Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
HP F1930 Capacitors
Hi, I've read the questions and replies regarding a monitor that doesn't power up and i have ordered the capacitors but can't seem to open the back. I've taken out the screws but unable to remove the back cover.....
Can you let me know if there is a special way of getting it open?
Regards,
Michael.
  • 1 more comment
  • Anonymous Feb 07, 2009
    Same problem... need to check capacitors and the Inverter board but don't know how to remove back panel or open monitor to check. Then.. where can one find a schematic of the inside as the manual shows nothing on this.
  • useHPmost Feb 11, 2009
    several folks say they have fixed the f1903 monitor themselves, but noone has given any help with how to open the monitor to check what the problem may be.
    Can someone please provide information on what the trick is to get the monitor back off or open in order to look at the inside
    I have removed the screws on mine as well as stand, but cannot figure out how to open it up to look at. I do not want to force anything or crack the brittle plastic case, and cannot find any catches, releases, or buttons to release the front.
    Thanks!
  • Scouse_01 Feb 12, 2009
    I managed to open my monitor by removing the screws and then prising the front silver cover off with a screwdriver. This revealed the monitor casing, which is held on with lots of sticky tape (the strong type), which I gently pealed back before removing some more screws along the sides.
    Once you have removed the tape and screws you can open the casing, which you are then presented with two circuit boards. The one that has the power cable attached has a clear plastic envelope type of cover, which can easily be removed, exposing both the circuit boards.
    NOTE: upon visual examination of the capacitors within my monitor none of them had exploded, which tells me that it wasn’t the capacitors and therefore must be something else………..If any of you get that far and manage to find out exactly what went wrong please share in detail with others like me.
    Problem Solver:
This is how I learned to open my f1703hp monitor not sure if f1903 hp is the same...I got my open and going to replace power board waiting for the mail LOL.
http://www.fixya.com/support/t862133-open_f1703
Posted on Feb 12, 2009
Monitor Flashes Then Goes Very Dim
Check and replace the inflated capacitors on the power/invertor board. The generated 12 volts are unstable and protection cirquit turns the invertors off to avoid damage to the IC
May 16, 2015 | HP 2311x 23-Inch LED Monitor - Black
Hp w1907v monitor switches off after being switched on
It sounds like defective capacitors in the power supply/inverter.
Unless you are experienced in electronics be careful repairing.
Check for bulging electrolytic capacitors, bulging capacitors indicates they are defective. But a bad capacitor doesn't always bulge to indicte it has failed. Replace all cheap capxon capacitors, with low ESR rated capacitors from Digi-Key, Mouser, Allied electronics or Newak electronics.
Jan 31, 2012 | ViewSonic Computers & Internet
OSD Lock out on HP Monitor
I've seen this solution suggested: Unplug the monitor from power. Hold the power button in for about 30 seconds to completely discharge the capacitors. Now power it back on.
If that doesn't work, go into the monitor's menu and do a factory reset. Hope it works now.
Nov 01, 2011 | HP f2105 Monitor
Hp w19 lcd monitor display go off after a while
Hi There,
Defective capacitors on the power board can cause this problem, you can read tips that I have written here. hopefully can help.
regards,
dm
Jan 18, 2011 | HP w19 19" LCD Monitor
Monitor keeps turning on and off? it wont even show the screen for more than a second or two and then switch to black again.
your LCD inverter is almost dead. the monitor itself actually remains on, but just goes to black each time the LCD inverter cuts out, since this is what supplies white light to the screen.
In case you wanted The FP5315 Users Guide, or 3 other HP documents for the HP FP5315 LCD Flat Panel Monitor:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=324205&
Jan 05, 2011 | HP Compaq FP5315 15" LCD Monitor
Dell monitor can not on. after pressing on button buttons light showing on off and screen in blinking pls help.
Usually it's electrolytic capacitors' problem inside the monitor. In case you can use soldering tools you can handle it. Open the monitor's case and locate near the power supply socket the capacitors like these
Replace ALL of them with new ones. The cost isn't too much and you can find them at any electronics components shop at your area.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 22, 2010 | Dell IN1910N 19" Monitor
Can't get any signal, or watch dvd's. Everything is plugged in and working a few hours ago; when I got back home, nothing's working
jiwurster, If your unit seems to have a "black" lcd screen, then you may want to read a testimonial in my fixya profile. Your unit may also have bad electrolytic filter capacitors on it's "switch-mode-power-supply" circuit board. Check your board visually for swollen/leaky "CapXon" brand electrolytic filter capacitors. If not into doing inspection, you will need to contract out the work. Just do some reading here on fixya in the profiles of "budmrtn" "buddymc" "12fixlouie" The problem (poor quality/infantile failure) of CapXon filter capacitors is also rampant in the CCFL-back-lit-lcd monitor industry affecting nearly all brands of monitors. Hope to see reply from you after you do the investigation and pay a visit to YOUTUBE to see video clips of owners/technicians who have successfully refurbished their power supplies inside of the lcd monitor or lcd tv. I'm 12fixlouie on fixya or lmistyrel on aim Hope to to see reply from you.
