Question about Samsung HLN617W 61" Rear Projection HDTV
No picture or sound!
When I turn on the t.v. the cooling fans come on and the lamp light flashes green. After several times, all three lights in front flash. The lamp looks great and the color wheel spins. What else could it be?
  • 4 more comments
  • john hrouda Jun 29, 2007
    Bulb looks good.
    How do I test the ballast?
  • john hrouda Jul 03, 2007
    I hear a click as if starting the bulb.
    Is there a way to test the bulb or the output to the bulb?
    There is some dust on the components. Could this have anything to do with it?
  • john hrouda Jul 04, 2007
    I have ordered a new bulb. I will keep you posted if it worked.
  • john hrouda Jul 05, 2007
    I replaced the bulb and still no picture!
    There is still a click as if the bulb is trying to start, but no light.
    The voltage to the ballast seems fine.
    I am now ordering a new ballast!
    I hope this is it as far as parts.
    I am over $320 already!
    Will keep you posted.
  • john hrouda Jul 18, 2007
    It was the ballast board!
    Thanks!
    President:
  • 3,130 Answers
The bulb is bad my friend, even if it looks good, the flashing light is the first indication. You should get the original lamp from here http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96%2D00224B Good Luck
Posted on Jul 03, 2007
  • Larry  Dillon
    Larry Dillon Jul 03, 2007
    Oh also the click, like if the bulb is starting is an indication that the bulb wants to start but it cannot.
  • Larry  Dillon
    Larry Dillon Jul 05, 2007
    Get the service manual and measure the voltage on the ballist, if the voltage are good replace the ballist http://www.samsungparts.com/part_detail....
SOURCE:
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
Sxrd 50 won't turn on - Cooling system or dlp lamp?
4 blinks is a fan error, check and see if the fans are clogged with dirt. Unplug the set then take the back off and get some canned air and blow the fans out.
Oct 08, 2009 | Sony KDSR50XBR1 50" Projection HDTV
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Good sound, no picture, green standy light flashing
Replace the lamp-mine just went out also and sony told that I just need to replace the lamp---after a while the lamp indicator light will turn on red if and blink if this is your problem....also note to make sure it is your lamp unplug your tv from the wall or surge protector for atleast a minute or 2 and then replug it back in and see if the lamp light blinks red? If it doesn't then you got something else wrong. I hope this helps...if you need further assistance contact sony online via chat at sony.com and they'll help you fix the problem in no time. Take care
Mar 30, 2009 | Sony XL-2100U Projector Lamp for...
Sony Grand Wega 55" LCD ml # KDF-55WF655 goes protective shutdown
This is the lamp going bad. For some reason, it doesn't spit out that lamp error, it just keeps refiring the lamp and it just cycles forever. When the lamp totally fails, you will get the lamp led lit. Replace the lamp to resolve.
Dec 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Samsung HLN617W 61" Rear Projection HDTV Logo
120 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
