Question about GE Profile JTP56 Electric Double Oven
Sabbath mode What does sabbath mode mean on wall oven.
  • 1,543 Answers
This feature has to do with when it is OK to cook during the Sabbath or some other Jewish holidays. If you are not of the Jewish religion, ignore it to allow your range to function 100 % of the time. Do not rate if you do not feel this is a Fix-Ya for your range, as other ratings will lower my score. Thanks.
Posted on Jan 20, 2009
Is there a shabbath mode on this oven. if yes how does it work
Sabbath Mode - Star-K Kosher Certification - Kosher ...
www.star-k.com/kashrus/kk-cooking-SM.htm
Whirlpool called this "the Sabbath Mode" and was awarded a patent in 1998 for ... In many cases this mode will prevent the oven light from going on/off as the ...
Sep 24, 2015 | Ovens
Co1 erroe code distinctive wall oven what is problem
According to your model number this code means Shorted or stuck key. Your keypad needs to be replaced. Good Luck
Aug 07, 2014 | Dacor Distinctive DO130 30" Single...
What does 5ab mean on the oven?
Some ranges with a lot of features have a Sabbath mode, hence the letters Sab in the display although it looks like 5ab. Check your owners manual and it should tell you how to turn off the Sabbath mode. If you don't have a manual Google your model number and Sabbath mode.
Aug 28, 2011 | Ovens
Jenn-Air gas wall oven some how got stuck in ''Sabbath'' mode and unable to reset.
ok it happens / so to enable the Sabbath mode 1 open the door. 2 press cancel/off. 3 press the number pads 7&8 and 9 , in that order. 4 press Number pad 6 . 5 press start. "sab and on" will appear on the display ..( now to disable the sabbath mode .}. ( repeat the steps above to disable the Sabbath mode. " Sab and off" will appear on the display .. there now that wasn't too tuff was it .. mm hope this helped ..
Jul 15, 2010 | Jenn-Air Ovens
How set sabbath mode??
to turn on or off the sabbath mode on your oven press and hold the sabbath mode button for 5 seconds that turn it on and then repeat to turn it off
Apr 04, 2010 | KitchenAid KEBC107 Electric Single Oven
Maytag oven says sabBATH what does it mean?
My Maytag oven also has a "Sabbath" mode and you can check your manual to see how to turn it on/off. I have a different model than yours, but to turn the "Sabbath" mode off on mine, the manual says to press and hold the CLOCK pad/button for five seconds.
Sep 16, 2009 | Maytag 30" Built-In Single Electric Wall...
Maytag single electric built in with a display saying sab bath
It is in Sabbath mode, used for Jewish holidays. Anyway, hold the cancel button for 3-5 seconds and it should revert back to normal operating mode. It will still bake in Sabbath mode but will not display anything due to the laws regarding observation of the Sabbath
Jun 16, 2009 | Maytag MEW6527DDS Electric Single Oven
Dacor ECD230 Sabbath Mode
You don't need to do anything special.
Quoting from Daco.com FAQ
"In our ovens, the cooling and convection fans do not turn off when the oven door opens. The lights also do not turn on. There is no timed shutoff on our ovens, either, meaning that once they are turned on, they will stay on until you manually turn them off. Both of these would be considered violations. Our ovens do not have a special Sabbath button because our ovens already adhere to the laws. When the oven door is opened, there are no changes to the control panel, which would also be a violation. It is best to wait for the small "On" light with the circle around it to go on before opening the oven door, though. This light indicates that the element has gone on, as the oven cycles on and off to maintain the selected temperature. Opening the oven door without this light going on may trigger the element to go on, which can be a violation."
Mar 25, 2008 | Dacor ECD230 Epicure Stainless Steel...
GE Profile JTP56 Electric Double Oven Logo
469 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
