Question about Plumbing
Cant find valve cartridge for a Blanco 157-065 pot filler to purchase
Looking on line for anyone selling valve cartridge replacement for a Blanco wall mounted pot filler # 157-065. Please advise
2 Suggested Answers
  • 171 Answers
SOURCE: Installing a Pot Filler
Hi 13Kat,
I'm Harvey the Master Plumber.
You must connect to a flanged fitting behind the wall. The wall is sandwiched between the flange behind and the escutchen in front that holds the pot filler in place. These are usually installed on stainless steel sinks that have stainless steel back walls and do not come supplied with the flanged fitting, available at any plumbing supply.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
How do you adjust the fill rate of fill valve?
The fill rate is determined mostly by the incoming water pressure. If it's filling too fast, you could close the source valve (between the wall and tank) slightly. If its too slow, the source water line may be clogged, or the filler itself may have become clogged. Not much to do but replace the filler if it's clogged.
Oct 05, 2014 | Home
Where can I purchase a replacment pan?
Go to this site http://www.crock-pot.com/CustomerService.aspx?id=rpt and put in your model number (located on the bottom of the unit) and you can order the liner and other parts for your crock pot.
Jun 23, 2014 | Greenpan Premier Pressure Cooker
How to replace cartridge on blanco 157074R-ST
Check "YOUTUBE" for blanco cartridge replacement. They have a great video on how to do it.
Apr 18, 2014 | Blanco Plumbing
Check "YOUTUBE" for Blanco cartridge replacement. They have a great step by step video.
Where is the filler valve for the ac unit on the 2.2 95 camry
It may vary, depending on the market, model, engine and brand of the system, but generally one of the refrigerant lines will be larger, with a thing on it looking like a large bicycle valve under a plastic cap.
This may assist, although it may not be identical to your car
http://www.turboninjas.com/camry/ac.pdf
Apr 16, 2012 | 1995 Toyota Camry
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
I have a 2001 Chevy Blazer and it is slow to take gas from the gas station. I was told to check the vent hose, but can not locate it. It does not run with the intake line nor does it Y off the intake line,...
the vent hose you are looking for is located off of the gas tank it should be beside your filler hose. if you don't see one there then you tank has a vent on top that is the problen and probably needs replaced
Oct 15, 2010 | 2001 Chevrolet Blazer
Dometic Duo Therm AC Brisk Air 13k btu not blowing cold air
you can buy a saddle valve, this is a valve you screw in. I am assuming you have the correct freon as where you purchased your freon they should sell the saddle valve. Hope this helped
Jul 23, 2010 | Dometic Rooftop RV Air Conditioner
Replacement hinge for Crock Pot #SCV550H
you cant. those hinged lids are junk and you cant get one of those either. you might as well just buy a whole new crockpot that doesnt have that lid. those lids always break.. if you have your receipt you should try calling that company and if they feel like it.. they might replace hit.. haha good luck though!
Nov 26, 2008 | Rival 38601 Smart Pot 6-Quart
Hi 13Kat,
Thank you,
Oct 06, 2008 | Franke PF3000 Deck Mounted Pot Filler...
Plumbing Logo
35 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
