Question about Kenmore HE2 Plus Front Load Washer
Water is pouring from the dispenser drawer, how do I fix this
I cleaned dain at the bottom of washer and it did fine for 3 loads and on the 4th load started pouring water again
    Sergeant:
  • 291 Answers
First check the drain hose behind the machine. It must not enter more than 4" to prevent siphoning situation. If that looks okay check for a sock or similar item between basket and tub. They seem to like to stick close to the dispenser drawer when they get in there and often cause the symptom you are describing. Make sure to check the drain hose between tub and drain pump for objects. When checking pump basket, stick a finger in and feel around the propeller of the pump. If it feels at all wobbly or bent to one side the pump may need to be replaced. If that doesn't solve your problem you may want to check this video:
http://www.youtube.com/watch?v=SFEQsJ-vLxw
It's a bit more involved and i about went to sleep listening to the guy but he's informative.
Good Luck.
Posted on Jan 07, 2013
watugot
  • 290 Answers
SOURCE: Kenmore HE3 Front Load Washer
Remove the dipenser and feel down inside the hole. You will probably feel a detergent build up in the cavity. If so clean this out and rinse with hot water. This problem is becoming more common since people are washing more in cold water to save electricty. Some detergents and fabric softeners will not disolve in cold and it "gums" up the works. Post back to let me know what you find.
Posted on Oct 09, 2007
  • 1028 Answers
SOURCE: washer
remove dispenser drawer with rag and bleach water mix wash as good as you can the top of dispenser housing aroud holes to remove build up ..if problem is still there entire assembly will need to be removed and flushed thoroughly build up is blocking the holes over the dispenser cups
Posted on Jun 02, 2008
SOURCE: kenmore he 2 plus front loading washer
Solution for clogged soap dispenser on Kenmore He2. If you open the door and slightly pull the gray rubber seal away from the drum, at the 10:00 position, you can see if there is an item blocking the inside soap despenser drain pipe. I had a sock stuck in there and I gently used two fingers (one from each hand) to grab the lodged item and pull it out. It no longer looked like a sock, but a torn up washcloth. If this solves your problem, I highly recommend using a mesh laundry bag to wash anything smaller than a washcloth. Socks (all socks, not just a baby's socks), thongs, etc have all gotten stuck in the soap despenser drain and in the water outlet drain filter. They are too torn to be used again, of course but it answers the age-old question of "where did all the matching socks go!"
What I recommend to anyone who has this washer to do their regular cleaning cycle. After you do this, check both drains, the grey rubber seal, etc for anything that may have gotten in here. If you use the mesh bags for anything smaller than a shirt and pants, you will find that the clogged draining problems will happen with less frequency.
Also, before doing expensive repairs, take an hour or two to search the web and see if you can figure out (from customers before you) how to fix these chronic problems. If there is still a problem you can't fix and HAVE to call a repairman, watch the repairman fix the problem so you know how to fix it next time. Not only that but you can tell us what the repairman did so those that have the problem after you, have a way to fix the "simple" fixes.
Posted on Dec 08, 2008
  • 14 Answers
SOURCE: water pouring out of detergent dispenser drawer
There is a rubber hose that connects dispenser housing to outer tub of washer. Disconnect hose at outer tub and fish out article of clothing that has wedged itself in there cuasing water to back up and pour out of dispenser. In the future use a linen bag for small articles of clothing such as underwear and socks.
Posted on Jan 02, 2009
Jahn27
  • 1554 Answers
SOURCE: My Kenmore front-loading washer - As soon as I
The washer will not start the wash cycle when there's no enough water inside the tub. The washer will flash an error code if it has a display or light up a status indicator to indicate the fault code depending on the model number of the washer. Please specify the model number of the washer for more specific advice. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Regarding the leak problem, a broken drain pump usually causes the problem; to check, remove the screws attaching the bottom of the lower front access panel to the cabinet. Once the screws are removed, slide the panel down then out to remove it from the cabinet. Fill the washer with water and locate the leaking part.
Also remove the top panel by remove the screws attaching it to the rear of the washer then slide it rearward and lift it off the washer. Check dispenser hoses for any leak during the fill cycle.
Specify the model number of the washer and let us know the source of the leak for further and specific advice.
Posted on Apr 10, 2010
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
    Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
    Apr 17, 2010 | Samsung WF203ANW Front Load Washer
    Whirlpool duet washer leaking/pouring water out of soap dispenser
    You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
    Pull the dispenser drawer completely out.
    There is a tab that needs to be depressed to release the drawer and remove it.
    Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
    Reach down into this opening to see if an item is inside the hose.
    Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
    Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore 11047511701 Front Load clothes washer: Liquid detergent runs out of dispenser and down front of machine immediately as liquid is poured in instead of holding liquid. Dispenser was not overfilled.
    http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
    Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
    Water Pools Up in the Fabric Softener Area
    have you dis assembled the dispenser drawer and cleaned out the sections. the top covers slide off their areas standpipe.
    May 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Can i adjust the water level on my Duet?
    Sorry there is no way to adjust the water level. the washer decides how much water by how much clothes are in the washer .
    Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Water pouring out of detergent dispenser drawer
    Dec 31, 2008 | Kenmore 46462 Front Load Washer
    Maytag Neptune Washer dispenser unit has mold and mildew inside top of dispenser compartment.
    You can pour the bleach in the drawer every time you do white loads and it will stay clear too!
    Just flush it out good before you do colored clothes or you may get a small bleach spot on a red shirt !
    Neil
    Ps. Give me a problem solved rating here on fixya.com
    Aug 19, 2008 | Maytag MAH6700AWW Neptune Front-Load...
    Water is leaking out of detergent dispenser- big time
    Water pressure may be too high,try turning the cold water feed pipe (usually the blue one)down a little,not too much though.If this does not solve it,is the machine lying level front to back? If not pack up the front of washer until level.If still no good take out dispenser drawer completely check for obstruction inside housing of machine. Also while drawer is out clean the underside or top of dispenser housing with an old toothbrush or similar tool,(you will see several pin holes where the water comes out when filling).To take out dispenser open drawer fully and there should be a clip at top back of drawer that you push while pulling drawer at the same time.Hope this is useful to you.
    Aug 24, 2007 | Haier XQG50-11 Front Load Washer / Dryer
    Kenmore HE2 Plus Front Load Washer Logo
    22 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
