RCA tv with FiOs
I do not have a remote for the RCA tv I'm using. I only have the Verizon FiOs remote. Someone hit the channel button on the tv and now I can't turn it on without it being snowy. The tv is normally set on channel 00. I can't put it on channel 00. the FiOs remote's number buttons won't work in tv mode. Can you please help me fix this?
My fiance fixed it. he has this really expensive remote that he programmed via a USB port and some fancy fingerwork that I can't even begin to explain :D and I was able to change the channel back to 00
Posted on Jan 21, 2009
What is the Brand Code for this TV?
The brand code should be listed in the Verizon FIOS remote user guide.
Jul 30, 2014 | RCA Televison & Video
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
Cannot program Verizon FIOS remote with RCA L32HD31 32 in. HDTV LCD TV, none of the codes work. Can you assist?
Talk to Verizon,should not require code because u using verizon remote on verzon box.
Jan 15, 2010 | RCA L32HD31 32 in. LCD HDTV
No codes for remote verizon fios control of tv came with tv or are listed for RC1445 302/oob manual
for my tru-tech i used the auto code finder on the Fios remote instructions it didn t take very long, I can t say the same for my memorex tv though.
May 10, 2009 | TruTech PLV1615T 15 in. LCD Television
Do we have to manually set the pix set key for every station/show we watch? We loose scrolling writing at the top and bottom of the screen on my dad's new 32" lcd tv bought at Wal-mart. When we set...
Thanks for the offer but we cannot afford to pay additional money for something the Factory support service Should provide.
From what we have heard through the Verizon installer, our SANYO LCD TV probably does NOT have a Automatic picture adjust system. That would most likely be the reason for the maunual button on the remote control. The troublle is that with the FIOS service, you do NOT use the TV's remote control. That leaves to switching back and forth between two different remotes wiich can be vary confusing for someone that is not 88 years old.
It is bad enough that you have to remember which channels you have to go to to receive HD programming signals. If I were making a TV set, and or running a TV network/ cable service, I would transmit both HD and regular signals on the same channel number and let the TV and or the decoder box figure out if my set could display High Definition. Isn't that what we spend lots of money buying equipment and paying each month for service?
If anyone out there knows if the SANYO 32 inch LCD TV sold at Wal-Mart automatically adjust to the picute format, (PIX 1-4) we sure ould like to hear from you.
Jul 23, 2008 | Televison & Video
Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Apr 30, 2008 | Samsung HP-S5053 Television
Can you help me?
go to verizon.com and look up fios tv and then from there go to installation and then troubleshooting
Apr 09, 2008 | RCA F27625 27" TV
FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
