Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG TROMM - awful smell while washer is running
I have an LG TROMM front loader wash machine. I have had it for about 2 years now....and almost immediately I learned that there was a smell left in the washer if I didn't leave the door open to dry out the washer and wipe down the rubber. So fine, I do that now and that takes care of most of the smell after washing clothes.
But I have an awful smell that emerges from the laundry area....during the wash cycle. It's a smell that sort of smell like a mix of mold and rodden eggs. Again only while the washer is running through a cycle.
We use the HE liquid detergent. I read some posting and will maybe try the Aafresh tablets, but I am still wondering if there is something else is going on. Any ideas?
  • arthurarthur Apr 02, 2009
    Sorry to hear about the "Trauma." My wife calls our TROMM, "Trauma," which is a much better name.
    I have a LG TROMM model WM2688. Paid more for this machine than all the other washers I have owned in my lifetime.
    Have had it less than 2 years. The 1st year was okay, but now it is a mold making machine.
    Have tried all the tricks, but there is no cure. This will help a bit: We do bunch of loads, finish the last one with a bleach load, run a drum clean cycle, drain the washer leave it with the door open, and let it sit idle a few days. This helps, but it is far from cured. On the next wash, mold can be smelt.
    Also, good luck if you accidentally run it with the drain open. Might want to unplug it from the wall when it is in resting state.
    What gets me is, "J.D. Power and Associates Reports: LG Ranks Highest in Customer Satisfaction With Washing Machines." (https://www.istockanalyst.com/article/vi...)
    Too bad the Washington Post can't investigate to see if this is another "Washergate."
    Problem Solver:
  • 14 Answers
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
Posted on Jan 20, 2009
Lg tromm front load washer smells like burning and going to catch fire?
Unplug the washing machine from your electrical plug immediately, and do not run the washer at all. The longer you run the machine with smoke coming out of it, the more expensive will be the repairs. Not only that, but, you could have smoke damage, and cause yourself health problems by breathing in the toxic smoke. Your question can only be answered by physically inspecting the machine. Please have it serviced by a qualified service technician.
Nov 25, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How do I open to remove the water on an LG tromm front load washing machine to repair/replace the pump?
LG machines normally have a small diameter rubber pipe folded up in the drain pump basket area on the lower left side of the front panel.
Pull out the pipe and remove the small plastic end stopper to allow the water in the tub to drain.
Sep 20, 2014 | LG Washing Machines
Have a lg tromm front loader and am wondering if it is ok to run regular detergent instead of the hd stuff. C.
Not recommended. When buying the correct product you should also find the front loader much more economical on washing powder than a top loader.
Mar 05, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Horrid smell in clothes - LG tromm front loader
Odors are caused by a variety of particulates, and each is neutralized by a specific formula.
I don't know what type of odor you are dealing with, so we'll start with first attacking any soap residues. Buy a gallon of white vinegar, and run a small laod wash cycle using hot water and add 1 quart of vinegar and 1 cup of baking soda, repeat a second time.
After the vinegar treatment, run another small load wash with hot water and 2 cups of bleach, and one cup of baking
Finally, dampen a rag with vanilla extract, and wipe down the the inside of the tub and door.
Write me at buffalonymann@yahoo.com with your results
Oct 02, 2009 | LG WM2688HWM TROMM SteamWasher
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer smells bad
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
May 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Nov 24, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
648 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
