Question about JVC GR-D270US Mini DV Digital Camcorder
JVC camcorder says "Please Wait"...
... whenever I open the LCD monitor to record now. I've used it a lot for over a year with no problem, and this started just a couple weeks ago. It takes about 10 seconds for the "Please Wait" message to go away, and so I'm often missing the shots I want. One thing I did for the first time a couple weeks ago, that I thought might be related, was using the "Copy" feature. I just discovered that I could freeze the tape and copy a still shot onto the memory card. I did quite a bit of that a couple weeks ago, and thought maybe having the "Copy" setting still turned "On" was causing it, but I've turned that back to "Off" and it still does it. I always use the adapter, so it's not a power problem. Would love any suggestions on how to resolve this. Thanks!
  • Judy Hoskins Jun 29, 2007
    I should add that this is a GR-D270U, not the exact same model shown here, as the LCD monitor doesn't show on the outside. You have to flip the little door open to see it.
Actually, I got the solution on the phone with JVC -- it was to remove the memory card which was still inside. Thanks.
Posted on Jul 11, 2007
  • 30 Answers
PRESET the camera two or three times and try.
Posted on Jul 10, 2007
SOURCE:
How do I record onto a SD memory card on my JVC grd72u?
Make sure the camcorder's power is off.
Open the LCD monitor (cover (MEMORY CARD).
To load a memory card, firmly insert it with its
clipped edge first.
To unload a memory card, push it once. After the
memory card comes out of the camcorder, pull it out.
Do not touch the terminal on the reverse side of the label.
Close the card cover.
To protect valuable files (available only for SD
Memory Card)
use the snap button to capture a scene.
Feb 06, 2016 | JVC Video Cameras
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
Hello, I opened the LCD monitor to right angles
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sep 01, 2011 | JVC GR-D870 Mini DV Camcorder
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
JVC GZ-MG20U
It's definitely an internal problem in your camera and it sounds like you don't have any warranty after 5 years. I don't have a step-by-step help guide for you since I don't know about this camcorder but in my opinion, if the camcorder is really that good, it's worth the repairs. Though HD camcorders are getting cheaper these days...
Jun 29, 2010 | JVC Everio GZ-MG21 Camcorder
JVC camcorder loose LCD monitor screen
I have the same problem with my panasonic palm camcorder, help...
Jun 28, 2009 | JVC Video Cameras
Writing DVD is not seamless
Not only you. A lot of people have same issue.I have read a lot of questions and answers,forum about JVC software Power cinema ...etc... ( go to www.videoforums.co.uk/general-sofware-problem/12080-jvc-everio-sofware.html ).Headache.That sofware from JVC is a scrap.
Buy a DVD Recorder ( cheap one ) . Record directly from your Camcorder on Replay mode. That is my way.It is good.
Please tell all of your friends,family , co-workers never buy any products from JVC again. NEVER all your life.
Sep 07, 2008 | JVC Everio GZ-MG130 Camcorder
Unable to see any picture on my JVC GR-D22U Camcorder. Please help*
I bought 3 Sony camcorders at different times, I have used not more than 20 times, and my brother bought another kind of camcorder did the same, but after 3-4 years, automatically quit one by one, even my brother’s camcorder quit within 4 years, this is what I think, the big companies like Sony, Jvc etc., won’t let you use the same unit for a long time, from our case, made us thought, they probably put a timer to control the age of the camcorders. Maybe we have to know how to adjust or change the timer chap.
I am still research about this case. And also I have a lot of documents can not transfer.
Jul 01, 2008 | JVC GR-D22U Camcorder
Jvc GR-D290 MINI DV.
sorry but I can'nt give my cradit card information in the internet
thanks
johanan
Apr 21, 2008 | JVC GR-D290 Mini DV Digital Camcorder
LCD Monitor on my GR-DV3000
CHECK YOUR RECENT PREMIUM QUESTION I POSTED OTHER LINKS AND DATA THAT WILL HELP YOU
Dec 28, 2007 | JVC Cybercam GR-DV3000 Mini DV Digital...
JVC GR-D270US Mini DV Digital Camcorder Logo
74 people viewed this question
Top JVC Video Cameras Experts
Ekse
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
