Question about Saws
Dewalt dw705 type 3 spark then won't work
I was using my saw and a really big spark and now won't work. I check my fuse box but it was fine.
  • 313 Answers
SOURCE: Switch diagram
as u notice the terminal on the switch has 2 connection like a switch diagram to it.it has normally open & normally close contact. the normally close contact are for red & white wire & the other
contact are for 2 black wire which is normally open contact.hope it helps.
Posted on Sep 19, 2008
Editor925
  • 285 Answers
SOURCE: DW705 Miter saw Spark in motor Compartment
Yes spark in motor compartment is normal. You only need to worry if you see a lot of sparks flying out of the motor compartment! Most power tools will spark inside the motor compartment (particularly if carbon brushes are used).
Bevel and miter could be off... Consult your manual for how to adjust these correctly, but usually the bevel has a 0-degree setting screw or adjustment, and the miter adjustment on the saw is usually done by altering the fence position... Again check your manual for specifics on your saw.
Posted on Mar 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: DEWALT DW705 MITER SAW BRAKE DOES NOT WORK
Could be worn brushes, dirty commutator or a combination of both. Unplug the tool and remove one brush at a time noting the condition and length. Use a flashlight look into brush tube and also not condition of commutator. I would blow is out with compressed air and you can try turning the brushes 180 deg and retry. That is usually the problem
Posted on Jun 27, 2009
brewerstool
  • 141 Answers
SOURCE: dewalt saw does not work
You more than likely have a break in the field. In order to test this you will have to take the field out of the motor. There will be 4 terminals on one end of the field. Test between 2 terminals of one side of the field. You should have continuity. Then test the other side. (By side I mean the windings will be seperated one on each side.) The most common problem with these saws is that the field wire at the terminal comes loose from overheating. You may be able to scratch the wire up a little (because it has epoxy on it) and then solder it back to the terminal. (Originally the wire is pressed into a slot in the terminal, but this will be broken, so you will have to solder it for it to make contact and stay) It will save you some money from having to buy a new field. Eventually though you will have to replace the field and make sure that there isn't a running short between the field and armature that caused the overheating in the first place.
Posted on Oct 13, 2009
  • 34 Answers
SOURCE: dewalt 7749 radial arm saw
According to the service manual this saw has a 120VAC single phase 2.5 Hp motor with a 5/8" x 1.5"long arbor. It has a maximum vertical cutting depth of 2 and 15/16". It has a maximum cutting depth at 45 degrees of 2.125" (2 and 1/8") without the lower guards. The maximum cutting depth at 45 degrees with the lower guards in place is 1.625" (1 and 5/8"
The service manuals (approximately 24 megabytes each) are available on line at Dewalt.com After creating an account. Then you should go here:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=18624&typeId=1495&documentId=574
for the manuals.
Posted on Nov 24, 2009
Where can I order a replacement trigger switch
How to Install a Switch Kit on a DeWALT DW705 Miter Saw ...
? 12:35
https://www.youtube.com/watch?v=FJ1Wo2xufzI
May 15, 2013 - Uploaded by eReplacementParts.com
Get a replacement switch kit for your DeWALT DW705 miter saw ... kit on a DeWALT DW705 miter saw which replaces thetrigger switch (part ...
Miter Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/miter-saw.html
Shop the Tool Parts Direct inventory of miter saw replacement parts. A miter saw is designed to quickly make cuts at a variety of angles. Featuring a pivoting ..
Oct 23, 2015 | Saws
How to replace arm locking pin on a dw705 Type 4 miter saw
Can't remember how much access there is at the back on that model, on some you have to take the main hinge pin out to get to it and move the top arm assembly out of the way. Not always the easiest of jobs.
Dec 09, 2012 | Dewalt DW715 Heavy Duty 12" Single -...
Dewalt DW 705 Type 1 Hard to pull down to cut material
Go to www.2helpu.com that is the dewalt site. You might have to change the link arm that moves the guard up. They get bent over time. Check other parts on the raise and lower assy for wear at the same time.
Dec 04, 2012 | Dewalt DW715 Heavy Duty 12" Single -...
Need to get owners / instruction manual for my Dewalt DW705 type 3 12" miter saw. Do you know where I can get one quickly?
Hello. DeWalt has 13 types of this saw on file. Here is the link to all:
http://servicenet.dewalt.com/Parts/Search?searchedNumber=DW705&searchType=1
Click on the "more details" arrow of the one that meets your needs, then click the PDF symbol in the top right of the "product information" tab.
If this helps, please rate a four-thumbs up. Thank You.
Sep 12, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
The on and off handle on my mitre saw is broken,want to know how much is a new handle
It really depends on the model. The clamshell set for the DW705 is $20. There are many different models so check out dewaltservicenet.com and punch in your model number (HINT: make sure you press the GO button instead of pressing enter after entering your model)
Nov 04, 2009 | Dewalt Saws
Jun 27, 2009 | Dewalt Saws
Mar 19, 2009 | Dewalt Saws
Can't rotate the blade carriage.
I guess that you are releasing the handle for the tilt? When released does it feel like it did? Does the carriage move any? What I would do is unplug the saw and put it on a workbench or floor and carefully tilt the saw on its back edge, holding the guard to keep if from falling quickly. Look under the saw for a bent rail and if not try to push the saw tilt by hand pushing on the bottom guard. You might have to lubricate the slide underneath or loosen up the locking mechanism. If you need a copy of the owners manual I would go to Dewaltservicenet.com and typing in your model number to download it. I really don't think it is anything major. Let me know
Jan 15, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Dewalt DW705
Use a continuity tester to check each leg of the cord from plug to switch and from switch to the motor.
Apr 28, 2008 | Dewalt DW744S 10" Portable Table Saw with...
Saws Logo
82 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
