Question about Nikon D5100 Digital Camera with 1855mm lens
My nikon d5100 comes out with lcolored lines up and down my pictures dissorting my image,whats wrong?
It makes my pictures look all dissorted and wrapped..please help is it broken?
  • 3 Answers
The sensor would be a prime suspect. Has the camera been anywhere where dirt or moisture might have got in? Or has an attempt been made to clean the sensor recently? If so, it may be worth taking to a specialist camera shop to check, but prepare yourself for some bad news. If it is the sensor that is broken it may well be beyond economical repair.
Posted on Jan 16, 2015
  • 15 Answers
SOURCE: Nikon D1 - thin green line across image
There's a few things you can try to narrow down where the problem might lie. One thing you don't mention is if the green line is on the actual image, or only shows up on the LCD monitor.
If the line is in the actual image after transferring it to your computer, try formatting the memory card in the camera, or try a different card to see if the problem persists. If it only shows on the LCD, count yourself lucky because you can continue to use your camera, albeit with an annoyance to deal with.
However, it sounds to me as though you've got either a dead or hot pixel on the CCD which will cause problems in the adjacent pixels creating a "line". Take a look at this page and this page. Unfortunately, you will most likely need to send it in to Nikon for repairs.
Posted on Dec 14, 2007
  • 3 Answers
SOURCE: Nikon D90 takes pictures, all pictures are black!
I think its your CCD. If its new take it back. Nikon will fix it for free
Posted on Apr 22, 2009
iwctoys
  • 126 Answers
SOURCE: image screen on nikon d40 won't stay on
You have a short in your button board in your camera or a bad button board. Send into Nikon to repair. You can also look on Ebay for the part if your technical skills are up to self repair.
Posted on Jul 02, 2009
SOURCE: dropped my nikon coolpix...the lense was stuck but
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Feb 07, 2010
ZJLimited
  • 17970 Answers
SOURCE: Plz help me- 4 white small bars on my LCD Nikon D5100
Hi there:
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Posted on Aug 21, 2012
Electric clutch is staying stationery when engaged wires wrap around clutch and break off what is missing what keeps it from spinning around
Very hard to say without seeing it or a picture, but likely the stabilizer plate is broken from vibration.
May 08, 2016 | Garden
Brought used tv,was made aware of this problem,just looking for advice please.Picture dissorted on right side of screen,then can clear for hours or days,then returns for hours,any ideas please.
U have an intermittent condition on what is referred to as the T con board
U don't fix boards - too much of a hassle, labor, expense. U replace them..
Sep 25, 2015 | JVC Televison & Video
remove lens keep bulb mode for 15 sec.shutter speed take cotton cloth wipe sensor gently in 10 sec.
Jan 07, 2013 | Nikon D5100 Digital Camera with 1855mm...
On my laptop the volume changes and is dissorted. Lost the remote for mitsubushi big sreen tv and when I manually turn it on only the timer button flashes green. thanks
Dear User,
For distorted audio issue I would suggest you to please install the latest version of audio driver and also update the bios of the laptop.
Regards,
Tech_Comp
Feb 22, 2011 | Computers & Internet
The plastic piece that holds the rod from cylinder to the paddle is broken. How can I fix that?
For a temp. fix, grab some wire and wrap it around each rod, then insert into the hole (were the plastic piece broke) and wrap those two together, YOU NEED to repair it correctly, go to dealer and they have pictures that can locate the plastic bushing.
Feb 14, 2011 | Pontiac Grand Am Cars & Trucks
Using Word 2010 Avery Address Label 5160 Trying to put a tiny photo of my new book, next to my address as a marketing tool. I can get the book on label or the address, but can't figure out how to...
The problem is due to "wrapping". That is why you can't get your picture to stay where you want it to go. There are two ways to fix this. You can right click with your mouse on top of the picture and choose edit then find wrapping and select in front of text or behind text and then close it and this will make the picture stationary.
Or
You can open the picture ribbon at the top of the screen in the software and look for wrapping and change the setting to in front of text and this will also fix the problem.
Nov 24, 2010 | Computers & Internet
THE SPIN DRYER IS MAKING NOISE BUT NOT SPINNING
Hi, if the tub is not spinning, you have either broken the belt, or the motor has burned out. If you are a handy person, you can pull off the back panel to get a look at the tub and the belt will be wrapped all the way around the tub and motor pulley. Turn it on if the belt isn't broken to see if the motor is trying to turn at the pulley. If the belt is broken that's the problem, but also make sure the motor runs because if it if froze up due to loss of bearings it will break the new belt if you decide you are going to try and replace it on your own. You will have to wrap it around the tub and run it over the belt tentioner and around the pulley. You can get a belt at a appliance parts house. Take the model, serial, numbers and brand name, and the old belt may have a part number on it. Keep me posted please.
I will check back in the morning.
Sincerely,
Shastalaker7
Mar 17, 2010 | Washing Machines
My sharp aquas lc32d44e has got dissorted sound how do i fix it
check the sound settings and see if it will make any difference. Also if volume is too high, it might cause some distortion.
It could be that the speaker has got some holes. It is has some holes, then you need to change the speaker.
Best regards.
Jan 05, 2010 | Televison & Video
How to wrap text around a graphic, I have followed all directions from users manual and tutorials nothing works, I am using Printshop 23 with windows Vista, I dont seem to be having a problem running the...
I use word but it may be the same for Corel. You need to click on the picture and then from the drop down box choose text wrapping. It will giveyou options of how to place the text arround the picture.
Dec 21, 2009 | Encore The Print Shop 23 Deluxe Full...
Rca 52inch hdtv
Please replace STK392-110 quantity 02 in your tv to fix convergence problem.
Above said part is available here.
Regards,
Sep 27, 2008 | RCA HD52W59 HDTV Projection Television
Nikon D5100 Digital Camera with 1855mm lens Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
