Question about Canon PIXMA Office Equipment & Supplies
I can not find 3v button batery on canon ip4950
I need to reset in absorber on canon ip4950, on one post a readed that I need to remove 3v button cell battery but I can not find it
SOURCE: Canon iP2000 Waste Ink Absorber - where is it for washing and replacing?
I found it under my ink cartridges in my Canon iP2000 printer. Trying to losten it for cleaning, it came out in my hand, I washed it and replaced it with a tiny amount of glue. After resetting the program, it is working again.
Posted on Sep 22, 2008
SOURCE: Reset Waste INk Canon MX318
help me please....!!
may printer error 5B00
Posted on Apr 01, 2009
jim4984
  • 797 Answers
SOURCE: How can i reset or remove ink absorber full error
You should replace the aborber if you have not already. You can get one from ebay.
You can buy a service manual here which will have the reset instructions.
Posted on Mar 20, 2010
netrocker
  • 162 Answers
SOURCE: Hy! I need to reset my canon Mp190 ink counter and
Please refer to this:
http://www.youtube.com/watch?v=WOxkCjIQlRo
Posted on May 31, 2010
SOURCE: how to reset waste ink absorber full ip3300 warning?
Try to enter service mode and reset EEPROM:
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head
Press RESUME 4 times then POWER to execute the command
turn the plug off turn on and all ok
Posted on Jul 30, 2010
Why is my canon ip1800 printer still not printing after cleaning the ink absorber, I still get the message ink absorber is full
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The ink absorber is full Canon Pixma IP1980 IP1880
How to Clean Canon Ink Absorber
iP1800 ink absorber
Apr 07, 2016 | Canon Office Equipment & Supplies
Tip
How To Reset Ink Absorber Canon i550
When your Canon i550 printer get an Ink Absorber Full error, then you need to reset this Canon i550 inkjet printer.
The following step is procedure used to reset waste ink counter of Canon i550. Nevertheless, this procedure is also applicable for the printer models listed below.
PROCEDURE:
I. Enter Service Mode:
  • Plug in power cable
  • Hold down RESUME/CANCEL button
  • Hold down POWER button
  • Release RESUME/CANCEL button
  • Press RESUME/CANCEL twice in a row
Continue reading complete step below:
How To Reset Canon i550
on May 11, 2014 | Office Equipment & Supplies
What is the waste ink absorber reset code for pixma IP4950
this is how to do it use xp
http://www.mediafire.com/?dbi16o3ovel1iyk
download the v3400 for free in link above it is 9,5mb ( there is a other file dont use it only the service mode tool v3400 )
follow this instructions and you will be fine
http://www.2manuals.com/product_info.php?products_id=1445
- power OFF the printer bu Power button. Dont disconnect power cable
- connect the printer by USB cable to the PC.
- press and hold Resume button (red triangle in the red circle) and press Power button
- hold both buttons until power on indicator will light then release resume button (dont release Power button) and press Resume button 5 times
- release all buttons - the printer will blink few times with green light and will then light green constantly. You have put the printer in Service Mode now and you can now run the Service Tool. (If the printer is still blinking by green - you have some other errors in printer and you have to fix them first, because the Service Tool will not work if the printer is not put in service mode - green light is constant)
4. Run the Servicetools V3400.exe program.
5. Select the connected USB port number from USB PORT
6. In the Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber pull-down menu.
7. From the Counter Value(%) pull-down menu, select the value (in 10% increments) which is the closest to the actual counter value confirmed before replacement of the logic board, and click SET.
Print EEPROM information to confirm that the value is properly set to the EEPROM
Jul 27, 2012 | Canon PIXMA Office Equipment & Supplies
Canon 6c10
Hello and Welcome to FixYa!
Error 6c10 is ink absorber problem.You need to reset Printer Canon ink absorber. For this Follow the steps given below
  • Start with printer off
  • Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  • While holding the Power button, release the Resume Button.
  • Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  • Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  • Turn off the printer and turn on again
Error will be removed
If the problem exist then then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution helps you
Thank you for using FixYa!
Jun 18, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Error 6c10
I hope this solution helps you.
For further assistance, I am here to help
Concerned:
Angel Bird
May 05, 2011 | Canon MP560 All-In-One InkJet Printer
Canon mx860 6c10 error
to fix this you must'
    1. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
    2. While holding the Power button, release the Resume Button.
    3. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
    4. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
    5. Turn off the printer and turn on again
    Mar 26, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
    The Canon ix4000 is giving me i service error 5C10 please can someone help me?
    Error 6c10 is ink absorber problem.You need to reset Printer Canon ink absorber. Follow the steps given below
    Anymore help, I am here to help
    Concerned:
    Uxair Shah
    Mar 18, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
    The waste ink absorber is full how to by pass this
    Since my last post, I have found the method to reset the counter and stop the error message that the waste ink absorber is ALMOST full. I am not sure if it will work once the error becomes the waste ink absorber IS full.
    After cleaning the ink absorbers as instructed in my last post, remove the print head by following the instructions which can be found on-line at www.usa.canon.com. Click on support and enter your model information. Then in the search box enter "remove print head."
    After removing the print head, perform the following instructions:
    1. With the power turned off, while pressing the Resume/Cancel button, press and hold the Power button. DO NOT release the buttons.
    2. While holding the Power button, release the Resume/Cancel button. DO NOT release the Power button.
    3. While holding the Power button, press the Resume/Control button 2 times, and then release both the Power and Resume/Cancel buttons.
    4. When the Power LED remains green, press the Resume/Cancel button 4 times.
    5. Turn the printer off.
    6. Turn the printer back on and install the printer head with on-line instructions as described above.
    You are now ready to print,
    Larry
    Aug 06, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
    Canon Pixma ip 90 mobile printer with error message ''waste Ink absorber full. Is there a way to fix this without seeing a dealer? I've read solutions where for other canon printers with a similar message....
    there are two ways you can remove the error message from your printer..
    the first is to reset the printer and the second is to replace the waster absorber. If the reset thing did not work for your then you'll be spending money to replace the absorber.
    How to reset? follow these steps
    1. Turn off the printer...press and hold the resume/cancel button... then press and hold also the power button..
    2. Release the resume/cancel button while holding still the power button.
    3.(While still holding the power button)...press three times the resume/cancel button
    4. (After pressing the resume/cancel button three times)...release the power button
    5. Wait for a couple of seconds.. when the led stops blinking and turn green..Press the resume/cancel button four times.
    6. Press the power button...some functions will be perform before the printer return to menu selection mode..
    7. Turn off the monitor wait for 5 seconds, then turn it on and try printing..
    Hope that solve the waste ink absorber in your printer..
    If you find this solution helpful..would you be kind to rate this solution and vote for this on the help below..thanks..
    Mar 23, 2009 | Canon PIXMA iP90 Mobile Printer
    Waste ink tank full..error 5B00
    Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
    You need to Remove the ink Cartridge first in order for the code to take effect.
    1) Closethe print head cover.
    2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
    4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
    5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
    6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
    7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
    8) Power off then back on and test.
    9) Congrats!!
    Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
    Dec 03, 2007 | Canon Pixma iP6210D InkJet Photo Printer
    51 people viewed this question
    old marine
    old marine
