Question about HP Compaq Evo n800c Notebook
No hard disk drives
Im trying to put a new hard drive in mycompaq evo n 800c and it says that there is no hard disk drives so im not shure what i need to do
  • Anonymous Feb 23, 2009
    i put the hard drive in my compaq evo n800c and the computer say no hard disk drive
  • 125 Answers
Make sure that you put the h/d in all the way so that it is seated firm if thats not it you will have to use a small jumper on the 2 pins that do not go into the caddy adaptor try the out side one first this puts in slave mode the next one puts it in cable select mode
Posted on Jul 05, 2009
  • 70 Answers
Wich message that show "there is no hard disk drives"
if in win XP
when the setup is loading driver it's will ask for SATA/RAID driver
you must press F6 then insert your SATA driver with USB floppy drive
or install XP with something like unattended installer with SATA driver included
or if it's shown in BIOS
probably your harddrive is broken
and you must replace it
or claim your warranty
note: ask your OEM
Posted on Jan 20, 2009
I have evo n610c laptop but when ever i turn on the laptop itgives a messege that non disk system or disk error with some sort of noice coming from hard drive
This error message could be caused by the laptop not detecting the hard drive.
Check the BIOS to see if it detects the hard disk
If not the hard disk may be faulty or needs reseating. If the hard disk is faulty it needs to be replaced and Windows installed on the new hard disk.
A virus program may have infected the computer and removed or changed some system files - in this case Windows needs to be repaired OR Windows re-installed - this is the best option.
Aug 15, 2010 | Compaq Evo N610C Notebook
Have compaq evo n610c laptop, it locked up on
sadly you need a new drive, these are about £40.
from any computer vendor fit new drive and then load installation disc.
hope this helps.
Apr 27, 2010 | Compaq Evo N610C Notebook
Problem loading os on compaq evo n610c
Make sure you start by deleting the old partition, and formatting C:. If it still locks up after that, then your hard drive is bad.
Nov 21, 2009 | Compaq Evo N610C Notebook
Doesn't boot
If the bios does not reconise the hard drive then you will need a disk utility at this point. some laptops only accept a max of 120gigs for a reason if your trying to put a larger drive in a old system you need the latest bios drivers for one and use a disk utility.
Aug 10, 2009 | Compaq Evo N610C Notebook
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
Trying to wipe the hard disk of an old Compaq Evo
You message cut out. It's very difficult if not impossible to wipe a hard drive when you're using that hard drive. You need to get a program like Gparted or Disk Manager. The first is free and can be downloaded.
Mar 27, 2009 | Compaq Evo D500 PC Desktop
Problem with recognizing 2nd hard drive in Compaq EVO D510
you need to initialize the newly added drive in disk management, then format the drive once disk management assigns a drive letter.
CONTROL PANEL, ADMIINSTRATIVE TOOLS, COMPUTER MANAGEMENT, DISK MANAGEMENT
There you should be able to see the 2nd drive, Right click and INITALISE it, once it is initialized, it will be assigned a drive letter and you can format the drive
Feb 05, 2009 | HP Compaq Evo D510 e-PC PC Desktop
Compaq evo 610
Turn it all the off. Then pull the hard drive out and put it back in again. Now, put your system disk (Win XP?) into the drive and turn the laptop on. It should do something else now. I have had this happen on several laptops I have rebuilt and it takes patience to get them started sometimes.... I have managed to load XP onto all of them eventually!
Hope this helps
Apr 04, 2008 | Compaq Evo N610C Notebook
New Hard Disc for COMPAQ Evo410c...Now what..
you need to get some operating system.
like XP or Vista.
you can get XP disk with some of your friends if they have..
or you have to buy those operating systems...
and after loading disks into your disk drive disk is autometically get started...to load XP or vista..
Mar 31, 2008 | Compaq Evo N410C Notebook
HP Compaq Evo n800c Notebook Logo
140 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
