Question about GE JE1540 Microwave Oven
Failed keypad on ge wes1450 microwave oven - GE JE1540 Microwave Oven
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave Keypad or Control Panel
If some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
I have attached a drawing to show where the bulb is on this model. It is located on the right side of the oven next to the wall of the cooking cavity.
The bulbs are available in local grocery stores, hardware stores, and stores like Wal-Mart and Lowe's.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: F3 meaning ?
"F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds"
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jan 12, 2009
  • 36 Answers
SOURCE: keypad on ge spacemaker microwave oven not working
Needs a new touch pad if it doesnt respond, you can check the connection between the touch pad and the pcb, but it sounds like there is an O/C on the pad.
Posted on May 19, 2009
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
Ge wes1450
You have to remove the outer enclosure to gain access to the lamp. read and heed the warnings about high voltages before poking around inside.
Mar 01, 2014 | Microwave Ovens
Ge microwave start button does not worg
It could be a failed keypad or a bad door switch.
More details and a full model number would help us help you.
Please make a new post.
May 02, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker JVM1540SN1SS. It stopped working without any warning: no light or clock or anything. Just dead weight. Any ideas?
It indicates the main fuse in the microwave oven has opened, probably one of the main parts have failed, possible causes, magnetron, inverter board, and the keypad control board.
Apr 18, 2012 | GE Spacemaker JVM1740 Microwave Oven
Front panel not responding
The keypad has a short in the membrane, or the microprocessor control board has failed.
Mar 19, 2012 | GE JVM1540DM Microwave Oven
F3 and beeping on my GE spacemaker 1800 microwave oven...what causes this?
F3 is the code for a failed membrane keypad.
On most of these GE models, the keypad is not available as a separate part.
So you'd have to order so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Nov 27, 2011 | GE Microwave Ovens
Is there a way to correct a keypad short on a wes1450 GE
No, sadly the WES series ovens were made for the rock bottom market, and GE does not make any parts available for them except the turntable and turntable support.
If it's under warranty, you can return it to Walmart.
If not, it's off to the dump.
Sorry to bear bad news.
May 22, 2011 | GE Microwave Ovens
Microwave display flashing & beeping.
You have a failed membrane keypad.
On this model, GE doesn't make any parts available except the tray and the roller.
If it's in warranty, they will exchange or repair it.
It it's out of warranty, you're out of luck.
I'd advise you to contact GE Customer Service in case they may be able to help you.
Jul 25, 2010 | GE JES1036PWF 1100 Watts Microwave Oven
Cant figure out how to stop the timer before it goes out, or runs out of time
You should be able to hit the Stop pad, but you can download GE owner's manuals and installation instructions here.
If some of the pads on the keypad are not working, you may have a failed keypad, which can be replaced.
If so, please reply back with your model number and let us know.
Sep 28, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave shows F3 on the display
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
Apr 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Dec 23, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
