Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by side Refrigerator Model GSH25JFTFWW water diagram
  • 35 Answers
SOURCE: no water from door dispenser
BAD WATER VALVE OR CHECK FOR CLOGGED FILTER
Posted on Jun 18, 2009
erpaalai
  • 999 Answers
SOURCE: GE Profile Series - Side by Side Refrig - No Water Dispensing
Tubing/resevoir is coiled behind the crispers and can freeze.
Eric
Posted on Jun 20, 2009
Sea Breeze
  • 4655 Answers
SOURCE: No water from door dispenser
This is most times caused by a defective dual water control valve on the back near floor of the refrigerator. Unplug the two wire connections and check both coils with an ohm meter. The both should read the same amount of resistance. Or set your meter on voltage and place the probes in each side of the plug and have someone press the dispense button. You should show the household voltage at the end of that plug. Sea Breeze
Posted on Jun 23, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Posted on Jul 12, 2009
aasc
  • 1606 Answers
SOURCE: G.E. Side by side model quit dispensing water
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Posted on Aug 25, 2009
Testimonial: "The diagnostic aid was helpful. Still trying to figure out how to unfreeze the water line in the door of the side by side GE refrigerator, however. "
I have a GE fridge side by side model GSH25JFTFWW. It is not keeping milk and fresh food cold. What is the problem?
There could be a defrost problem. This has an electronic control board. If the freezer has ice build up on the back panel then it isn't defrosting. this could be from a bad defrost heater, of defrost thermostat. the problem could also be from a bad thermistor on the coils. this won't allow the control board to defrost. It could be a bad control board of damper fan .
Oct 04, 2014 | Refrigerators
I have a refrigerator that uses the GE SMART filter. When the filter needs to be changed, the water stops working. I changed the filter -- still no water, yet it makes ICE....any thoughts?
The water valve has two sides. One side is for the ice maker and one side is for the dispenser. If the dispenser side fails you have to change the complete dual water control valve. What is the model number of your GE Refrigerator? Sea Breeze
Jan 10, 2013 | GE Refrigerators
We have a gsh25jftfww ge fridge. the temperature control panel (on front) does not light or work and fridge and freezer is not cooling. The light is still on in the refridgerator, but fan is not running...
Your refrig uses a main control board that is on a recall list .The board uses a WR55X10552 . The replacement board is WR55X10656 . I would suggest calling GE factory service and they will cover this under warrenty , due to the recall .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Oct 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrigerator wiring diagram
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
Feb 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
