Question about Goodman Heating & Cooling
Electrical schematics goodman phkj030
Need wiring schematics
5 Suggested Answers
BearWeb
  • 357 Answers
SOURCE: need wiring schematics for goodman
Here is a diagram containing the Wiring Schematics for Goodman Gas Furnace
Posted on Jun 27, 2008
woobie dog
  • 1273 Answers
SOURCE: need wiring schematic for a goodman 4ton unit
There should be one packaged with the unit. Shut off the power and open the metal enclosure around the control board.
--W/D--
Posted on Aug 18, 2009
SOURCE: I need wiring diagram for goodman AC unit heatpump/electric
The wiring diagram is on the inside of the door on the blower/air handler unit.
Posted on Mar 19, 2010
  • 1340 Answers
SOURCE: need a wiring schematic for
I have searched for schematics for many things.They are not a free download and you will have to contact the maker to see if they will even sell you one.Here is the link.Good luck! Greg
http://www.goodmanmfg.com/Home/AboutGoodman/ContactUs/tabid/156/Default.aspx
Posted on Aug 10, 2010
Wiring schematic goodman ph036a serial # 9610058720
Is condenser running? Verify amps to be sure both fan and compressor are operating. Should have 2 wires to compressor and 1 to fan on top of contactor. Then on the capactor (herm) terminal is the remaining compressor wire. On fan and c would be the 2 remaining wires for the outdoor fan motor. Then 1 more wire on c that jumps to the top of the contactor on the other side to which the first fan wire connects. GOOD LUCK.
Mar 19, 2017 | Goodman Heating & Cooling
Need wiring schematics for goodman manufacture model # A60-20REV/C gas furnace
Jun 27, 2008 | Goodman Heating & Cooling
Need the pin to pin wiring schematics for this model of motorcycle?
    More images for 1990 Kawasaki 650R wiring schematic
    Kawasaki Motorcycle Wiring Diagrams - ClassicCycles.org
    www.classiccycles.org/1852/597943.html
    Kawasaki Motorcycle Electrical Wiring Diagram Schematics. ... Kawasaki GPZ600 GPZ 600 Electrical Wiring Harness Diagram Schematic 1988 to 1990 HERE ...Kawasaki KZ650 Z650 KZ Z 650 B Electrical Wiring Harness Diagram Schematic ...
    Owner Center - Kawasaki
Jan 21, 2016 | Motorcycles
I have a goodman furnance there is a loose green wire coming from the motor where does it go? Please help me.
Hi, W/D here.
A short green wire usually indicates a ground wire, and can sometimes have a terminal attached to the end of it. This wire would go to the frame of the furnace, as a ground wire for the motor, bonding the motor to the frame electrically. Usually, it is attached to the frame at the nearest point of contact, which usually is a motor attachment screw, or a green colored screw in the panel near the motor, and will sometimes have the grounding symbol near it. Before making any connections, check your wiring diagram first. It will be either in your paperwork with the furnace or attached to one of the panels near the motor. It can also be located inside the furnace electrical panel on the furnace, so make sure that the power is turned OFF (trip the breaker, and test it) before opening the electrical connection panel. Once you locate the schematic with the motor on it, find the green coded wire on the schematic and see where it goes. My experience has been that it will be a ground wire, but you have to check.
Best regards, --W/D--
Oct 20, 2011 | Goodman GMS90703BXA Heater
Need a wiring schematic for a goodman ck48-1c air conditioner
Aug 10, 2010 | Heating & Cooling
Need wiring schematic for a goodman 4ton unit model #mle48-1b
--W/D--
Aug 18, 2009 | Goodman Heating & Cooling
Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
Jun 21, 2009 | Goodman Heating & Cooling
New furnace, goodman and reinstalling squirrel cage... unsure where to put red wire running from squirrel cage
Follow your schematic on the new unit. It will tell you where the wire goes. Some of the "extra" wires are connected to the main board close to where the "used" wires are and they are labled "spare". Find the blower motor on the schematic and trace out where this wire will go.
Mar 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
