Question about Belkin (F5D5231-4) Router
BElkin wireless modem + router dsl conectivity issue
Alrighty I'm gonna try exsplain this forgive me for lack of spelling and gramma. ALright so I went to sleep and my belkin router + modem thing (it's like a two in one ) was working fine. when i wake up The Light that has the telephone thing above it is't solid but flashing at certian periods and the light with the world looking thing above it isn't doing anything now i've tried using difrent cords to the phone line a difrent phone jack tried it w/o any phones on the line with and without filters and it just won't go It realy has me in a bind and it seemed to happen over night cause it was fine when i went to sleep i wake up and it's all like this any sugestions / fixes
Kt.
  • joe_thomas May 11, 2010
    Have you unplugged it and re-plugged it back in after a minute or so? You may need to re-configure, or reset your DNS addresses through the configuration menu. Your ISP should have given you the primary and secondary one of these. I don't know too much about DSL. I know that turning them on and then off again clears a lot of problems. Make sure there are no other wireless routers, range extender, repeaters, etc., in the proximity of your Belkin router. IP confusion has caused a lot of grief for these. Disconnect all corless devices (unplug them even) taking a source from a single jack. I don't know if this helps or not. Good luck.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
Their should be a reset button on the back of your router/modem. You need to get a stick pin and reset it. Then turn it off from the power and allow it to reconnect. If this does not work I would call your ISP provider and get their help. They should be able to tell if it is working properly or not. Hope this helps. Please rate my answer.
Posted on Feb 17, 2009
I cannot connect the computer to the router while the computer is conected to the internet
are you trying to connect wirelessly?
do you have a cable modem or dsl connected to the router and the computer connected to the router?
Mar 07, 2011 | Belkin (F5D7230-4) Router (587009)
My Belkin wireless G router does not seem to work any more. If I connect my router to my DSL modem, I am not able to make a connection to the internet via the router to my iMac. However, if I connect the...
So if you connect the computer directly to the modem , it works .
That means your modem is working properly. Your ISP is DSL connection. Now connect the modem to the router and the computer to the router. Open the router xet up page and change the settings of the router according to the type of connection you have.
There are 2 types of connection in DSL.
DHCP and PPPOE .
Click Here for step by step instructions
Feb 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin F5D8236-4 Wireless Router will not connect to pannaway dsl modem with same settings as router I am replacing. Dynamic IP address setup. Modem light continously blinks orange. No internet light.
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
Oct 03, 2009 | Belkin F5D8236-4 Router
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connect router to playstation 3
You need to first plug the DSL modem into the router. log on to the router. Configure the router byusing the user name and password as supplied by your dsl provider. once the router connects to your dsl provider, you should be able to connect your playstation to the wireless network.
Jun 02, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trying to set up wireless router to satellite phone/internet
i've never worked with a 7740, but i've installed hundreds of hn7000's and hn9000's. the issue is usually that the router and modem are defaulting to the same ip address. if your router supports has a web-based config utility (as most do) try cat-5'ing to the router with your computer while the router is NOT connected to the modem. log into the router and set it's ip address to something OTHER THAN 192.168.0.1 (i use 192.168.1.1 for my customers) reboot the router and reconnect it to the modem. the ip conflict should now be resolved.
Feb 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Jan 05, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Belkin router
I just worked on one of these today. Try this and see if it helps.
1. Unplug your cable or DSL modem and your wireless router
2. Plug back in the cable or DSL modem and wait for the internet to successfully connect (watch the lights).
3. Plug the wireless router back in again and wait for it to connect (again, watching the lights)
If this doesn't work, make sure you have the equipment plugged-in in the right order.
cable or dsl signal goes to modem ==> modem plugs into wireless router ===> computer plugs into wireless router.
Feb 02, 2008 | Belkin (F5D7230-4) Router (587009)
All downlods stall
try disabling windows XP firewall...
May 20, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin (F5D5231-4) Router Logo
143 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
