Question about Garden
How to replace a lesco walk behind mowers transmission
  • 93 Answers
SOURCE: My Ariens 21 walk behind mower has lost its drive.
YES ! Probably the drive belt.
Posted on Sep 15, 2009
  • 89 Answers
SOURCE: I have a carftsman walk behing mower with an eager1 egine
did you turn the mower upside down then the oil filled up the oil filter take off the filter then it should start it has to breath it takes mor air then fuel to make a engine run
Posted on Nov 04, 2009
2strokeguy
  • 183 Answers
SOURCE: Need to replace starter cord on Tecumseh LV195EA
This is an easy one. You need a #2 phillips screwdriver, a 1/4" nutdriver or socket, a 5/16" nutdriver or socket, 84" of #4.5 braided nylon rope, scissors and a lighter or flame of some kind.
1. With the #2 phillips screwdriver, remove the 2 screws that hold the green plastic cover to the top of the engine. This is just a decorative cover.
2. With the 5/16 nutdriver, remove the 3 screws in the top of the fuel tank. Lift the tank straight up about 3/4" and then just lay it back on the rear of the mower deck.
3. The round black object on top of the motor is the starter houseing. You will find it being held on with 2 screws from the side. The 1/4 nutdriver should fit these. Remove them, and note the position of each screw and the position of the starter top. It might help to put some colored tape on the starter top and on the upper engine shroud to make sure you put it back in the same position. The starter top will come off by lifting it straight up.
4. Remove what is left of the old rope.
5. carefully wind the inner pulley (the same direction the rope will pull it) until it is tight. Then let it rotate back a little until the rope hole in the pulley lines up with the rope hole in the starter top. Use your screwdriver to hold these in place by putting it through the pulley and starter top vent holes.
6. Measure your rope out to 84inches and then cut it. Take the lighter and melt the ends of the rope to keep them from ravelling. When you melt the ends, take a paper towel or a rag and wipe the ends to form a point. This will make reinstall easier.
7. Push the rope throught the eyelet of the starter top and through the hole in the pulley and tie a figure 8 knot on the inside of the pulley. Tie the starter handle on the other end. but do not tighten this knot, you may have to untie it to lace it back through to where it goes.
8.. Hold tension on the rope and remove the screwdriver. The rope should retract into the starter top.
9.Reinstall everything in reverse order.
Posted on Nov 02, 2010
2strokeJim
  • 577 Answers
SOURCE: I have a 60" Lesco
If it were me I would check the PTO switch with it running and use a dvm or test light to see if switch is working or defective , you could just have a bad wire connector at the switch or at PTO clutch ....look for discoloration or spread terminals, good luck
Posted on Aug 01, 2011
  • 214 Answers
SOURCE: ive replaced my transmission on my walk behind
The gas and oil weren't in the mower when it was upside down were they?
If that's not the issue, then the problem could lie in the fact that neither tank was fully drained before being put upside down. What happens is that the oil and fuel mix and will drain into the wrong area.
My best suggestion would be to leave the mower upright for a few days before trying to start it If need be, drain the oil and gas and let both tanks dry out completely before refilling.
Clean the spark plug and change the filter.
If none of these ideas work, then you will need to take your mower in to be serviced.
Posted on Aug 13, 2011
Why isn't something engaging when accelerator pressed?
It would help to know more information about the mower in question. Walk behind push mower? walk behind self-propelled mower/ Riding lawn mower? Lawn tractor? Or goat...just kidding...lol. The engine horse -power or cc's and make of the mower and engine. Anything happen before the problem or was it straight out of storage. Does the gas pedal feel normal? Could you be talking about the forward/ reverse pedal? These types don't engage by depressing them, they engage by releasing the pedal.
I'm going to guess you have a riding lawn mower or lawn tractor. The pedal for those types of mowers controls the transaxle ( rear wheels, transmission and differential basically). If the pedal move properly and it was working ok when it was stored, then check to see if you can push it with little effort. On most transaxles there is a disconnect rod to disengage the transaxle for towing the mower without damaging it. Pulled out for disengaged and in for engage. If that all checks out it could be very low on transmission fluid or the drive belt might be off or broken depending on which type you have. If it is low on fluid, you have a leak. Hope this helps.
Mar 11, 2016 | Garden
How to tighten drive belt on 26 inch walk behind mower or replace drive belt
Here is a video about how to replace the drive belt on a walk behind mower, hope it helps you out!
How to Replace Lawn Mowers Drive Belt
Jul 28, 2015 | Garden
What are the troy bilt 618-04378 transmission parts?
http://www.searspartsdirect.com/partsdirect/part-model/Troybilt-Parts/Walk-behind-lawn-mower-Parts/Model-12AG836E711/1307/1500600&shdMod=12AG836E711
Jul 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Why would Lesco Walk Behind Mower get no fuel?? Has New Pump and Fuel Filter
Be sure your petcock is in the open position. Not uncommon to forget to open it after working on the carb
Jun 17, 2014 | Garden
Where safety switches are located on lesco walk behind commericial lawn mower?
usually the only safety is the engine shut down control cable that is attached to a smaller handle on the main handle that you must hold to have the mower to start and run part number for the cable is 946-0957
May 29, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
I have a 60" Lesco
Aug 01, 2011 | Garden
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
