Question about Panasonic (KX-TG1032S) Phone
Phone beeps 3-4 times and then hangs up in the middle of talking to someone
When i am talking the phone will randomly beep 3-4 times and hang up and say line in use? No other phones are in use and there are no messages waiting. I also do not have a message service. I had an issue a few weeks ago that made a LOUD humming beep. Getting a new ac cord fixed that. Now this? These phones are a terrible hassle.
SOURCE: Almost constantly gives "no link to base" message
I had this problem too. I popped the battery out, waited 1 minute then put it back in. Unfortunately this clears the memory of all recent calls, etc. but it immediately started working again. So far its only happened once...
Posted on Mar 31, 2007
CORDLESSGURU
  • 106 Answers
SOURCE: Voice mail issue
Here is what is suppose to happen. Once you leave a message at Rogers, they are to send your phone a "stutter dial tone" signal back to your phone. When you phone gets this signal, it is to light your messag light. So we need to figure out if Rogers is sending the signal, and if your light is working. So, leave yourself a message. Give Rogers a minute or two to send the signal. Pick up your phone to make a call. Do you hear a "stuttery" type dial tone? If not, it sounds as if the Rogers system is not providing the signal. Okay, if your light is not on, then lets test the light by taking the Rogers VM out of the equation. Go to your Panasonic answering machine menu, and turn it on, then turn the number of rings set to 1, and save that. Now call the phone. It should answer after a ring or two, and your call should never make it to Rogers AM. Leave a message and see if your Panasonic answering machine takes the message and lights the light. If it does not light the light even though your message was recorded and saved, then you may have a bad light. If it lights the light, go back into your menu and turn the machine off, and look for any settings regarding using the "telephone company voice mail" or review your message light settings, etc. Hope this helps
Posted on Feb 04, 2008
SOURCE: Uniden PowerMax 5.8 Caller ID for Call Waiting Stopped Working
I had the same problem with one of my phone. Turned out that the memory is fulled. After I deleted some numbers in my address file, it works.
Posted on Apr 08, 2008
SOURCE: message light won't come on
press intercom 165
#6
#2
messae lamp enable
Posted on Oct 31, 2008
  • 40 Answers
SOURCE: Phone won't work
try unplugging the base and plugging it back in. Or try a different outlet for the base.
Posted on Jun 11, 2010
How can I get more than 3 rings? I am in my 70s and disabled. I can not get to my phone to answer in 3 rings. I miss calls due to this.
  1. Pick up the home phone receiver, wait for dial tone, and dial *94. You'll hear 3 beeps followed by dial tone.
  2. Enter the number of rings you want (between 2 and 9).
  3. Listen for 2 confirmation beeps and hang up.
Dec 11, 2014 | Vtech CS6719-16 Cordless Phone with Caller...
How to recover saved messages remotely
To retrive the messages remotely please follow the steps...
Dialing In to Your System:-
1.Call your telephone number and wait for the system to answer. (If your answering system is off, it will answer after ten rings and sound a series of beeps instead of your greeting.)
2.During the greeting or beeps, press 0 and immediately enter your security code. If you enter it incorrectly 3 times, the system hangs up and returns to standby.
3.The system announces the current time, the number of messages stored in memory, and a help prompt. It will beep intermittently to let you know it's waiting for your command.
When you hear beeping, enter a 2-digit command from below:-
01Repeat message
02Play message
03Skip message
04Delete message
05Stop playback
06Turn the system on
09Turn the system off
10Hear help prompts
Thanx
Jul 20, 2010 | Uniden DECT 6.0 Cordless Phone ID
Parrot v508c
Turn off key word voice prompts/voice commands. The Parrot is listening for key words like "phone" or "call" or "hang-up". When it thinks that it hears this it will beep, or call someone.
Sep 06, 2009 | Parrot 3000 Evolution Advanced Bluetooth...
AT&T 964 won't free phone line when incoming caller hangs up
Verizon is right, it's out of their hands. You may have a defective unit or it may be sharing the line with other equipment that is fooling the phone in thinking the call is still there. Or, you may have DSL on the line and it may not be filtered.
You'll have to start by eliminating other devices from the line, fax, computer, credit card machine etc. Now try the auto attendant voice mail. Add those devices back and check each time.
