Question about Denon DRA-37
HELLO,MY DENON DRA-37 COMES ON EVERYTHING WORKS BUT NO SOUND.I DONT PLAY OFTEN ITS LIKE NEW.
COULD THERE BE TWO BUTTON I CAN HOLD AT THE SAME TIME,IS IT LIKE A RESET.I DID IT ONCE BEFORE AND EVERYTHING WORK, BUT THAT WAS SEVERAL YEARS AGO.CAN YOU HELP ME WITH THAT?
SOURCE: Denon 2902 No Sound
REPLACE MUTING TRANSISTORS IN DSP PANEL
Posted on Sep 05, 2007
  • 151 Answers
SOURCE: Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Posted on Jul 12, 2008
SOURCE: reset channels??
http://www.eserviceinfo.com/download.php?fileid=26004
http://www.eserviceinfo.com/download.php?fileid=26005
Here are the links for the manual. I've lost my remote as well. I can't get my unit to recognize the digital audio input (optical). Very frusturating.
Posted on Nov 20, 2008
SOURCE: Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Posted on Dec 30, 2008
  • 85 Answers
SOURCE: Denon DRA-555 Memory won't hold set FM stations when powering up
Most probably the memory capacitor / battery inside soldered to pcb
Posted on Jan 09, 2009
My denon dra 295 radio won't play everything else is working
Try resetting the unit.
HOLD DOWN SPEAKER A AND SPEAKER B BUTTON at the same time as HOLDING DOWN THE POWER BUTTON TO TURN IT ON. Hold it for five seconds and the unit should reset. This may resolve the issue.
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 27, 2016 | Denon Audio Players & Recorders
How to unlock remote for denon rc1170
My ampifier remote is not working for my amp anymore its coming up "( Remote lock : on ") what do I do ??
Feb 09, 2014 | Denon DRA-37
Can dra 37 be used as a pre-amp without connecting speakers
If you mean a sa control center for source selection, volume and tone control, yes, but NOT for a turntable (no PHONO).
Controlled audio goes emerges from the pre-out. Page 9.
http://www.retrevo.com/support/Denon-DRA-37-Receivers-manual/id/696dj086/t/2/
But you could still use its own speaker terminals if your exxternal amp has is remote or has its own volume control to match it up with other speakers.
Sep 05, 2011 | Denon DRA-37
Denon DRA-37 Receiver-Remote lock on. Need to unlock.
Refer to the "Initialization of the Microprocessor" section of the manual (page 16 of the PDF version of the manual).
1) Turn the unit OFF using the On/Off switch (not the standby switch).
2) Depress both the Speaker A and B switches, and turn the Power ON.
3) The entire display should flash at 1-second intervals. The microprocessor should be reset, and the remote should be unlocked.
Jan 23, 2010 | Denon DRA-37
Denon dra-95vr receiver has no sound out. All
Two things to check. First, the 95VR can be deceiving because it has a "variable loudness" control that some may mistake for volume. The actual volume is controlled by the big up and down arrows on the upper right side. If the volume is turned up, you should see the volume bar graph display show up. If none of the inputs are giving you volume, and the volume is turned up, then try running the output from the processor loop output in the back to another amplifier. The processor out is jumpered to the processor in for normal operation. Missing jumpers could cause a problem also. If there is sound coming to the processor out, then you have a problem with the power amplifiers. Best to refer that to a technician.
Dec 29, 2009 | Denon Audio Players & Recorders
Denon DRA397 Panel lock on.
Denon has for some reason removed this function from their user manuals. However The manual does show how to do a manual reset of the unit. This may correct the issue.
With the Amp OFF but plugged in, press and hold the speaker A and B buttons and while still holding them press the POWER button. Continue to hold the speaker buttons for another second or so. The display should all light up and flash at 1-second intervals. If not flashing, try again.
This should reset the unit back to factory state with the front panel lock disabled.
Jul 07, 2009 | Denon DRA-397
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
Apr 12, 2008 | Denon DRA-397
Remote locked
I had the same thing happen. This fixed it...
1. Press master power switch OFF
2. Hold down Speaker A & B buttons simultaneously then press master power switch
Display will flash at 1 second intervals denoting that the microprocessor has reset.
3. Release Speaker A & B buttons
Remote should now work.
Sep 01, 2007 | Denon DRA-37
Denon DRA-37 Logo
41 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
