Promethean PRM30 stopped working
Turns on momentarily then turns off. fan comes on and after about 5 seconds then revs up to high speed and then the entire unit turns itself off. will not allow me to turn back on. unit has to be unplugged then plugged back in to power on again. lamp has already been replaced but that is not the issue. unit is only a week old and has never worked. i replaced the bulb because I could not think of any other reason why a brand new unit would not work.
SOURCE: sony KF50XBR800 Turn off and on issue
You will need to replace your bulb.
It costs around $ 300.00 for a new bulb.
After you have installed it, your TV will look new once again.
Posted on Dec 31, 2007
  • 1030 Answers
SOURCE: TV suddenly shuts off and lamp light comes on, but lamp is OK
did you reset the lamp timer? just a guess
Posted on Feb 08, 2008
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Posted on Feb 20, 2008
SOURCE: projector
Same problem
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Posted on Aug 07, 2008
rylee_smith
  • 8619 Answers
SOURCE: projector
Hi
If the fan is not working, the lamp will not fire. Kindly make sure that the panels are seated properly. Also chek if the outer cover is seated back 100% as if that is not seated back 100%, the unit will not work.
Posted on Mar 07, 2009
Green light on prjector PRM 35 will not stop blinking and the projector will not come on
open the case, and reseat the ribbon cable at both ends.
5 screws on the bottom and 3 screws inside the lamp housing to open the case. Be careful not to break the 2 plastic clips in the back.
Also check the micro switch on the lamp door is working correctly.
Mar 10, 2014 | Promethean Board Promethean PRM-35 DLP...
Hp dc7900 powers up momentarily even when computer is off
if the power is coming on automatically does it remains started or turns off?
Feb 24, 2014 | HP dc7900 PC Desktop
Whirlpool AWO/D 8708
F07 is a fault with the motor control, probably the triac has failed.
Jun 16, 2017 | Washing Machines
A/C fan cuts out completely when on high fan AND recirculate
Replay the blower resistor. Used to be you could replace the relay, but they are built into the resistor now. Should be under the passenger side dash. Usually behind the blower. There will be four to six small wires going to it and two big wires coming from it going to the blower motor.
Jul 13, 2013 | 1996 GMC Yukon
Compressor and fans do not turn on until rev engine
I passed this question the first time I read it, so I will take a stab at it now.
The fans don't come on until the compressor has pumped the freon pressure up to say 150 or 200 psi. And the compressor clutch has to have voltage to engage the clutch.
I wonder if the clutch is going and needs 14 volts instead of 12 to engage ? Or the relay that powers the clutch ?
Speeding up the engine would increase voltage from the alternator.
This is assuming the serpentine belt is tight and everything else is working correctly.
I think I would swap the relay with another and put a meter on that circuit to the ac clutch to see what it takes to engage it.
Jul 24, 2012 | 1992 Buick Regal
The fan in my truck only turns on on high speed.
A bad blower motor resistor will cause it. It is located ny the blower motor p.s. below dash.
Sep 28, 2009 | 2000 Chevrolet Silverado
O3 saturn ion quad coupe all kinds of problems, oil leak,high rev
Sounds like you need an axle seal for leak, and rev problem should be idle air contolr valve on Throttle body,If high mileage recommend get new throttle body assembly.Note after replacing T/Body will have high idle till driven for a while.
Jun 17, 2009 | 1999 Saturn SL
Unit powers on momentarily, bulb comes on for about 4 to 5 second
if a fan is blocked from turning then the power up self testing will detect a problem and stop it from further operation. thats why you have to unpug it
Mar 20, 2009 | Panasonic PT-LB30U Multimedia Projector
Open Questions:
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
