Question about Corona 23-DK Compact Heater
Can i burn deisel fuel in my dyna glo heater, cannot find kerosene anywhere around here?
  • 700 Answers
Only if it's number 1 grade diesel
Posted on Jan 20, 2009
Dyna-Glo kerosene forced heater burning eyes and will not stay lit with top on
Do NOT use it indoors. If it's burning your eyes it's carbon monoxide from an inefficient burn and it will kill you. Kerosene flow is not working correctly. Cannot diagnose without examining. I'd recommend taking it thoroughly apart and cleaning all parts (especially internally of parts... anywhere kerosene flows). You can use "Brake Kleen" (or any brand) from an auto parts store. It evaporates quickly and leaves no residue.
Apr 05, 2016 | Dyna-Glo Heating & Cooling
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
I just bought a dyna glo kersene heater. Can I use diesel fuel in it instead?
kerosene is a higher grade of deisel donot do it problem with fumes
Dec 27, 2010 | Heating & Cooling
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Kerosene heater
Dyna Glo 95 c4 Manual
http://www.owneriq.com/mdownloads/8979e0af-dfee-45f1-a8ba-c05c2f5ed4a8.pdf
Jan 31, 2009 | Dyna-Glo RMC-8001SS Heater
Dyna-glo kerosene heater (rmc-55-r7 )
wicks won't light for usually one of 2 reasons. water in the kerosene, which means a new wick and new fuel. or build-up on the wick. check to see if the wick is hard. your wick should be soft. burning out the heater until all fuel is used either by running down all the fuel in the unit or removing the fuel can and lighting to burn off all fuel in the bottom will prevent the wick from getting hard.
Mar 09, 2008 | Heating & Cooling
Diesel
well, somebody once told me that if you add a quart of oil to 5 gal of kero, it makes a good diesel substitute. So, in theory, I would add a little ethinal (corn gas) to the kero.
Feb 20, 2008 | Corona 23-DK Compact Heater
E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Feb 03, 2008 | Dyna-Glo (PPH16-LP) Utility Heater
Corona 23-DK Compact Heater Logo
174 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
