Question about HP Pavilion dv9000z Notebook
My HP Pavilion dv6000 won't turn on
I used my laptop yesterday and turn it off. Today in the morning I am trying to turn it on and it will only flash twice and turn off again. I check my power cord in my boyfriend's laptop and it is good, I took his power cord and battery and put them in mine and I only have a black screen.. nothing ! The fans are starting but then its shuts off... so is not the battery and is not the power cord... What is it? I try to turn on but it doesn't just show all the light on but the screen never turn on and after 15 seconds it restarted and do it again
  • 50 Answers
Hi sounds like your dc connector in laptop is loose or bad connection.Try moving the power cord going into the laptop gently and watch the lights to see if they flicker off .If they do you need to take the laptop in for repair.
Posted on Jan 20, 2009
    Genius:
  • 1,913 Answers
If no one led blink and it show no power then remove battery then refix it.
2 Suggested Answers
SOURCE: My HP Pavilion dv6000 won't turn on
I've had the same problem.
Remove the battery & power cord.
hold down the power button for 10 sec to release any residual power.
plug in the power cord but leave out the battery
it should boot right up
Posted on Oct 13, 2008
I have a HP Pavilion dv6000 and the webcam does not work , i also tried everything still i couldn't use my web cam
did you try update correct drivers and reboot system?drivers is here -
http://www.hp.com/united-states/products/dv6000.html
Nov 15, 2012 | HP Pavilion dv6000z Notebook
Tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 | Computers & Internet
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
Hp pavilion dv6000 battery not chargering
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Jul 14, 2010 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000 turns onn and off
I had a similar problem with my pavilion. They have a cooling fan design that allows for lint buildup and subsequent overheating. You could try using a compressed air and blowing out the exhaust vent area for the fans.
May 27, 2010 | HP Pavilion dv6000t Notebook
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
My battery is at 0% and does not charge and whenever i take out the power chord my computer automatically turns off. Any help
here is a good resource I found:
Solution for HP Pavilion DV6000 Battery Not Charge
  • Reinstalling the power management software has just fixed it for me. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select ’scan for hardware changes’. It will reinstall it and hopefully start charging immediately (mine did anyway).
  • If your HP Pavillion dv6000 has a battery that won’t charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
  • I made the bios update, and works for me. My Dv6000 battery problems were fixed. The battery led always blinking every time and the battery didn’t charge. Now it’s ok !
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
  • If it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page.
  • Just got it to charge again.While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the dv6000 laptop battery. Power it back up and enter Windows. Then, re-insert the battery.
  • So I always remove the Hp dv6000 battery after I have powered down the laptop, and I have not had any battery problems since then!
  • I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
  • I had the dv6000 battery problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
  • Some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
  • HP has posted BIOS updates to address battery problems as well as the auto startup on some.If you will post the full model number,someone can help you find your driver/updates page.
Hope this helps, please rate! ^_^
Jun 23, 2009 | HP Pavilion dv6000z Notebook
Laptop hp dv6000 will not recognize cd burner/dvd player
HP Pavilion dv6000 laptop PC
Did you 'turn off' the AUTOPLAY feature of the CD\DVD ? When the player "runs two times at startup", it is trying to find the program on the disc.2nd- Look in internet for HP dv6000 cd\dvd drive replacement.(If that is the ""exact match for the product"" you wrote about)
3rd.goto CONTROL PANEL>SYSTEM>HARDWARE>DEVICE MANAGER and look up cd\dvd and uninstall it. REBOOT, when your system comes back it will try to find the cd\dvd. If it does not, it is damaged (kaput!), must be replaced. If Windows finds the cd\dvd drive and reinstalls the drivers, but it does not work, then the heads are dirty or damaged.That Windows found the dvd\cd means that the circuit on the device works.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
AUTO SHUT OFF HP DV6000
Youre cpu heatsink is clogged with dust not breathing properly and causing it to over heat and shut down.Must remove keyboard heat sink should be on top right removed heat sink and clean dust .Use air can and spray whole laptop.
Oct 02, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv9000z Notebook Logo
1,118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
