Question about Exercise & Fitness
Error code 4 on sport craft tx400 treadmill
Runs for about 1 min and then stops.
vpaaf
  • 115 Answers
SOURCE: treadmill tx400 wont work for llonger then 6 seconds
Sportcraft tradmill are very safe. First check and make sure there are no recalls on you unit. Do that on line or call Walmart where you most lickly got you treadmill. Try lubing you deck wich is under the belt. This is something that needs to be done to stop friction... Frition may have worn down the motor. Get back to me
Posted on Oct 11, 2009
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
SOURCE: Sport Craft Treadmill model TX2.5xt, showing
You need to put the RED SAFETY KEY on the Yellow spot on the control panel to turn it on. EO will disappear once you put it on.
Paul
Posted on Apr 11, 2010
SOURCE: Can I fix my Sportcraft TX400 Treadmill ?
adjusting the belt
Posted on Jun 19, 2010
SOURCE: Repco Sports Treadmill
Repco RP300TM wont start E1 error message
Posted on Jul 14, 2011
What does a E2_C error code mean?
If the console doesn't receive a signal from the speed sensor, which is mounted on the back of the motor, the console stops sending power and displays an E2C error code.
You need someone to test voltage on the treadmill and determine if the power supply board, motor controller, or motor is bad.
You can have it repaired with "Sears Treadmill Repair" (even if you bought it somewhere else) calling them at 1-888-206-3131...
May 01, 2014 | Bowflex TC3000 Treadclimber
Treadmill triumph 400t has error E1
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
Apr 16, 2014 | Triumph Academy Sports 400T Treadmill
Tx400 treadmill runs for 7 sec then turns off
1)lUBE THE treadmill deck belt, the lack of maintenance produce SHUT down for to protect the electronic system
2) Lube the rollers bearing too
3) Measure the input voltage motor, if there are the motor need repair
4) Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. See the block diagram
God bless you
Jun 18, 2012 | Exercise & Fitness
E5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Nov 24, 2011 | Exercise & Fitness
E5 sportcraft tx400 treadmill
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=relatedsincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
See the schematic how the Main Controller has 90% functions in Treadmills
Z8 is showing L5 cant seam to fix this
Dear Sir:
I will try to help you, please use the steps with patience and carefully: You must need some basics tools; Included Dvom (Digital Voltemeter).
Instructions Things You'll Need for to Reset Code:
  • treadmill (all models applicable)
1.
    • 1
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    • 2
Press the "ENTER" button three times to access the treadmill's error log.
    • 3
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    • 4
To view the treadmill
Oct 19, 2011 | Spirit Fitness Z8 Treadmill
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
Error 1 message on older life fitness t3 treadmill
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
Treadmill tx400 wont work for llonger then 6 seconds
Oct 10, 2009 | Exercise & Fitness
Exercise & Fitness Logo
223 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
