Question about Garden
What makes swing on bobcat 337 slow?filters news oil new and full has good breakout power but everything seems to be slower that other machines i have run or owed my case cx 50 would eat this machine alive the bobcat isnt mine but run for a township i work for. very disappointing machine. has 2500 hrs on it any ideas bad pump or valves it
  • 489 Answers
SOURCE: LG SIDE BY SIDE - REPLACED FILTER BUT WATER VERY SLOW
You may have ice building up inside the fill tube that is slowing the water flow.  You will have to remove ice maker to see inside the tube.  If the tube has ice buildup, use a hair dryer to melt the ice.  Then is should work fine.
Posted on Jun 08, 2008
  • 1388 Answers
SOURCE: pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Posted on Dec 01, 2008
  • 7 Answers
SOURCE: My Breville800ESXL makes steam but does not make espresso.
jejones is right. try a coarser grind. it still makes great espresso, especially if you really pack a lot of ground coffee into the filter basket. Just make sure it is a bit coarser than you would normally use for machines without the dual wall filter basket.
Posted on Dec 02, 2008
  • 8 Answers
SOURCE: swing not workng
If it is new take it back , if you bought it used and cant take it back they took your money. The gears are worn out or it has been assembeled wrong.
Posted on Dec 29, 2008
SOURCE: Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
Posted on May 19, 2009
Elna 6000 sewing machine, machine running very slowly and will not speed up when more pressure applied to foot peddle. More details below ?
This happened with my 50 year old Elna Supermatic. It ran a bit slow, so I oiled it and it ran again okay. But then it got slower, and I had to turn the wheel to get it to start and then it would run. But then even that didn't work. No go, period. I checked the foot pedal which had a bit of lint inside but no obvious problems. But the light worked so power was getting through to the machine.
I took it in for service, and the repair guy said that the brushes inside the electric motor (they supply power to the turning part called the armature) were worn out and no longer making contact. $11.00 for new ones, and a service/cleaning charge, and it's running at full power again.
Aug 20, 2017 | Elna Sewing Machines
Bobcat 773 excavator, blade and swing is weak everything else strong
if it has electronic controlled valves , check for power to the solenoids not opening the valves correctly
check valve and lever adjustments for correct operations
Apr 24, 2017 | Bobcat Garden
How do i fix my bobcat 825 skidsteers hydraulics ? the right steering leaver works fine but the left does very little to nothing.
basically there are 2 points of control
1---is the control valve for that side which may not be opening the system
2--- the drive motor for that side which may be passing excessive oil and not turning
for the lift action to be slow indicates excessive pressure leakage in that circuit
early units had lever action to the control valves where as later units use electronic controls from joysticks to operate the valves
If this is your type of machine, I would be looking at faulty electronic control mechanisms or corroded wires and contacts
Dec 15, 2015 | Bobcat Garden
WIRING FOR CID brush swing boom
    Wiring Harness for swing boom - Skid Steer Genius
    www.skidsteergenius.com/blogs/news/.../wiring-harness-for-swing-boom
    Aug 21, 2015 - Posted by Robert Leib in bobcat 7 pin cable for swing boom, CID ... The CID Swing Boom, Prowler Swing Arm & Spartan Articulating Brush ...
    WIRING FOR CID brush swing boom - Fixya
    www.fixya.com/cars/t26003553-wiring_cid_brush_swing_boom
    4 hours ago - WIRING FOR CID brush swing boom - Cars & Trucks question. images for WIRING FOR CID brush swing boom
Dec 11, 2015 | Cars & Trucks
How do you control how fast or slow a grandfather clock runs ? Does lowering the pendelum disc make it faster or slower ? Thank you !!!
The longer the pendulum the slower it will swing, so lowering it will slow the clock down.
Feb 10, 2011 | Watches
I was shredding 3 papers at a time and the shredder seemed like it was running out of gas and dying. The red overload button came on. I checked the basket and it was not full at all. The motor seemed to...
Return it to the place you purchased it for the motor has a problem and can be a fire hazzard. You should be able to run 6 sheets through at a time without it slowing down.
Jun 23, 2010 | Royal SC180MX Shredder
My sewing machine starts sewing good and then it seems to
Providing the machine has been oiled if the machine is still running slow then the chances are the motor is on the way out.
Apr 25, 2010 | Sewing Machines
The engine oil light illuminates after making a sharp turn or after coming down from highway speeds to slower speeds
Sounds like you've got sludge. The best way to deal with it is to change the oil. Flushing with an oil cleaner is dangerouse but faster. The cause of this isrunning too long without an oil change, engine overheating, and antifreeze leaking into the oil. Lots of really short trips where the oil doesn't reach full operating temperture. Change the oil with a good cheap oil including the filter. Run the car for about a week 200 miles and change the oil again, filter and all. do this again untill when you go to change the oil it's not exactly black solid like the first time you changfed it. Another cause of sludging is the car does'nt warm up fast enough and not hitting the full operating temperture, it could need a new themostat. Overheating can cause problems too. Is the cheak engine light on? If it is you need to research the problems and get them repaired because everyuthing effects everything else.
Jan 06, 2010 | 2006 Chrysler PT Cruiser
Sears series 90 washer - hot-cold mix ratio? Testing water inlet solenoid on 110.209229990. Connected to water line and applied power to solenoid. One is full blast, the other much slower. Is that how...
No, they should be equal. Check for a plugged filter screen at the faucet end of the affected hose. Also, make sure the faucet itself delivers full flow. Check the inlet of the slow solenoid valve for a plugged screen too.
Oct 28, 2009 | Washing Machines
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
