Question about Toshiba Computers & Internet
Sound driver for n61 - Toshiba Computers & Internet
  • Toshiba Master
  • 3,606 Answers
Hello visit toshiba (if the brand is that) here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Product%20Support
Select laptop or desktop.
Select your pc model.
Select the FULL pc model number
(eksample: satelite p403-s4102)
The number is placed somewhere on the pc.
You maybe also need to select your windows system in order to find the right driver.
Good luck
Posted on Jan 07, 2013
Hdd caddy and cover
Go here: https://hddcaddy.com/en/
I order from them and I was surprised how fast they move.
Jul 13, 2014 | ASUS N61 Series N61JQ-XV1 NoteBook Intel...
Unrecognized hard disk
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jun 15, 2012 | Freecom Hard drive XS 2 TB black
After i did an upgrade to the memory to 8 gig and hd to momentus 500 xt, everytime i use it it would just take a few minutes and my screen turns blue. seems like it's overheating so quickly coz if i'm in a...
I am wondering, did you download updated drivers for the system and hard drive?
There is no reason, that I am aware of, why the laptop would run hotters. The more the memory, the better. Bearing in mind there is not many laptops that can utilise 8Gb memory unless in 64bit mode.
Mar 11, 2011 | ASUS N61 Series N61JQ-XV1 NoteBook Intel...
Fan stopped working on my N61 model of my laptop,going ot replace the heatsink and fan myself instead of dealing with customer support, just unsure what parts I need exactly.
If the fan stopped working then you only need to replace the fan. There's no need of replacing the heatsink as there's nothing to break on it, it's just a block of aluminum and a copper pipe embedded on it. So, just do a search on eBay or Amazon for a fan for your N61JQ laptop, this shouldn't be more than $50. Just make sure you're getting the fan from a company, and make sure it's a new one. You don't want to end up with two broken fans.
On the other hand, as a temporary solution, you may want to get an electronics lubricant spray and lube up the inside of the old fan. This may prolong the life indefinitely but you will need to open the laptop and clean up the heatsink radiator often, about once every two months or even more often, depending on the environment you work in.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Feb 01, 2011 | ASUS N61 Series N61JQ-XV1 NoteBook Intel...
Asus n61 wireless switch on side is on, but light wont go on, and it wont pick up any connections!
Are the drivers installed correctly? Go at the device manager (right click on my computer - properties - hardware - device manager) and check for any exclamation mark at any device. In case of drivers needed go at this link, select your operating system and download the official driver you need.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Nov 03, 2010 | ASUS N61Jq A1 Notebook
I have a Asus n61 vn a1 laptop bought 8 months the problem is that all of a sudden it shuts down completely without warning i asked the asus people they asked me to update bios with win flash utility but...
Hey its still in warranty period get it fixed or exchanged for free from company people.. If they don't support you shoot a complain of them on their local as well as global website. Hope this will help..
Aug 15, 2010 | ASUS Computers & Internet
NEED TO AVERAGE CELLS, WHERE ONE OR MORE CELLS CONTAIN ''0'' OR ''#D
Try this. If any of the cells are zero (or blank), the word 'zero' will be displayed. Substitute anything you want for the text including blank ""
=IF(OR(F61=0,J61=0,N61=0),"zero",AVERAGE(F61,J61,N61))
Aug 26, 2009 | Microsoft Office Excel 2007
Computers & Internet Logo
29 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