Aug 15, 2010 | Olevia Kolin DLT2711M 27 in. LCD...
When i turned on my monitor it stays on for a couple of seconds and goes blank (dark screen). But also has error message stating no DVI input?
here the solution to ur question.. made simple its from HP..
http://tinyurl.com/3xt5wwb
let me know if this was helpful regards, guru
Apr 24, 2010 | HP 2009M Monitor
Hp pavilion f1930 shows pic for 2 secs. then blank
Rather than guessing, or blaming the computer, I fix the F1903 backlight problem. Power the monitor and using a bright flashlight check the screen to ensure there's an image, or the menu when you press the menu button. Nearly every one of the F1703 and F1903 monitors I've repaired have all been backlight issues. If you have an image proceed with these instructions. This is a repair for those people competent in component level electronics repair with good soldering skills. Items needed, Crosstip screwdrivers, fine tipped soldering pencil, fresh rosin core solder, (4) "2SC5706" or "C5706" Transistors. Remove the 4 screws holding the base, set the base aside. Lay the monitor face down on a surface that won't damage the screen or Bezel. Remove the 4 screws holding the back on.Carefully pry the back away from the bezel. Be careful in doing this because the display controls are attached to the bezelremove the 4 screws holding the control board on. Turn Monitor face up, remove bezel. With the Monitor Face up remove the Machine screws around the edge of the case. Carefully place the monitor face down again without having the LCD fall out of the Monitor frame. Peel the foil Tape back on one end of the frame and using small pliers, unplug the 4 CCFL plugs (these go to the 4 lamps, I believe you have to remove the VGA and DVI connector Hex socket screws and screws around the power input. Carefully lift the back up and unplug the LCD, you'll have to remove the adhesive backed ribbon cable retainer. Set the LCD somewhere safe.The board with the 4 CCFL plug sockets is the Inverter board, unplug it fomr the Logic board, Remove the screws holfding it in as well as the 2 plastic clips (Squeeze these one at a tim with needle nosed pliers while gently lifting the board up.set the Monitor fram aside as you're going to focus on the inverter board. Using a LIGHTED magnifier, look for cold solderjoints, dull gray and pitted looking. One by one remove the solder with a desoldering braid (I mark the board with a sharpie pen to remember where all of the questionable joints are.) Using a fine tipped soldering pencil REMOVE the solder and replace with fresh rosin core solder. Be VERY careful not to disturb any of the surface mount components on the board. There are 2 large gray boxy looking capacitors with 2 transistors around each one. Check the solder connections there carefully on the capacitors. Look for signs of arcing, blackened spots or overheated circuit board. The 4 transistors in this area are (2S)C5706, replace them all, they're about a dollar apiece on EBAY, I would NOT recommend using a "SK or EGC Equivilent". Once the transistors are replaced, reassemble the monitor, up to the point of where you put the plastic case back on. with the monitor face up, plug in power and a signal cable form the computer and carefull press the power button on the Control board, the monitor should work. This is the most common fault with this monitor, if it doesn't work, go back and check all of the solder joints and resolder any you may have missed. Once the monitor works again, reassemble the plastics onto the frame, attach the base. I hope this helps, I can't promise this will resolve the issue every time, but it has in virtually every one of this model I've repaired. This repair helps the "no backlight or comes on then goes dark" problems. Randy L. Bray
Mar 29, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp vs19
If it displays the 'no input' type message on the display, it's likely a cable or perhaps the main board in the monitor has gone out. However, if the display is completely black, no backlight, etc. or if the backlight flashes once then stays off, and possibly emits a high pitched squeeling sound, it is very likely that the capacitors on the power supply board for the inverter(s) have gone bad. Apparently there are a few different versions of this same monitor, but all seem similar, and many seem to have problems with the capacitors going bad over time. There is information floating around on this monitor on the internet (http://boredprojects.blogspot.com/2008/06/hp-vs19d-fix.html) which may or may not be the same as yours, but pulling it apart to replace the capacitors is a $5-10 and 1-2 hour shot in the dark, and seems to be within the capabilities of anyone with the ability to solder. Just be careful of the small surface mount components which are all over the back sides of these boards... The bad capacitors should be fairly obvious, with bulged or ruptured tops, possibly leaking fluid. The are most likely going to be the 1000uF 10V (or 25V depending on the model) capacitors towards one edge of the board. On mine, there were 6, 3 of which had swollen. Replace them with the same (higher voltage rating is fine, but not lower) specification parts, and it should be back in order.
Dec 27, 2008 | HP vs19 (Silver) 19" LCD Monitor
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
306 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
