What does F08 error on a WFS1275cd washing machine
Error F:08
  • 5 Answers
SOURCE: Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
  • 8 Answers
SOURCE: Indesit WIE127 Washing machine which
I HAVE THE FAULT CODES FOR SOME INDESIT MACHINES THEY ARE ONLY SUPPLIED TO THEIR ENGINEERS BUT A MATE OF MINE WORKED FOR INDESIT/HOTPOINT (ONE COMPANY NOW) UP UNTIL A MONTH AGO , HOWEVER ,THEY ARE AT WORK & I WONT BE IN UNTIL FRIDAY IF YOU CAN HANG FIRE UNTIL THEN I MIGHT JUST BE ABLE TO HELP YOU OUT!
Posted on Jul 30, 2008
GodBlessU
  • 3513 Answers
SOURCE: error code F-08
The meaning of F08 is that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
In order to resolve this the only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Hoep this resolves your issue. God Bless.
Posted on Jul 09, 2009
SOURCE: error F08 on a fagor washing machine FU-6146
F08 on my FAGOR means a new motor is required we've had 3 failed motors in the past 2 years , total rubbish machine , would never buy FAGOR again . Mr M Freeman.
Posted on Mar 06, 2010
sodeep
  • 3267 Answers
SOURCE: reset error code F08 in
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Posted on May 28, 2011
How to fix error f-08
if my memory serves me right f08 is faulty heater code check the heater is okay
Mar 09, 2014 | Hotpoint Ultima WF860 Front Load Washer
Hi we are getting an f-08 error code on our hotpoint wf840, any suggestions? thanks
F08 is for the heater relay on your washer. You can try unplugging the washer for a half hour and see if that will clear the error up.
Dec 29, 2010 | Hotpoint Washing Machines
My washing machine has just finished a cycle and an error message has appeared F-08 , cannot get machine to start
If it's Hotpoint or Creda,
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 24, 2010 | Washing Machines
Error code f-08
Hope this helps.
Dec 13, 2009 | Washing Machines
My hotpoint washing machine wt960 keeps displaying the fault code f-08 when trying to do a 40 c wash
Error code F08 is indicating that the heater relay cannot be activated.
Check all connections on pressure switch----module---- and heater.element.
Hope this helps, this is the recommended procedure.
Dec 01, 2009 | Washing Machines
F-08 Error message keeps appearing
Error code F08 indicates that the heater relay cannot be activated.
Check connections on
1--pressure switch.
2--heater element.
3--control module.
If you still cannot get it to work, then you are probably going to have to call an engineer.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code F-08
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I think you will find the pump comes on because the heater relay is stuck which then gives out the error F08, not the other way round. Check the heater, the pressure switch and the module connections (you will need a multi meter of some description) to check the connections.
Jul 09, 2009 | Washing Machines
Hotpoint washing machine WF860 F-08 error, does anyone know how to fix this
F08 error code: for hot point washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
hope this helps
Sep 29, 2008 | Hotpoint Washing Machines
Washing Machines Logo
14,176 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
