Question about Canon PowerShot SD600 Digital Camera
Canon powershot sd600 won't focus - Canon PowerShot SD600 Digital Camera
t00nz
  • 4738 Answers
SOURCE: Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 28, 2009
rajak2009
  • 527 Answers
Sir,
The problem seems that miniscule dust/sand particles jam the gears which moves the lens.
It is possible to turn the lens motor by hand bit by bit and remove particles stuck in the gear.
Also try restoring the factory settings and resetting the camera and seeing if that makes the error to go away. To do that, hold down the Menu button for five seconds. This should reset everything and (hopefully) make the error stop. If it doesn't, then you've got a separate problem-- come back and let us know if the error is still there. Also, if you have photos stored on the camera's internal memory, resetting the camera will delete those so make sure to download them first.
Thanks
Posted on Aug 07, 2009
SOURCE: My Canon PowerShot SD1000 won't focus. Most
View is not get displaying in the screen when i select other than Easy mode.If i select auto mode it is displaying only the black screen.Any idea why it is like this?
Posted on Jun 02, 2010
  • 178 Answers
SOURCE: Canon sd 600 auto focus is not working
You should first check if the Lens of the Canon PowerShot SD630 Camera is clean,then check if it is the GPU problem.
Posted on Sep 21, 2010
  • 102366 Answers
SOURCE: my canon powershot sd600 says card locked. Why did
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Sep 28, 2010
Testimonial: "Thank you very much. "
Canon powershot sd790 won't focus
There is probably dirt in the camera that restricts operation, the other concern is damaged gears, camera is trying to focus.
Mar 19, 2012 | Canon PowerShot SD790 IS/ IXUS 90 IS...
I need a manual for canon SD600
You can find it in this link:
Canon SD600
Scroll down and click Guides and Manuals, then click the download icon beside the user's manual.
Oct 25, 2011 | Canon PowerShot SD600 Digital Camera
I have a Canon PowerShot SD600 Digital Camera. The battery has a full charge but the camera will not power up. I press on and nothing happens. What do you recomend?Best RegardsNeil
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 02, 2011 | Canon PowerShot SD600 Digital Camera
My Cannon SD600 Lens Power Shot is suddenly taking blurry photos. Why?
you have to wait for it to focus. a green or red light (depends on your model) will appear and it will go away when focused.
Jul 31, 2011 | Canon PowerShot SD600 Digital Camera
I have a new sd600 canon powershot.It doesn't have the software.Do i need software to upload pics in my pc with windows xp? I tried without the software but i didn't get any connection.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jul 09, 2011 | Canon PowerShot SD600 Digital Camera
PowerShot SD600 will not focus
If the camera was open (lens extracted) the camera lens may be damaged. If you can retract it (power off), then maybe it's just dirty. Can you zoom in or out?
Jul 26, 2008 | Canon PowerShot SD600 Digital Camera
Jul 22, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD600 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
