I have av-502a konzert amplifier may i know the voltage of output relay because is relay to burn
4 Suggested Answers
alxz
  • 89 Answers
SOURCE: I have a konzert amplifier av-502 that has two
Is it the resistors near the relay? that would be 10 ohms. You may replace it with a higher wattage (like say 5 watts)
Posted on Oct 05, 2010
jdvillanueva
  • 2098 Answers
SOURCE: how can i upgrade my av 302 to becomes best as
upgrade your 302 to 502 need to replaced the toroid transformer, set of output amplifier, set of electrolytic capacitor.
Purchasing of these parts one-by-one is much expensive rather that you buy a brad new Konzert AV-502. Also upgrading the unit is quite tech and need a lot of experienced in electronics.
Hope that it may help you.
Have a nice day.
JDVillanueva
Posted on Jan 31, 2011
  • 8 Answers
SOURCE: Got a crown amplifier XLS 602 its powering up the relays are clicking, all voltages seems ok the signal led's are on but there's no sound output on both channels. I manage to trace the signal
Check your input or output cables might be dirty I had the same problem
and 1 of my output wire was dirty so i sprayed tha electric cleaner and its all good now
Aloha
Posted on May 21, 2012
Konzert amplifier av 302
200 watts is the output, home use or commercial? not a good amp to run at its max as it has a low reserve headroom. for home use 100 watts rms is more than enough.
Mar 08, 2014 | Audio Players & Recorders
Konzert model AV 502A
Disconnect the speakers, all of them. If the fuse continues blowing off, you have a short circuit in the final stage of the device, called the amplification circuit. If the does not blow , then the short circuit in is one or more speakers.
Jan 18, 2014 | Audio Players & Recorders
Black diagram of av-502a
front: 500 watts/channel
surround: 30 watts/channel
center: 30 watts
Jun 22, 2013 | Audio Players & Recorders
KONZERT AV-502A KARAOKE AMPLIFIER,POOR AUDIO,2-RESISTOR WORN OUT PLS. HELP ME
pls check burnt resistors, if ceramic it's value is .25 0hms 5 watts, if big carbon film resistor it's value is 10 ohms 3 watts. check also power transistors A1941 & C5198. also check driver transistor A940 & C2073
Jan 06, 2013 | Car Audio & Video
What is the specs of konzert av-502 amplifier
input voltage: 220vac
500 watts /channel
5 channel output
pro logic surround decoder
single output digital delay
w/ karaoke function
Aug 08, 2011 | Car Audio & Video
How can i upgrade my av 302 to becomes best as konzert av-502
Have a nice day.
JDVillanueva
Jan 31, 2011 | Audio Players & Recorders
79 people viewed this question
 Grubhead
Grubhead
