WHIRLPOOL AWM8121 WATERVALVE PLEASE - Washing Machines
    Sergeant:
  • 291 Answers
Http://www.whirlpoolparts.co.uk/?searchStr=AWM8121/S&_a=viewCat&Submit=Go
Posted on Jan 07, 2013
  • joanne wyatt Jan 07, 2013
    thankyou for your help im not sure where the watervalve is located.all the pipes are clear of bebri i had them off the other day after doing the dogs blankets it clogs them up but once i did that it now wont take in water.
  • B.H. Countryman Jan 07, 2013
    Oh i see. The watervalve is the thing the hoses behind the washer hook up to. Check that the hoses aren't kinked or restricted in any way. If you see no problem turn off the supply valve (the valve that came with the house) and remove the hose from the back of the machine (from the watervalve on the machine.) There are screens in the ends of the watervalve than can become clogged with debris. Use a toothbrush or spray bottle to flush the debris from the screens. Be careful reattaching the hose to valve. And consider replacing the washer in the end of supply hoses before reattaching. Screw the hose end to the valve hand tight then 1/4 turn more with pliers. Do not overtighten, do not use teflon tape and do not crossthread. Turn supply line valve back on. Check for leaks. Test washer.
Where to put washing detergent in Whirlpool AWM8121?
Simply place detergent into wash ball and place inside drum on top of clothes,,,,fabric softener goes in smallest compartment in tray
Jun 20, 2013 | Whirlpool Washing Machines
Whirlpool AWM8121 says Door is open and will not wash. Is it Microswitch of something else.
Let'[s hope that is it.
These switches are made of plastic, and are really cheap.
It should be fastened with screws to the inside of the top of the machine, which you will need to open to access.
Be blessed.
Apr 20, 2013 | Whirlpool Washing Machines
Water supply isnt getting to the ice maker .
HI welcome to fix-ya. Sounds like bad watervalve with a frozen filltube. Try using a hairdryer to thaw the tube that the water enters icemaker. Then replace watervalve. I take it you can get water out of the door and the filter is ok. This can also cause the problem. I hope this helps.
Sep 08, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
No spin cycle
have you tried unblocking the inlet and outlet pipes under the drum
Apr 25, 2009 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM8121 stops working mid cycle. Bottom two lights flashing on spin speeds.
Fault code 3 = Drain failure or not detecting empty drum.
Check pressure switch, blocked drain, drain pump.
See link below for service manual.
http://www.user-manuals.com/advanced_search_result.php?keywords=857081253000&forward=plist
Oct 24, 2008 | Whirlpool AWM6120 Front Load Washer
I have a Whirlpool front loading washing machine (model AWM8121). We keep getting sporadic bleach marks on our towels and clothing when we take them out of the washing machine. Any idea what might be...
try removing dispenser drawer completely and cleaning thoroughly there may a buildup in drawer preventing the bleach from completely dispensing properly at the proper time ..press tab down on left rear corner to completely remove entire assembly
Aug 19, 2008 | Whirlpool Washing Machines
Bearing replacement
hi there,
just wondered if you found a solution.
thanks
Jul 28, 2008 | Whirlpool AWM6120 Front Load Washer
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
