Question about Coleman Powermate Premium Plus 6250W Portable Generator
Cold weather generator running
Last week I had to run my 6250 coleman generator outside at about -35 C. In about an hour it started to blow oil from the generator end it appeared. Ia there a solution short of having to enclose and heat the area?
  • conrus Feb 03, 2009
    I'll give it a try, thanks. IR
    Problem Solver:
  • 10 Answers
I don't believe you have a problem with running your unit out in cold weather, it just does't make any since. There have to be a problem with the engine. If your unit is new or has been used very little, it is not broke in and has a to much blow-by. If this is the case you will find oil in your air clean and/or muffler. To fix it problem you need to change your oil and replace it with a organic oil which means not synthetic. Run your unit under 1/4 load for 15 minutes in your case about 15 amp at 120vac. This step it up to 30 amps at 120vac of 15 minutes then 45 amps for 15 min. Then about 60 amps for a good hour. After that step the unit back down to 45,30,and 15amps to allow the engine to cool-down properly. If you load your unit with 240vac instead of 120vac just divide the amps by two giving you 7.5, 15, 22.5, and 30amps. This should break your engine in. If you are still leaking/pushing out oil you more than likely have a bad seal, gasket, or something broken in you engine internally.
Posted on Feb 02, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
What weight oil do I use for a 5000 watt Coleman generator
Depends on the temperature where yuo will operate it, but a good multi-viscosity oil like 10W-30 should work. 5W-30 for cold climates.
Sep 07, 2014 | Coleman Powermate 5000 Portable Generator...
My Coleman powermate generator 6250 won't start. We used it last month when we had a power outage during the coldest of winter weather. We checked the oil, gas compartment and found that there was...
Make sure the sparkplug is clean and gapped. Unloosen the float bowl slightly and drain about a half cup of gas out of the bowl. It is possible a little condensation got in to the fuel. Tighten the bowl nut slightly and try to start the generator.
Mar 10, 2011 | Heating & Cooling
How often should I change oil in my model 6250 powermate. Thanks
For some reason people think that the oil goes bad in 2 weeks because it is a small engine, but if you compare 3,000 miles on your car to hours, you would never change the oil in the generator. I don't think I have changed my lawn tractor oil in 15 years, and it is still clear, never broke down, because in 15 years, I've probably run it, 150 hours? It's about due. I hope this helps.
Apr 29, 2010 | Coleman Powermate Premium Plus 6250W...
I tried to start my new coleman powermate 6250/5000,
Do check the oil after it has tried to start. Low oil cutoff would certainly cause the problem. Look for the "lost" fuel shutoff valve... there usually is one.
Apr 24, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 6250 generator - shut off generator at 11pm after v4 hours normal use. At 5am, wouldn't start, pull rope wouldn't move to start. A few hours later while draining oil found mostly gas...
the usual reason is a stuck float in your carburator , can be caused by dirt/rust etc , remove carb bowl and clean , there is also a very small needle valve which is attached to this float ( metering needle ) these can leak.
if all else fails always turn off the fuel supply to the generator whilst not in use
Oct 21, 2009 | Coleman Powermate Powermate 5000W...
A call to Elliott Small Engine solved my problem - Oil Guard. I had checked the oil and it was just a little low but seemed well within the normal range. I was told to add more, bringing it just over the Full mark. It seems that the low oil protection system is very sensitive and shuts down the engine even when the oil is withing 1/8" of the mark. I added about 2-3 oz of oil and no more problems
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
214 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
