Question about Sony Playstation 3 (PS3) Console
Ps3 wireless hi i dont have a problem just a question what type wireless adapter do you need or what do you need to connect the ps3 to the internet.
  • cjrun Dec 24, 2007
    I have a lynksis router but my PS3 is nit picking it up as an access point. I'm probably doing something wrong in the configuration process?
    New Friend:
    Problem Solver:
  • 5 Answers
On a wireless N type within 50 feet is sufficient with a type b/g 75 feet is the range give or take a few feet depending on walls and what the walls are made of. but I suggest running the network set up utility and manually inputting the network name and other info
Posted on Apr 11, 2013
    Problem Solver:
  • 6 Answers
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Posted on Jun 30, 2007
2 Suggested Answers
  • 39 Answers
SOURCE: my ps3 would connect to the internet
Try connecting to your router with a cable and see if that is able to get you online.
If it does, then 9/10 its a signal problem.
If it doesn't, then you have a settings problem.
Also, is your router close enough to the ps3 to supply sufficient signal to the console? From my experience, the router needs to be pretty close to the ps3 for it to get a good signal or if you have a wireless N type router. Wireless b/g routers usually need to be very close to their source for it to be fully effective as the ps3 requires.
Posted on Apr 16, 2009
Error code 8002ad23
Hi Giles
You probably have your router connected to your modem, and a PC connected wired/wireless, and the ps3 connected wired/wireless.
1. First you need to start your ps3 system. Go to your network settings and select information. Write down your IP, Subnet mask, Standard Gateway, and the primary DNS.
2. Start your PC and go to your networks settings. Right click your network adapter, click properties. Select "Internet Protocol version 4 (TCP/IPv4). Click properties and type in manually the IP adress, Subnet mask, Standard gateway and DNS.
Then you click "Advanced" and then you click "WINS" then "Activate NetBIOS over TCP/IP". Save your settings and connect the ps3 to your network (should not make a difference if you do it wired or wirelessly)
Let me know if this helped and please do rate my solution.
Regards
KreativeGeek
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
I need help hooking my PS3 wireless
Hi
You have not specified what kind of connection are you going to use to get online on your PS3, i am listing steps below first for a wireless connection in case you have a internet connection with a wireless router or modem.
Make sure that your wireless Internet is turned on and working properly,Turn on the Playstation 3 game console and follow these steps below
1) Access the "Network Settings" screen under the "Settings" screen in the main menu.
2) Select the "Internet Connection" tab and select "yes" when the system displays a new screen.
3) Select "easy" on the new screen that pops up asking what type of installation you want to use.
4) Select "wireless" when it asks you what type of Internet connection you have.
5) Select "scan" on the next screen so that the system searches for all available Internet connections in the area.
6) Select your home Internet when the screen pops up displaying the available Internet options.
7) Save your settings on the next screen.
8) Test the connection to make sure that it works properly, also you would need to enter the secure password if you have set it for your wireless modem our router for wifi access in order to connect it with your PS3.
Now for connecting your PS3 through a wired internet connection you can follow the instructions given at this link, this is with diagrams for you to understand better.
Let me know if this helps and please do not forget to rate my solution
Wish you Happy Holidays and Happy Gaming
Regards
KreativeGeek
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
WHAT DO I NEED TO HOOK IT UP TO THE INTERNET
Hi
Dec 08, 2009 | Sony Playstation 3 (PS3) Console
Ps3 connection to internet
Hi friend
These routers practicall has a range of 55 to 65 meters. If your ps3 is within the range then try thses steps or else you need to buy an access point to get the signal from your router to the ps3.
1) click start menu>run? type cmd and hit enter
2) in the black box and type ipconfig/all
3)note the default gateway
4)open the internet explorer and type the default gateway number
5) username is blank(dont type anything) and password is admin
6) click advanced wireless settings
7) change the following settings beacon interval-75
Fragmantation threshold-2306
RTS threshold-2307
8) save settings and turn off the router for 30 secs and then give power
Enjoy
warm regards
Chiranjeet Mitra
Oct 08, 2009 | Linksys WRT610N IEEE 802.3/3u IEEE...
Trying to connect my ps3 to the internet but need wireless route
That won't work because your old sbc wireless router 2wire gateway is also a modem. You need a plain router for Time Warner. Try Linksys router.
Sep 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
My ps3 would connect to the internet
Apr 16, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont connect to internet
Your PS3 should have WiFi built in unless you bought he 20GB version back when it first came out, that is the only one that dosn't have WiFi. But you can still connect it the way you want. You can use any type of ethernet cable, straight through or crossover. You need to go into your network connections in the control panel, select wired and wireless connection at the same time and bridge them. That should do it if you wanna go that route but you would have to have the computer on anytime you wanted to connect your ps3 to the internet. The best bet I think would be to just use the WiFi built into the PS3
Feb 14, 2009 | Sony Playstation 3 (PS3) Console
How do I connect ps3 to wireless internet
go to network setting and set it to wireless and if you dont have any wep on your wifi, set it on scan .. your unit should have wireless acess
May 14, 2008 | Sony Playstation 3 (PS3) Console
Wiring up 2700hg-b wireless router
Hi, you will need a ethernet card in the pc to connect up a wireless router, most dont work with usb,
otherwise you would need a wireless adapter.
once you do get it connected, go into internet explorer and type in the ip adress for the router, will then come up with a menu for you to programme in your broadband details, once you get the router up and going, go into the PS3 settings, network settings, it will pick up the router all you need to do is enter the network key and its all go from there.,
ethernet card should cost you about £10 from any shop
Happy New Year
John
Jan 01, 2008 | 2wire 2700HG-B Router (2700HGB)
Ps3 online
ps3 has a built in wireless adapter.rather than having wires all over, get a wireless router.connect the router to your modem with an ethernet.once you have the wireless router up and running,you will have whats called an "access point" for any devices to connect to wirelessly (within a reasonable distance),such as the ps3.
Dec 30, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
301 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
