Question about Siemens HG2415UC Stainless Steel Gas Kitchen Range
Error 43 buzzer goes off door locks error 43 shows-up on pannel
2 Suggested Answers
  • 2069 Answers
SOURCE: I have the mag tron
Error Code 43 Cause: Upper (or single) oven motorized latch will not unlock; Defective or jammed upper oven door or latch switches; Defective latch motor or its wiring.
solution:
1.Check connector on the power board.
2.Ensure door latch switches are operating properly.
3.Check that neither latch switch nor common wires are
pinched to the appliance chassis.
4.check if latch motor wire is pinched to the appliance chassis.
5.If 43 persists, replace power board
Posted on Oct 22, 2010
My machine shows F:43 . What is the problem?
try to run test program if it won't help - service. F:43 is a fatal error. it could be short-circuit rotor broken engine etc...
it won't dissapear on it's own.
Oct 20, 2015 | Washing Machines
Reason for door codes on a frigdaire front load dryer
Your door lock my be defective and need replacing. It has to send an input to the computer otherwise a door error will display
Mar 03, 2015 | Frigidaire Affinity FAQE7011LW Electric...
Door alarm buzzer goes off inadvertantly
in the door jam you should find the button for the buzzer some of these are adjustable the button might not be getting push in all the way if this doesnt fix the problem I would find that stupid buzzer and rip it out
Jan 25, 2013 | 1998 Ford Windstar
Megane door lock buzzer
We do not have this make in the USA so have no info on it. Sorry
Jun 16, 2012 | Cars & Trucks
In the middle of self cleaning, the oven is giving us an error message that says "F2" and locked door. I buzzer continually goes off. What does this mean and what should we do about it?
900 degree oven does a number on electronics: overheat situation.
Bottom line: never do a self clean unless you have the money to buy new controls.
Dec 12, 2010 | Kenmore Ovens
Power door locks are not working nor keyless remote access. Fuses in the fuse box are ok.
the master door lock/wndow swtch is bad this is the switch pannel in the drivers door.if this goes bad it wont work for the locks in any door or with keyless entry
Feb 09, 2010 | 2002 Mercury Grand Marquis
We have a Kenmore front loading washer, model 417. We are getting a door open error code even with the door closed. Any suggestions?
This could be one of two things. The actual door lock assembly there is something malfunctioning with the part that the striker goes into or that the control pannel is not registering that the door lock is actually closed. One is a $60 fix (the door lock) and the other is approx ($250). Unfortunatly because they are both electronic parts you can't just buy the cheap one put it in and if it doesn't work return it. Most stores have a no return policy on electronics/electrical parts.
Oct 03, 2009 | Kenmore Washing Machines
F-9 warning with buzzer
try unplugging for a few hours. If this does not correct the problem which it should, make sure the door latch is releasing and latching when door opens and closes.
also make sure door is locked before turning to clean.
Mar 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Whirlpool Electric Oven RBS305 overheats while baking, locks door
The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
Good luck
Dec 18, 2008 | Kitchen Ranges
Open door alarm on VW Jetta
You probably have a bad microswitch in the door latch assembly. It lets the computer know if the doors are open or not.
Dec 10, 2008 | 2004 Volkswagen Jetta
Siemens HG2415UC Stainless Steel Gas Kitchen Range Logo
53 people viewed this question
Top Siemens Kitchen Ranges Experts
Timllfixit
Bill Boyd
rpar
Are you a Siemens Kitchen Range Expert? Answer questions, earn points and help others
