attraction.
15. Use convergence controls to remove grid distortion and converge grid colors. Refer to the Anamorphic link for details.
16. Enjoy 1080i.
Other Comments:
I didn't realize I could create the overlay grid before placing the Acetate sheet on the TV screen, until I finished drawing the grid with the sheet placed on the screen. I added grid lines as called for in the procedure. I'm sure this method took much longer no only to draw the lines but some of them were difficult to see.
Part way through the convergence procedure, I became concerned that the image width was off since I did my screen adjustment with wide screen image. Thus, I decided to repeat that step with a 4:3 screen.
I confirmed the need to press 7 often to save results since after I adjusted one grid color without it, I accidentally hit a key that switched me out of convergence mode and when I switched back, all settings were gone.
Another mistake I made was not realizing that the cursor color determines which grid gets moved.
May 13, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
I have a toshiba 39"
On the TV remote there will be a button labeled ASPET or PICTURE SIZE or RATIO or ZOOM. Press that button while pointing the remote at the TV. Press it repeatedly until the desired picture size is acheaved. Not the cable remote but the remote that came with the TV.
Dec 26, 2010 | Televison & Video
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