Jun 16, 2009 | AT&T 964 Corded Phone
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
How to configure call forwarding on RCA RCA Phone model 25425RE1-
CALL FORWARDING HAS TO BE DONE THRU THE PHONE COMPANY IF YOU HAVE CALL FORWARDING - AND I DO THIS IS WHAT I DO - I HAVE AT&T IN MEMPHIS TN PICK UP HAND SET AND HIT *72- YOU WILL GET A BEEP- DIAL THE PHONE # YOU WANT TO FORWARD THE PHONE TO - SOMEONE MUST BE AT THAT PHONE NUMBER TO ANSWER IT! ONCE THE LINE IS ANSWERED- THEY HANG UP AND THEN YOU HANG UP AND PHONE SHOULD BE TRANSFERED- I ALWAYS TEST IT TO UN- TRANSFER IT PICK UP PHONE AND HIT 73# AND IT WILL BEEP 2 TIMES- NOW PHONE IS NOT TRANSFERED ANY MORE
Jan 16, 2009 | RCA 25425RE1 Phone
LG Vu lock & beeping while talking
For the beep you go into the tools menu (bottom right icon) from there go to calls and in that sub menu go to "minute minder" and turn off as for the screen lock I think you can change the time but your stuck with it. i hope that helps some.
Dec 25, 2008 | LG Vu CU920 Cellular Phone
New GE Model 28821 Answering System HANGS UP after greeting announcement! HELP?! ;P
JUNK IT AND GET A PANASONIC.. THATS WHAT I DID. THIS GE PHONE IS THE WORST.
Jul 24, 2008 | Uniden Cordless Phone
Stupid Phones
If you have two identical handsets, try swapping the batteries. If the problems moves with the battery, then it is old or weak and not holding a charge. That what it sounds like to me.
Hope this helps, and please rate my answer, good OR bad.
Oct 30, 2007 | Vtech 5.8GHz Analog Cordless Phone
SW Bell FA-980 Answering Machine
Here is a link to a similar model: http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf Here is what it says: TONE REMOTE OPERATION Remote Security Code To access answering functions from an outside line, you will need to enter the three digit security code located on the bottom of your unit. Write this number on the Remote Access Card, which you can keep in your wallet. Remote Turn On If you forget to turn on your unit: 1. Call your unit from a touch-tone phone. 2. Wait 12-14 rings until the machine answers. 3. The FA970 will automatically answer by playing your greeting. You may hang up the phone, and subsequent calls will be answered. Remote Message Playback 1. Call your unit from a touch-tone telephone. 2. After your FA970 answers, it plays the outgoing greeting and beeps once. Dial your three digit security code within 20 seconds after the beep, pressing and holding each digit for 1-2 seconds. Allow a 2 seconds interval between each digit. 3. Your FA970 will sound one beep to indicate the code was entered correctly. (If there are no beeps, enter your code again.) 4. You can press the following buttons on your keypad: Option Press Playback Mailbox 1 Messages (1) Playback Mailbox 2 Messages (2) Record Memo Message (3) Record New Greeting (8) Turn Off Answer Mode (9) If you press ?1? or ?2? (to playback messages), you have the follow options: Option Press Erase Current Message (0) Repeat Current Message (4) Repeat Previous Message (4) repeatedly Stop Message Playback (5) Skip to Next Message (6) To SAVE messages, hang up the telephone. Note: Your FA970 will sound a series of beeps if there are no messages. Remote Record New Greeting If you press 8 (to record new greeting): 1. When you hear a beep, begin recording your new greeting (up to 30 seconds). 2. When you have finished recording your new greeting, press (5). The unit will beep, and the new greeting will playback to you. 3. Hang up the telephone. Remote Record Memo If you press 3 (to record memo message): 1. Within three seconds of pressing ?3?, press ?1? or ?2? to select Mailbox 1 or Mailbox 2. Otherwise, the memo will be recorded in Mailbox 1. 2. When you hear a beep, begin recording your memo (up to 60 seconds). 3. When you have finished recording your memo message, press (5). 4. The corresponding Mailbox message count will be increased by one. To Retrieve Messages when Recording Memory is Full 1. When the message capacity is full, the unit will sound 3 beeps after answering the phone. 2. Within 20 seconds after the 3 beeps, dial your 3 digit security code. 3. Your FA970 will sound one beep to indicate the code was entered correctly.
Mar 22, 2007 | Southwestern Bell FA970SN Digital...
Panasonic (KX-TG1032S) Phone Logo
339 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
