Question about Maytag Neptune MAH5500B Front Load Washer
DOOR WILL NOT OPEN ON NEPTUNE WASHER
WIFE STARTED A LOAD, THEN SIGNAL WENT OFF AND WASHER STOPPED. TURNED WASHER OFF THEN ON AGAIN. PUMP STARTED AND RAN ABOUT 10 SEC, THEN WASHER FILLED FOR ABOUT 10 SEC AND STOPPED. DOOR WILL NOT OPEN.
  • Maytag Master
  • 19,396 Answers
This guys do not have a clue.
Complete the cycle by turning the timer up to the end.
Unplug dishwasher again, empty waterinside, check the drain hose, ensure water is coming from water supply.
Plug back dishwasher cord and perform the following reset, you may need to do it a couple of times.
Press Delay/Resume button once then the Drain/Off button twice. You may need to hold buttons for a couple of seconds.
The display will reset and restart working.
If the above does not work, that means that there is a n internal fault, in that case call a technician.
Posted on Jan 20, 2009
    Master:
  • 416 Answers
It might be problem with cold water supply, the cycle simply can not advance. Since it start running you can not open the dooor. To open the door you need to unplug the machine to clear the memory. End check cold water line.
Good Luck
  • Grigory Zyryanov Jan 20, 2009
    My dear friend Ginko.
    Lets respect each other. Even though you are the professional and Guru. That is not the reason to for doubting the suggestions of other people. Simply give the answer without any comments. There is one term you might be forgot about "professional ethics".
    If you fogget about it follow the link
    http://en.wikipedia.org/wiki/Professiona...
    Let us follow this. By the way your answer looks very similar to mine just more detailed one.
    Best regards
    Genius:
  • 1,550 Answers
Likely failure is a broken door switch plunger. Open the door. On the right side of the drum opening, you will see 2 screws above the door latch. Just above the top screw (at about the 2 o'clock position), you should see a plunger that detects when the door is closed. It should push in and spring back out. You may find this plunger broken. If so, you will need to replace the door latch assembly.
It starts to spin slow then quits.
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The lights go on, but washer will not start.
door not closed try open door and then closing again
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Leaking From the Door
possibly door lock not latching could be a bad wax mtr (within door lock asm) or control board
Dec 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune Dryer
the belt needs to be replaced. open the front of the dryer, remove the bulkhead and install belt. or call your service guy and have him do it
Sep 04, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Neptune washer front load may4000awq
Check your washer belt has not slipped off.
Just so you know thats not the problem.. Ours went ga ga and it was only the belt!
:o)
Aug 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune front loader
Check the belt is still on the wheel.. may have slipped off. Take top of washer off and you will be able to see if its ok.
:o)
Aug 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag top load neptune washer error code od
I own a maytag neptune, top load washer with electronic board or lcd screen, od code display, those are the door switches locates on the side of the door, the switches are electronic, an after opening the washer an opening the switches I discovered that the wire that sends the signal from the switches to the board were broken an rotted from the mold an soap that got accumulated in the switch, I took the switch an cleaned all the electric contacts, an stripped the wire back to were the wire was in good shape an re-solder the wire back to the switch, assembled back together an had the error went away ( no need to do anything else), the switches are attach to the machine with a 1/4 in screws , if you are not handy with soldering wires, you can order the part, ask for the lid switch give them your model number an I think they run about 75 dollars each, time to change em if ur a newbie, maybe an hour , I can do it in maybe 20 mins tops!
try it hope it works for you!,,,,,,
new washer 600
new parts 150
making a wife happy...............priceless!
good luck! let me know.
Apr 19, 2008 | Maytag LAT3600A Top Load Washer
Neptune washer not starting
open panel at rear of control panel usning phillips head and 5/16 the board attached to that panel will probably have a burnt r14 r1 or r21 resistor. this has been an ongoing problem with this model even a class action lawsuit.(lawsuit expired 9/2005) you can change the board but this will eventually happen again maytag directs you to do a full conversion kit rebuild about $400.
Feb 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Won't wash
also the wax motor and microswitch in the door lock can do it
Feb 10, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
18 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
